The HP ENVY 32 Media Display is a mind-blowing Quad HD monitor that elevates all your work and entertainment to new limits. With wide-angle viewing, brilliant imagery, modern streamlined design, and broad port connectivity, immerse yourself into a unique blend of advanced display with media functionality.
Stunning views
A 81.28 cm (32") diagonal wide-viewing angle screen makes it easy to take in all 3.6 million pixels of this Quad HD display. Wow. Is there anything more to say? -
An exceptionally rich audio experience
State-of-the-art Audio by Bang & Olufsen transforms your PC into a soundstage where entertainment comes alive to awaken your senses with sound you can feel. Designed for true audio perfection on a display. -
Upscaled connectivity
Connect a wide range of devices like tablets and phones through MHL, HDMI, USB 2.0 or DisplayPort, with optimized upscaling for flawless mobile streaming. -
No stuttering
Put an end to choppy gameplay and broken frames with AMD FreeSync . Now you can enjoy fluid performance at virtually any frame rate.
- HP ENVY 32 Media Display - LED monitor - 32"
- LED-backlit LCD monitor - 32"
- Energy Class
- Class A
- Energy Consumption per Year
- 60 kWh
- Power Consumption (On mode)
- 41 W
- Adaptive-Sync Technology
- AMD FreeSync
- USB 2.0 hub
- Aspect Ratio
- 16:9
- Native Resolution
- QHD 2560 x 1440 at 60 Hz
- Pixel Pitch
- 0.276 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 3000:1 / 10000000:1 (dynamic)
- Response Time
- 7 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- 2xHDMI, DisplayPort, MHL
- Tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- White, jack black, natural silver
- 86.16 cm x 17.89 cm x 52.2 cm
- 10.7 kg
- Localisation
- English / United Kingdom
- Plug and Play, VCCI, BSMI, NOM, TUV S, CB, CCC, FCC, ISO 9241-307, KCC, ICES, CECP, CEL, EPA, ISC, SEPA
- 1-year warranty
- Display Type
- Energy Class
- Class A
- 60 kWh
- Diagonal Size
- 32"
- AMD FreeSync
- Built-in Devices
- USB 2.0 hub
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.276 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 60 Hz
- Horizontal Refresh Rate
- 90 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- HDCP, anti-glare, Mercury free, arsenic-free glass, Bang & Olufsen audio
- 86.16 cm x 17.89 cm x 52.2 cm - with stand
- 10.7 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 6 Watt
- MHL (HDCP) , 2 x HDMI (HDCP) , DisplayPort (HDCP) , Audio line-out , 2 x USB 2.0 downstream , USB 2.0 upstream
Mechanical
- Tilt
- Tilt Angle
- -5/+25
- Wall mountable
- Included Accessories
- Wall mount
- Cables Included
- 1 x USB cable - 1.8 m , 1 x DisplayPort cable - 1.8 m , 1 x HDMI cable - 1.8 m
- Localisation
- Input Voltage
- 41 W
- Power Consumption (Typical)
- 50 Watt
- Power Consumption Stand by
- 1 Watt
- Power Consumption Sleep
- 0.5 Watt
- Included Software
- HP Display Assistant
- Dimensions & Weight Details
- Without stand - width: 86.16 cm - depth: 5.82 cm - height: 43.36 cm - weight: 9 kg , With stand - width: 86.16 cm - depth: 17.89 cm - height: 52.2 cm - weight: 10.7 kg
- Limited warranty - 1 year
- 5 °C
- 35 °C
- 20 - 70% (non-condensing)
