Do more with an affordable Instant Ink ready HP ENVY all-in-one – the perfect match for your technology. Save up to 70% on ink and enjoy the easiest way to print from your smartphone or tablet. Get wireless printing and lab-quality photos.
You can afford to be creative with HP Instant Ink
Save up to 70% on ink and never run out ink. Original HP ink. Ordered by your printer, delivered to your door.Print colour, black & white, and photos – your cost is the same.Ink cartridges and delivery costs included in your monthly plan price.No annual fee – change or cancel plans online anytime without penalty. -
Easy photo printing from your mobile device
Your device, your choice. Easily print documents and photos from a variety of smartphones and tablets.Start printing and get connected quickly with easy setup from your smartphone, tablet, or PC.Connect your smartphone or tablet directly to your printer – and easily print without accessing a network.Manage printing tasks and scan on the go with the free HP All-in-One Printer Remote mobile app. -
Everything you need to create
Print, scan or copy quickly and easily with the 5.5 cm (2.2-inch) display – simply touch and go.Save paper and conserve resources – use up to 50% less paper with easy, automatic two-sided printing.Print borderless, lab-quality photos, laser-quality documents, scrapbook pages, and more – right in your home.Print remotely without worries. The auto-deploying output tray keeps your pages from landing on the floor. -
Do more in less space
Save your space with a sleek, compact all-in-one designed to fit where you need it.Print in any room you choose – without causing disruptions – using the optional quiet mode.
- HP ENVY 4520 All-in-One - multifunction printer - colour - HP Instant Ink eligible
- Multifunction printer
- Localisation
- English / United Kingdom
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- HP Thermal Inkjet - 4-ink
- Monthly Duty Cycle (max)
- 1000 pages
- Recommended Monthly Volume
- 100 - 400 pages
- Max Copying Speed
- Up to 7.5 ppm (mono) / up to 4 ppm (colour)
- Max Copying Resolution
- Up to 600 x 300 dpi (mono) / up to 600 x 300 dpi (colour)
- Max Printing Speed
- Up to 9.5 ppm (mono) / up to 6.8 ppm (colour)
- Max Printing Resolution
- Up to 1200 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
- Scanning
- 1200 x 2400 dpi
- Display
- 2.2"
- Original Size
- 216 x 297 mm (max)
- Original Type
- Sheets
- Media Size
- 76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, cards, photo paper
- Standard Media Capacity
- 100 sheets
- Output Trays Capacity
- 25 sheets
- Automatic Duplexing
- Yes (printing)
- Connection Availability
- Interface
- USB 2.0, Wi-Fi(n)
- AirPrint Enabled
- Office Machine Features
- Scan to e-mail, scan to folder, HP Auto Wireless Connect, Mobile Printing
- Power
- AC 120/230 V (50/60Hz)
- 44.5 cm x 36.7 cm x 12.8 cm
- 5.41 kg
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Ink-jet - colour
- 1000 pages
- 100 - 400 pages
- Display Diagonal Size
- 2.2"
- Display Features
- Touch screen
- Interface
- USB 2.0, Wi-Fi(n)
- AirPrint Enabled
- Localisation
- Standard Memory
- 64 MB
- Max Supported Memory
- 64 MB
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 50
- Copying Features
- ID Card Copy
Printing
- Inkjet Technology
- HP Thermal Inkjet
- Nozzle Configuration
- 328 nozzles (black), 588 nozzles (cyan, magenta, yellow)
- Ink Cartridge Configuration
- 1 pigment black cartridge, 1 colour cartridge (cyan, magenta, yellow)
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, pigment black
- 4-ink
- Printer Drivers / Emulations
- PCL 3 GUI
- First Print Out Time B/W
- 18 sec
- First Print Out Time Colour
- 20 sec
- Colour Management Features
- ColorLok Technology
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 2400 dpi
- Interpolated Resolution
- 2400 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Document & Media Handling
- Max Original Size
- 216 x 297 mm
- Original Type
- Sheets
- Min Media Size
- 76 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 64 g/m²
- Max Media Weight
- 300 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 101.6 x 152.4 mm, 76 x 127 mm, 127 x 177.8 mm, 203.2 x 254 mm
- Supported Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm)
- Borderless Photo Sizes
- A4 (210 x 297 mm), 216 x 297 mm
- 100 sheets
- 25 sheets
- Input tray - 100 sheets size: 76 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 64 g/m² - 300 g/m² , Output tray - 25 sheets
- Speed Details
- Printing: up to 20 ppm (A4) - B/W draft , Printing: up to 20 ppm (Letter A) - B/W draft , Printing: up to 9.5 ppm - B/W (ISO) , Printing: up to 16 ppm (Letter A) - B/W draft , Printing: up to 6.8 ppm - colour (ISO) , Printing: up to 16 ppm (A4) - colour draft , Copying: up to 7.5 ppm - B/W (ISO) , Copying: up to 4 ppm - colour (ISO) , Scanning: up to 4 ppm (A4) - colour normal , Scanning: up to 8 ppm (A4) - B/W normal , Printing: 51 sec (10 x 15 cm (4"x6")) - photo normal
- 1 x USB 2.0 - 4 pin USB Type B
- Wi-Fi Direct
- Operating System Support
- MS Windows Vista, Apple Mac OS X 10.8, Windows RT, Apple Mac OS X 10.9, Android 4.0.3, MS Windows 7 (32/64 bits), iOS 7.0 or later, Apple Mac OS X 10.10, MS Windows XP 32-bit Edition SP3 or later, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10 (32/64-bits), Blackberry, Windows 10 Mobile, Chrome OS
- Software Included
- Drivers & Utilities, HP Photo Creations, HP Update
- Voltage Required
- 15 Watt
- Power Consumption Standby
- 3.05 Watt
- Power Consumption Sleep
- 0.55 Watt
- Included Accessories
- Phone cable
- Consumables Included
- 1 x ink cartridge (pigmented black) - up to 190 pages - HP 302 , 1 x ink cartridge (yellow/cyan/magenta) - up to 165 pages - HP 302
- PSB, UL 60950-1 Second Edition, BSMI CNS 13438, Green Dot, EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, EAC, EN 62479:2010, EMC 2004/108/EC, LVD 2006/95/EC, EN55022:2006, CISPR 24:2010, EN 55024:2010, EN 301 489-1 V1.9.2:2011, EN 301 489-17 V2.2.1:2012, CISPR 22:2008, CAN/CSA C22.2 No. 60950-1-07+A11:2011, IEC 60950-1:2005 + A1:2009, EN 62311:2008, FCC Part 15 Class B, IEC 62479:2010, ICES-003 issue 5, VCCI V-3/2013.04, KKC certified, IEC 62311:2007, AS/NZS 60950-1:2011, EN 60950-1:2006+A11:2009+A1:2010+A12:2011, EN 55022:2010 Class B
- ENERGY STAR Certified
- Limited warranty - 1 year , Technical support - web support - 1 year
- 44.5 cm
- 36.7 cm
- 12.8 cm
- 5.41 kg
- Shipping Width
- 48.5 cm
- Shipping Depth
- 16.8 cm
- Shipping Height
- 44.5 cm
- Shipping Weight
- 6.45 kg
- Sound Emission
- 51 dBA (operating)
- 5 °C
- 40 °C
- 20 - 80% (non-condensing)
HP Everyday Semi-Gloss Photo Paper-100 sheet/A4/210 x 297 mm | In Stock | £14.68 |
HP Iron-on Transfers-12 sheet/A4/210 x 297 mm | In Stock | £13.69 |
