HP Envy 13-D008Na Intel Core i5-6200U 8GB 256GB SSD 13.3" Windows 10 Home 64-bit
Quicklinx: BTJ3WS00 Mfr#: P0R94EA#ABU
  • Core i5
  • Bluetooth 4.0
  • IEEE 802.11n
For an ultra-thin, ultra-portable notebook, the HP Envy has you covered. You’ll enjoy a sleek and professional design with all the power you need for reliable performance every time.
Weighing just 1.36kg and measuring 32.65cm x 22.6cm x 1.29cm, the HP Envy 13 is ideal for work on the go. It also comes with speedy 802.11ac wireless technology and Bluetooth 4.0 allowing for fast web browsing and data transfer wherever you are.
This HP Envy laptop comes with a powerful 6th Gen Intel Core processor, as well as 8GB DDR3L memory and a super-speedy 256GB solid state drive – so you’ll have plenty of room for storing large files without it affecting speed and performance.
Enjoy up to 10 hours’ battery life so you can work all day long, unplugged, without losing power – handy if you’ve forgotten your charger cable.
Plus, with its Full HD 13.3-inch display, you’ll benefit from crystal clear image quality as well as anti-glare features.
For enhanced security, take advantage of the security lock slot and power-on password features.
  • Windows 10 Home
    Windows 10 Home is here. Do great things confidently with the familiar feel of Windows - only better.
  • Sleek design
    Easily take this thin and light PC from room to room or on the road. Take it anywhere and look sharp.
  • Bang & Olufsen with dual speakers
    Dual-speakers with Audio by Bang & Olufsen transforms your PC into a soundstage where entertainment comes alive with sound you can feel. Designed for true audio perfection on a PC.
  • Solid-State Drive
    Meet the lightning-fast drive that can keep up with your every demand. Load your apps fast with quick and efficient Solid-State Drives.
  • 6th generation Intel processors
    Faster, quieter, and with more features, the 6th generation of Intel Core processors enhances your computing experience like never before.
  • Backlit keyboard
    Keep going even in dimly lit rooms or aboard red-eye flights. With an illuminated keyboard, you can type comfortably in more environments.
HP ENVY Laptop 13-d008na - 13.3" - Intel Core i5 - 6200U - 8 GB RAM - 256 GB SSD - UK
Notebook
Operating System
Win 10 Home 64-bit - English
Intel Core i5 (6th Gen) - 6200U / 2.3 GHz, up to 2.8 GHz / 3 MB Cache
8 GB DDR3L (provided memory is soldered)
Storage
256 GB SSD
Display
13.3" WLED 1920 x 1080 / Full HD
Graphics
Intel HD Graphics 520
Input Device
Imagepad
Keyboard
Keyboard Backlight
Integrated Webcam
Bluetooth 4.0, 802.11a/b/g/n/ac
3-cell - up to 10 hours
Security
Trusted Platform Module (TPM) Security Chip, fingerprint reader
Natural silver, aluminium (cover)
32.65 cm x 22.6 cm x 1.29 cm
1.36 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 1 year - pick-up and return
Notebook
Operating System
Windows 10 Home 64-bit Edition - English
Processor / Chipset
CPU
Intel Core i5 (6th Gen) 6200U / 2.3 GHz
Max Turbo Speed
2.8 GHz
Number of Cores
Dual-Core
Cache
3 MB
64-bit Computing
RAM
8 GB (provided memory is soldered)
DDR3L SDRAM
Storage
Main Storage
256 GB SSD M.2
Display
13.3" - IPS
LCD Backlight Technology
WLED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Full HD anti-glare
Audio & Video
Graphics Processor
Camera
Yes - HD
Camera Features
HP TrueVision HD
Sound
Stereo speakers, stereo microphone
Audio Features
Output: Bang & Olufsen Audio
Input
Keyboard, imagepad
Keyboard Backlight
Keyboard Layout
Multi-touch touchpad
Communications
Wireless
Miracast
3-cell lithium polymer
45 Wh
Run Time
Up to 10 hours
AC Adapter
Output
45 Watt
Connections & Expansion
HDMI , Headphone/microphone combo jack , 3 x USB 3.0
Memory Card Reader
Yes (SD Card)
Software
Software Included
Skype, EverNote, Netflix, HP SimplePass, McAfee LiveSafe (30 days trial), HP Connected Drive, Dropbox (25 GB Cloud Storage) (free for 6 months), HP Lounge
Security
Security lock slot (cable lock sold separately), power-on password, HP USB Boost
Power adapter
Localization
1.36 kg
Sustainability Information
ENERGY STAR Certified
