HP ElitePad 40W A/C Adapter
Quicklinx: BKSVWS00 Mfr#: H5W93AA#ABU
Be productive throughout the day and keep an extra adapter on hand with the lightweight and versatile HP 40W Smart AC Adapter, which can power the HP ElitePad Docking Station, select HP Notebooks or the HP ElitePad (when connected to the optional HP Smart AC Cable).
HP Smart AC Adapter - power adapter - 40 Watt
Power adapter - external
245 g
English / United Kingdom
Output Voltage
9.5 V
Power Capacity
40 Watt
9.3 cm x 4 cm x 3 cm
ElitePad 1000 G2, 900 G1
Frequency Required
47 - 63 Hz
Output Voltage
9.5 V
Power Capacity
40 Watt
UL, BSMI, cUL, GS, NOM, CCC, PSB, PSE Mark, S Mark, KC
5 °C
35 °C
9.3 cm
4 cm
3 cm
245 g
HP ElitePad 1000 G2, 900 G1
