HP ElitePad 1000 G2 Intel Atom Z3795 4GB 128GB 10.1" Windows 8.1 Professional 64-bit
Quicklinx: BKSPWS00 Mfr#: H9X28EA#ABU
  • Atom
  • Windows 8.1 Pro 64-bit Edition
  • Bluetooth 4.0
  • IEEE 802.11n
More than a tablet-a total business solution. The elegant and sleek HP ElitePad 1000 G2 has the performance and flexibility to transform the way you work. Redefine productivity and stay light with the confidence of the leading manageability, security, and support you expect from HP.
  • Sleek and elegant
    High quality design delivers one of the thinnest tablets in the industry at 9.2mm thin. The HP ElitePad 1000 G2 Tablet feels light at just 680 g (1.5 lbs.) but it's built to last.Enjoy wider viewing angles on the outdoor viewable 25,65 cm (10.1") diagonal WUXGA multi-touch panel.
  • Powerful productivity
    Take the next step in productivity with the HP ElitePad 1000 G2 Tablet equipped with a 64-bit Intel processor and the features you need to stay productive in the office or on the go.Control wireless connection, including optional worldwide 4G LTE, with HP Connection Manager.Dual cameras help you collaborate or capture the moment.Work the way that suits you best. The ElitePad 1000 G2 supports touch, pen or voice-based input.
  • IT ready
    Easily incorporate the HP ElitePad 1000 G2 Tablet into your IT environment and simplify your workload with optional solutions from HP, LANDesk and Microsoft.Enjoy enterprise-class setup and take the headache away from IT with HP Custom Integration Services.
  • Security from the start
    Stay up and running. HP BIOS Protection offers enhanced protection against virus attacks to the BIOS and other security threats, and is designed to help prevent data loss and reduce downtime.Prevent data from being copied to USB devices without permission using HP Device Access Manager with Just in Time Authentication.
  • Customize it
    Expand what you can do with a suite of accessories-smart jackets, battery, adapters, docking station, covers, cases, and more-designed specifically for the HP ElitePad and turn a true business tablet into a total business solution.Simplify logins and prevent unauthorized access to data on your device or private network with an HP ElitePad Security Jacket.
HP ElitePad 1000 G2 - 10.1" - Intel Atom - Z3795 - 4 GB RAM - 128 GB eMMC - 4G LTE
Tablet - no keyboard
Operating System
Win 8.1 Pro 64-bit - English
Intel Atom Z3795 / 1.59 GHz, up to 2.39 GHz / 2 MB Cache
4 GB LPDDR3
Storage
128 GB eMMC
Display
10.1" LED backlight touchscreen 1920 x 1200 / WUXGA
Graphics
Intel HD Graphics
Input Device
Digitizer
Integrated Webcam
802.11a/b/g/n, Bluetooth 4.0, NFC
Wireless Broadband (WWAN)
4G LTE
Service Provider
HP Mobile Connect
2-cell - up to 13 hours
Ambient light sensor
Dockable
Security
Trusted Platform Module (TPM 1.2) Security Chip
26.1 cm x 17.8 cm x 0.92 cm
680 g
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 1 year , Limited warranty - battery - 1 year
Operating System
Windows 8.1 Pro 64-bit Edition - English
Processor / Chipset
CPU
Max Turbo Speed
2.39 GHz
Number of Cores
Quad-Core
Cache
L2 - 2 MB
64-bit Computing
Intel Burst Technology
RAM
4 GB
LPDDR3 SDRAM
Speed
1067 MHz
Storage
Main Storage
128 GB eMMC
Display
10.1"
LCD Backlight Technology
LED backlight
Touchscreen
Yes (multi-touch)
Resolution
1920 x 1200 (WUXGA)
Widescreen
Image Aspect Ratio
16:10
Image Brightness
400 cd/m²
BrightView, ultra wide viewing angle, Direct Bonding technology, anti-smudge, Corning Gorilla glass 3, auto-rotation
Audio & Video
Graphics Processor
Intel HD Graphics
Camera
Yes - 1080p
Resolution
8 Megapixel (rear), 2.1 Megapixel (front)
Camera Features
LED flash, rear camera with flash
Sound
Stereo speakers, two microphones
High Definition Audio
Input
Digitizer
Multi-touch digitiser
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Broadcom BCM43241
Gobi Technology, Miracast
IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED
Generation
4G
GPRS, EDGE, CDMA 2000 1X EV-DO Rev. A, LTE, DC-HSPA+
Controller
HP lt4112 - M.2 Card
Max Transfer Rate
100 Mbps
Service Provider
HP Mobile Connect
Navigation
Receiver
GPS/GLONASS
2-cell lithium polymer
30 Wh
Run Time
Up to 13 hours
AC Adapter
Input
Output
45 Watt
Connections & Expansion
Slots
1 x Micro-SIM card (1 free)
Headphone/microphone combo jack , Dock , USB (on supplied cable)
Software
Software Included
HP SoftPaq Download Manager, HP Support Assistant, HP SoftPaq Download Manager (free download), HP ePrint, HP Setup, PDF Complete Corporate Edition, Netflix, Intel Wireless Display, HP Wallpaper, Password Manager, Amazon Kindle, Windows Defender, HP Registration, HP Client Security, HP Mobile Connect, Device Access Manager with Just In Time Authentication, HP Systems Software Manager (free download), HP PageLift, Absolute Data Protection (4 years subscription), Box.net 50GB storage, HP Trust Circles Standard, HP Manageability, HP UEFI System Diagnostics, HP Wireless Hotspot, HP Software Setup, HP Client Management Interface (free download), HP BIOS Configuration Utility (free download), T-Mobile Malwarebytes Anti-Exploit (MBAE)
Case Material
Aluminum
Integrated Options
Dockable
Security
Digital compass, Accelerometer, gyroscope, Haptics, microphone with noise-cancellation
Power adapter, HP ElitePad USB Adapter, HP 4.5mm DC Dongle for AC Adapter, HP Rugged Shoulder Strap
CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FCC, RoHS, MIL-STD 810G, WEEE, A-Tick, ICES, ISO 7779, KC, CIT
Localization
680 g
Sustainability Information
ENERGY STAR Certified
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
