HP ElitePad 1000 G2 Intel Atom Z3795 4GB 128GB SSD 10.1" Windows 8.1 Professional 64-bit
Quicklinx: BFFYWS00 Mfr#: J6T92AW#ABU
  • Atom
  • Windows 8.1 Pro 64-bit Edition
  • IEEE 802.11n
More than a tablet-a total business solution. The elegant and sleek HP ElitePad 1000 G2 has the performance and flexibility to transform the way you work. Redefine productivity and stay light with the confidence of the leading manageability, security, and support you expect from HP.
  • Sleek and elegant
    High quality design delivers one of the thinnest tablets in the industry at 9.2mm thin. The HP ElitePad 1000 G2 Tablet feels light at just 680 g (1.5 lbs.) but it's built to last.Enjoy wider viewing angles on the outdoor viewable 25,65 cm (10.1") diagonal WUXGA multi-touch panel.
  • Powerful productivity
    Take the next step in productivity with the HP ElitePad 1000 G2 Tablet equipped with a 64-bit Intel processor and the features you need to stay productive in the office or on the go.Control wireless connection, including optional worldwide 4G LTE, with HP Connection Manager.Dual cameras help you collaborate or capture the moment.Work the way that suits you best. The ElitePad 1000 G2 supports touch, pen or voice-based input.
  • IT ready
    Easily incorporate the HP ElitePad 1000 G2 Tablet into your IT environment and simplify your workload with optional solutions from HP, LANDesk and Microsoft.Enjoy enterprise-class setup and take the headache away from IT with HP Custom Integration Services.
  • Security from the start
    Stay up and running. HP BIOS Protection offers enhanced protection against virus attacks to the BIOS and other security threats, and is designed to help prevent data loss and reduce downtime.Prevent data from being copied to USB devices without permission using HP Device Access Manager with Just in Time Authentication.
  • Customize it
    Expand what you can do with a suite of accessories-smart jackets, battery, adapters, docking station, covers, cases, and more-designed specifically for the HP ElitePad and turn a true business tablet into a total business solution.Simplify logins and prevent unauthorized access to data on your device or private network with an HP ElitePad Security Jacket.
HP ElitePad 1000 G2 - 10.1" - Atom Z3795 - 4 GB RAM - 128 GB eMMC
Tablet - no keyboard
Operating System
Win 8.1 Pro 64-bit
Intel Atom Z3795 / 1.59 GHz (2.39 GHz) / 2 MB Cache
4 GB LPDDR3
Storage
128 GB - eMMC
Display
10.1" LED backlight touchscreen 1920 x 1200 / WUXGA
Graphics
Intel HD Graphics
Input Device
Digitizer
Integrated Webcam
802.11a/b/g/n, Bluetooth 4.0 LE
Wireless Broadband (WWAN)
3G
Service Provider
Service not included
2-cell
Ambient light sensor
Dockable
Security
Trusted Platform Module (TPM 1.2) Security Chip
26.1 cm x 17.8 cm x 0.92 cm
680 g
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 1 year , Limited warranty - battery - 1 year
Recommended Use
Small business, corporate business
Operating System
Processor / Chipset
CPU
Max Turbo Speed
2.39 GHz
Number of Cores
Quad-Core
Cache
L2 - 2 MB
Intel Burst Technology
RAM
4 GB
LPDDR3 SDRAM
Speed
1067 MHz
Storage
Main Storage
128 GB SSD - (eMMC)
Display
10.1"
LCD Backlight Technology
LED backlight
Touchscreen
Yes (multi-touch)
Resolution
1920 x 1200 (WUXGA)
Widescreen
Image Aspect Ratio
16:10
Anti-smudge, Corning Gorilla glass 3
Audio & Video
Graphics Processor
Intel HD Graphics
Camera
Resolution
8 Megapixel (rear), 2.1 Megapixel (front)
Video Resolutions
1920 x 1080
Camera Features
LED flash
Sound
Stereo speakers, stereo microphone
DTS SOUND+
Input
Digitizer
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Broadcom BCM43241
Gobi Technology
Wi-Fi CERTIFIED
Generation
3G
GPRS, UMTS, EDGE, CDMA 2000 1X EV-DO Rev. A, WCDMA, DC-HSPA+
Controller
HP hs3110 - M.2 Card
Max Transfer Rate
21.6 Mbps
Service Provider
2-cell lithium polymer
30 Wh
AC Adapter
Input
Output
10 Watt
Connections & Expansion
Headphone/microphone combo jack , Dock
Memory Card Reader
Yes (microSDXC)
Software
Software Included
HP SoftPaq Download Manager, HP Support Assistant, HP ePrint, HP Setup, PDF Complete Corporate Edition, Absolute Data Protect, Netflix, HP Wallpaper, Amazon Kindle, HP Registration, HP Client Security, HP Mobile Connect, Device Access Manager with Just In Time Authentication, HP PageLift, Box.net 50GB storage, Drive Encryption, HP Trust Circles Standard, HP Manageability, HP Wireless Hotspot
Case Material
Aluminum
Integrated Options
Dockable
Security
Digital compass, Accelerometer, gyroscope, Haptics
Power adapter, HP ElitePad USB Adapter
CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FCC, WEEE, A-Tick, ICES, KC
Localization
680 g
ENERGY STAR Certified
35 °C
10 - 90% (non-condensing)
Shock Tolerance
40 g @ 2ms half-sine pulse (operating) / 200 g @ 2ms half-sine pulse (non-operating)
Vibration Tolerance
0.75 g @ RMS (random) (operating) / 1.5 g @ RMS (random) (non-operating)
