Keep the pace in and out of the office with the HP ElitePad 1000 Rugged Tablet, a Windows tablet solution designed to go wherever you go and do whatever you do-throughout the day.
Fearless durability
Use the durable solution wherever you need it. It's designed to be cleaned and pass IP 65 for water and dust and MIL-STD 810G testing. -
Mobile productivity that works as hard as you do
Power through your shift with up to 20 hours battery life and use the 2D barcode reader (select configurations) to quickly access information such as inventory data. -
Security from the start
Make the solution part of your secure IT environment with an integrated smart card reader with FIPS-140-2 encryption and IPS-201 certification, HP Client Security and HP BIOS Protection solutions, and full disk encryption. -
Expand what you can do
Create the best solution for your environment with a suite of optional accessories. Use the tablet pen to enable data input when you're out in the field or a docking station to create a desktop-like environment when you're back in the office.
- HP ElitePad 1000 G2 - Rugged - 10.1" - Intel Atom - Z3795 - 4 GB RAM - 128 GB eMMC
- Product Type
- Tablet - no keyboard - rugged
- Operating System
- Win 8.1 Pro 64-bit - English
- Processor
- Intel Atom Z3795 / 1.59 GHz, up to 2.39 GHz / 2 MB Cache
- Memory
- 4 GB LPDDR3
- Storage
- 128 GB eMMC
- Display
- 10.1" LED backlight touchscreen 1920 x 1200 / WUXGA
- Graphics
- Intel HD Graphics
- Input Device
- Digitizer
- Integrated Webcam
- Networking
- 802.11a/b/g/n, Bluetooth 4.0, NFC
- Battery
- 2-cell - up to 13 hours
- Ambient light sensor
- Dockable
- Security
- Trusted Platform Module (TPM 1.2) Security Chip
- 26.1 cm x 17.8 cm x 0.92 cm
- 680 g
- Localisation
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 1 year , Limited warranty - battery - 1 year
- Product Type
- Operating System
- Windows 8.1 Pro 64-bit Edition - English
Processor / Chipset
- CPU
- Max Turbo Speed
- 2.39 GHz
- Number of Cores
- Quad-Core
- Cache
- L2 - 2 MB
- 64-bit Computing
- Intel Burst Technology
- RAM
- 4 GB
- Technology
- LPDDR3 SDRAM
- Speed
- 1067 MHz
Storage
- Main Storage
- 128 GB eMMC
Display
- 10.1"
- LCD Backlight Technology
- LED backlight
- Touchscreen
- Yes (multi-touch)
- Resolution
- 1920 x 1200 (WUXGA)
- Widescreen
- Image Aspect Ratio
- 16:10
- Anti-smudge, Corning Gorilla glass 3
Audio & Video
- Graphics Processor
- Intel HD Graphics
- Camera
- Resolution
- 8 Megapixel (rear), 2.1 Megapixel (front)
- Camera Features
- LED flash
- Sound
- Stereo speakers, two microphones
- High Definition Audio, DTS SOUND+
Input
- Digitizer
Communications
- Wireless
- Bluetooth Class
- Class 2
- Wireless Controller
- Broadcom BCM43241
- IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED
- Technology
- 2-cell lithium polymer
- Capacity
- 30 Wh
- Run Time
- Up to 13 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 10 Watt, 9 V, 1.1 A
Connections & Expansion
- Headphone/microphone combo jack , Dock
- Memory Card Reader
- Yes (microSDXC)
Software
- Software Included
- HP SoftPaq Download Manager, HP Support Assistant, HP ePrint, HP Setup, PDF Complete Corporate Edition, Netflix, HP Wallpaper, Password Manager, Amazon Kindle, Windows Defender, HP Registration, HP Client Security, HP Mobile Connect, Device Access Manager with Just In Time Authentication, HP PageLift, Absolute Data Protection (4 years subscription), Box.net 50GB storage, HP Trust Circles Standard, HP Manageability, HP UEFI System Diagnostics, HP Wireless Hotspot, HP Software Setup, T-Mobile Malwarebytes Anti-Exploit (MBAE)
- Case Material
- Aluminum
- Integrated Options
- Dockable
- Security
- Digital compass, Accelerometer, gyroscope, Haptics
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter, HP ElitePad USB Adapter
- CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FCC, RoHS, WEEE, A-Tick, ICES, ISO 7779, KC, CIT
- Localization
- 680 g
Sustainability Information
- ENERGY STAR Certified
- 0 °C
- 35 °C
- 10 - 90% (non-condensing)
- Shock Tolerance (operating)
- 40 g @ 2 ms half-sine pulse
- Shock Tolerance (non-operating)
- 200 g @ 2 ms half-sine pulse
- Vibration Tolerance (operating)
- 0.75 g @ RMS (random)
- Vibration Tolerance (non-operating)
- 1.5 g @ RMS (random)
