Your basket is empty
HP Envy 4520 Colour InkJet Multifunction Printer
Quicklinx: BT65WS00 Mfr#: J6U70B#ABU
Do more with an affordable Instant Ink ready HP ENVY all-in-one – the perfect match for your technology. Save up to 70% on ink and enjoy the easiest way to print from your smartphone or tablet. Get wireless printing and lab-quality photos.
HP Envy 4520 All-in-One - multifunction printer (colour)
Multifunction printer
English / United Kingdom
Printing Technology
Ink-jet (colour)
Inkjet Technology
HP Thermal Inkjet - 4-ink
Monthly Duty Cycle (max)
1000 pages
Recommended Monthly Volume
100 - 400 pages
Max Copying Speed
Up to 7.5 ppm (mono) / up to 4 ppm (colour)
Max Copying Resolution
Up to 600 x 300 dpi (mono) / up to 600 x 300 dpi (colour)
Max Printing Speed
Up to 20 ppm (mono) / up to 16 ppm (colour)
Max Printing Resolution
Up to 1200 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
Scanning
1200 x 2400 dpi
Display
2.2"
Original Size
216 x 297 mm (max)
Original Type
Sheets
Media Size
76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, cards, photo paper
Standard Media Capacity
100 sheets
Output Trays Capacity
25 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, Wi-Fi(n)
AirPrint Enabled
Office Machine Features
Scan to e-mail, scan to folder, HP Auto Wireless Connect, Mobile Printing
AC 120/230 V (50/60Hz)
44.5 cm x 36.7 cm x 12.8 cm
5.41 kg
Environmental Standards
ENERGY STAR Qualified
1 year warranty
Printing Technology
Ink-jet - colour
1000 pages
100 - 400 pages
Display Diagonal Size
2.2"
Display Features
Touch screen
USB 2.0, Wi-Fi(n)
AirPrint Enabled
Standard Memory
64 MB
Max Supported Memory
64 MB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
50
Copying Features
ID Card Copy
Printing
Inkjet Technology
HP Thermal Inkjet
Nozzle Configuration
328 nozzles (black), 588 nozzles (cyan, magenta, yellow)
Max Printing Speed
Ink Cartridge Configuration
1 pigment black cartridge, 1 colour cartridge (cyan, magenta, yellow)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, pigment black
4-ink
Printer Drivers / Emulations
PCL 3 GUI
Automatic Duplexing
First Print Out Time B/W
18 sec
First Print Out Time Colour
20 sec
Colour Management Features
ColorLok Technology
Scanning
Scan Element
CIS
Optical Resolution
1200 x 2400 dpi
Interpolated Resolution
2400 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Document & Media Handling
Max Original Size
216 x 297 mm
Original Type
Sheets
Min Media Size
76 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
64 g/m²
Max Media Weight
300 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 101.6 x 152.4 mm, 76 x 127 mm, 127 x 177.8 mm, 203.2 x 254 mm
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm)
Borderless Photo Sizes
A4 (210 x 297 mm), 216 x 297 mm
100 sheets
25 sheets
Input tray - 100 sheets size: 76 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 64 g/m² - 300 g/m² , Output tray - 25 sheets
Speed Details
Printing: up to 20 ppm (A4) - B/W draft , Printing: up to 20 ppm (Letter A) - B/W draft , Printing: up to 9.5 ppm - B/W (ISO) , Printing: up to 16 ppm (Letter A) - B/W draft , Printing: up to 6.8 ppm - colour (ISO) , Printing: up to 16 ppm (A4) - colour draft , Copying: up to 7.5 ppm - B/W (ISO) , Copying: up to 4 ppm - colour (ISO) , Scanning: up to 4 ppm (A4) - colour normal , Scanning: up to 8 ppm (A4) - B/W normal , Printing: 51 sec (10 x 15 cm (4"x6")) - photo normal
1 x USB 2.0 - 4 pin USB Type B
Security Protocols & Features
Wi-Fi Direct
Operating System Support
MS Windows Vista, Apple Mac OS X 10.8, Windows RT, Apple Mac OS X 10.9, Android 4.0.3, MS Windows 7 (32/64 bits), iOS 7.0 or later, Apple Mac OS X 10.10, MS Windows XP 32-bit Edition SP3 or later, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10 (32/64-bits), Blackberry, Windows 10 Mobile, Chrome OS
Software Included
Drivers & Utilities, HP Photo Creations, HP Update
15 Watt
Power Consumption Standby
3.05 Watt
Power Consumption Sleep
0.55 Watt
Phone cable
Consumables Included
1 x Cartridge (pigmented black) - up to 190 pages - HP 302 , 1 x Cartridge (colour (dye-based cyan, dye-based magenta, dye-based yellow)) - up to 165 pages - HP 302
PSB, UL 60950-1 Second Edition, BSMI CNS 13438, Green Dot, EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, EAC, EN 60950-1:2006+A11:2009+A1:2010+A12:2011, EN 62479:2010, EMC 2004/108/EC, LVD 2006/95/EC, EN55022:2006, CISPR 24:2010, EN55022:2010 Class B, EN 55024:2010, EN 301 489-1 V1.9.2:2011, EN 301 489-17 V2.2.1:2012, CISPR 22:2008, CAN/CSA C22.2 No. 60950-1-07+A11:2011, IEC 60950-1:2005 + A1:2009, EN 62311:2008, FCC Part 15 Class B, IEC 62479:2010, ICES-003 issue 5, VCCI V-3/2013.04, KKC certified, IEC 62311:2007, AS/NZS 60950-1:2011
ENERGY STAR Certified
Limited warranty - 1 year , Technical support - web support - 1 year
44.5 cm
36.7 cm
12.8 cm
5.41 kg
Shipping Width
48.5 cm
Shipping Depth
16.8 cm
Shipping Height
44.5 cm
Shipping Weight
6.45 kg
Sound Emission
51 dBA (operating)
5 °C
20 - 80% (non-condensing)
