More than a tablet-a total business solution. The elegant and sleek HP ElitePad 1000 G2 has the performance and flexibility to transform the way you work. Redefine productivity and stay light with the confidence of the leading manageability, security, and support you expect from HP.
Sleek and elegant
High quality design delivers one of the thinnest tablets in the industry at 9.2mm thin. The HP ElitePad 1000 G2 Tablet feels light at just 680 g (1.5 lbs.) but it's built to last.Enjoy wider viewing angles on the outdoor viewable 25,65 cm (10.1") diagonal WUXGA multi-touch panel. -
Powerful productivity
Take the next step in productivity with the HP ElitePad 1000 G2 Tablet equipped with a 64-bit Intel processor and the features you need to stay productive in the office or on the go.Control wireless connection, including optional worldwide 4G LTE, with HP Connection Manager.Dual cameras help you collaborate or capture the moment.Work the way that suits you best. The ElitePad 1000 G2 supports touch, pen or voice-based input. -
IT ready
Easily incorporate the HP ElitePad 1000 G2 Tablet into your IT environment and simplify your workload with optional solutions from HP, LANDesk and Microsoft.Enjoy enterprise-class setup and take the headache away from IT with HP Custom Integration Services. -
Security from the start
Stay up and running. HP BIOS Protection offers enhanced protection against virus attacks to the BIOS and other security threats, and is designed to help prevent data loss and reduce downtime.Prevent data from being copied to USB devices without permission using HP Device Access Manager with Just in Time Authentication. -
Customize it
Expand what you can do with a suite of accessories-smart jackets, battery, adapters, docking station, covers, cases, and more-designed specifically for the HP ElitePad and turn a true business tablet into a total business solution.Simplify logins and prevent unauthorized access to data on your device or private network with an HP ElitePad Security Jacket.
- HP ElitePad 1000 G2 - 10.1" - Intel Atom - Z3795 - 4 GB RAM - 128 GB eMMC - 3G
- Product Type
- Tablet - no keyboard
- Operating System
- Win 8.1 Pro 64-bit
- Processor
- Intel Atom Z3795 / 1.59 GHz, up to 2.39 GHz / 2 MB Cache
- Memory
- 4 GB LPDDR3
- Storage
- 128 GB eMMC
- Display
- 10.1" LED backlight touchscreen 1920 x 1200 / WUXGA
- Graphics
- Intel HD Graphics
- Input Device
- Digitizer
- Integrated Webcam
- Networking
- 802.11a/b/g/n, Bluetooth 4.0, NFC
- Wireless Broadband (WWAN)
- 3G
- Battery
- 2-cell
- Ambient light sensor, proximity sensor
- Security
- Trusted Platform Module (TPM 1.2) Security Chip
- 26.1 cm x 17.8 cm x 0.92 cm
- 680 g
- Localisation
- Limited warranty - parts and labour - 1 year
- Product Type
- Recommended Use
- Small business, corporate business
- Operating System
- Windows 8.1 Pro 64-bit Edition
Processor / Chipset
- CPU
- Max Turbo Speed
- 2.39 GHz
- Number of Cores
- Quad-Core
- Cache
- L2 - 2 MB
- Intel Burst Technology
- RAM
- 4 GB
- Technology
- LPDDR3 SDRAM
- Speed
- 1067 MHz
Storage
- Main Storage
- 128 GB eMMC
Display
- 10.1"
- LCD Backlight Technology
- LED backlight
- Touchscreen
- Yes (multi-touch)
- Resolution
- 1920 x 1200 (WUXGA)
- Widescreen
- Image Aspect Ratio
- 16:10
- Anti-smudge, Corning Gorilla glass 3
Audio & Video
- Graphics Processor
- Intel HD Graphics
- Camera
- Resolution
- 8 Megapixel (rear), 2.1 Megapixel (front)
- Video Resolutions
- 1920 x 1080
- Camera Features
- LED flash
- Sound
- Stereo speakers, stereo microphone
- DTS SOUND+
Input
- Digitizer
Communications
- Wireless
- Bluetooth Class
- Class 2
- Wi-Fi CERTIFIED
- Generation
- 3G
- Technology
- HSPA+
- Controller
- HP hs3110
- Technology
- 2-cell lithium polymer
- Capacity
- 30 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
Connections & Expansion
- Headphone/microphone combo jack
- Memory Card Reader
- Yes (microSDHC)
- Case Material
- Aluminum
- Integrated Options
- Security
- Digital compass, Accelerometer, HP BIOS Protection, gyroscope
- Included Accessories
- Power adapter
- CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FCC, WEEE, A-Tick, ICES, KC
- Localization
- 680 g
- 0 °C
- 35 °C
- 10 - 90% (non-condensing)
- Shock Tolerance
- 40 g @ 2ms half-sine pulse (operating) / 200 g @ 2ms half-sine pulse (non-operating)
- Vibration Tolerance
- 0.75 g @ RMS (random) (operating) / 1.5 g @ RMS (random) (non-operating)
