Modernize any workspace with an AiO PC that makes a great first impression. The HP EliteOne AiO delivers serious performance, engaging collaboration, multi-faceted security, and purposeful manageability in a stunning and sleek 23.8-inch diagonal micro-edge bezel design.
Let nothing stand in your way
Power through your day with Windows 10 Pro with built-in security, collaboration, and connectivity. -
Firmware level protection
Protect the firmware that antivirus can't reach! The hardware-enforced self-healing protection offered by HP Sure Start Gen4 automatically recovers the BIOS from malware, rootkits, or corruption. -
Protect critical security processes
Keep your critical applications and processes running even if malware tries to shut them down with self-healing protection. -
Browse confidently
Help protect your PC from websites, attachments, malware, ransomware, and viruses with hardware-enforced security from HP Sure Click. -
Quick and secure recovery to the latest image
Quickly and securely restore PCs to the latest image using a network connection with HP Sure Recover. -
Get PC images right the first time
Improve the quality and security of custom Windows images with HP Image Assistant Gen3 which assists ITDMs with image creation, identifies problems, and provides recommendations and remediation.
- HP EliteOne 800 G4 - all-in-one - Core i5 8500 3 GHz - vPro - 16 GB - SSD 512 GB - LED 23.8" - UK
- Personal computer - all-in-one
- Platform Technology
- Intel vPro Platform
- Localisation
- Processor
- Intel Core i5 (8th Gen) 8500 / 3 GHz (4.1 GHz) (6-core)
- Processor Main Features
- Hyper-Threading Technology, Intel Turbo Boost Technology 2
- Cache Memory
- 9 MB
- Cache Per Processor
- 9 MB
- RAM
- 16 GB (installed) / 32 GB (max) - DDR4 SDRAM - PC4-21333
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- SSD 512 GB - PCI Express - M.2 2280 - NVM Express (NVMe)
- Optical Storage
- DVD-Writer
- Monitor
- 23.8" - LED - 1920 x 1080 (Full HD) - 16:9
- Graphics Controller
- Intel UHD Graphics 630
- Camera
- Audio Output
- Stereo
- Networking
- GigE, 802.11a, 802.11b/g/n, Wi-Fi 5, Bluetooth 5.0
- Keyboard
- UK
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Windows 10 Pro 64-bit Edition
- 53.96 cm x 5.38 cm x 34.179 cm
- 6.13 kg
- Limited warranty - parts and labour - 3 years - on-site
- Personal computer
- Product Form Factor
- All-in-one
- Built-in Devices
- Speaker
- Embedded Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 3 GHz
- Max Turbo Speed
- 4.1 GHz
- Number of Cores
- 6-core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- Chipset Type
- Intel Q370
Cache Memory
- Installed Size
- 9 MB
- 9 MB
RAM
- Installed Size
- 16 GB / 32 GB (max)
- Technology
- DDR4 SDRAM
- Effective Memory Speed
- 2666 MHz
- Rated Memory Speed
- 2666 MHz
- Memory Specification Compliance
- PC4-21333
- Form Factor
- SO-DIMM 260-pin
- Slots
- 2 (Total) / 1 (empty)
- Configuration Features
- 1 x 16 GB
Hard Drive
- SSD - M.2 2280
- Capacity
- 1 x 512 GB
- Interface Type
- PCI Express
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
Optical Storage
- DVD-Writer
Monitor
- Monitor Type
- LED - IPS
- Diagonal Size
- 23.8"
- Native Resolution
- Widescreen Display
- Image Aspect Ratio
- 16:9
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Colour Gamut
- 72%
- Pixel Pitch
- 0.2745 mm
- Image Brightness
- 250 cd/m²
- Image Contrast Ratio
- 1000:1
- Monitor Features
- Anti-glare
Graphics Controller
- Graphics Processor
- Video Interfaces
- HDMI, DisplayPort
- HDCP Compatible
- Max Monitors Supported
- 3
Audio Output
- Sound Output Mode
- Stereo
- Max Sampling Rate
- 192 kHz
- Speakers
- Bang & Olufsen sound bar
- Speakers Included
- 2 x right / left channel
Camera
- Camera
Input Device
- Mouse, keyboard
Keyboard
- Keyboard Name
- HP Business Slim Keyboard
- Connectivity
- Wireless
- Localization & Layout
- UK
Mouse
- Connectivity
- Wireless
Audio Input
- Dual array microphone
- Ethernet Controller
- Intel I219-LM
- Wireless LAN Supported
- Wireless NIC
- Intel Wireless-AC 9560
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 5.0
- Remote Management Protocol
- SNMP 2
- Wake on LAN (WoL), auto-uplink (auto MDI/MDI-X)
- IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.3x, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.3az, IEEE 802.11ac, Bluetooth 5.0
- Bays
- 1 (total) / 1 (free) x external 5.25" Slim Line
- Slots
- 1 (total) / 0 (free) x M.2 Card - 2230 , 1 (total) / 0 (free) x M.2 Card - 2230/2280
- 2 x USB 3.1 Gen 2 (one of them is fast-charging) , 2 x USB 3.1 Gen 1 , 2 x USB 3.1 Gen 2 (wake functionality) , 1 x USB-C 3.1 Gen 2 , 1 x LAN (Gigabit Ethernet) , 1 x DisplayPort , 1 x HDMI , 1 x audio line-out , 1 x headphones , 1 x headphones/microphone
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- VESA Mounting Interface
- 100 x 100 mm
- ACPI, CCC, RoHS, WEEE, CECP, SEPA, low halogen
- Power supply
- Voltage Required
- Power Provided
- 180 Watt
- Efficiency
- 90%
- Power Factor Correction
- Yes (active)
Operating System / Software
- OS Provided
- Windows 10 Pro 64-bit Edition English
- Dimensions & Weight Details
- 53.96 cm - 5.38 cm - 34.179 cm - 6.13 kg - without stand
- 53.96 cm
- 5.38 cm
- 34.179 cm
- 6.13 kg
- Shipping Width
- 69 cm
- Shipping Depth
- 25.6 cm
- Shipping Height
- 54.5 cm
- Shipping Weight
- 9.5 kg
- 5 °C
- 45 °C
- 5 - 90%
