Elegant, sleek, user-friendly, and designed to perform, the HP EliteOne 800 is ready to deploy in demanding environments, with manageability and security, enterprise-class collaboration technologies, and touchscreen configurations.
Place it here, there, and everywhere
Deploy this redesigned, stylish All-in-One with a 58.4 cm (23") diagonal FHD display anywhere you need a powerhouse PC. Its slim design and integrated cable management make an impression at reception, on an executive’s desk or mounted on a wall.
Deeply secure
Help secure your PC with comprehensive hardware and software tools like an optional fingerprint reader and HP BIOSphere with Sure Start’s customizable BIOS-level passwords.
Power-packed performance
Drive your most demanding workloads with an All-in-One powered by fast 6th Gen Intel® Core™ processors, plus AMD Radeon™ R9 360 discrete graphics with 2 GB GDDR5 for your most challenging use cases.
Count on premier audiovisual clarity
Collaborate naturally with Cortana on Windows 10 Pro, optional 10-point capacitive touch, Audio by Bang & Olufsen, HP Clear Sound Amp, HP Noise Reduction Software, and a 2MP HD webcam.
Featuring
Let nothing stand in your way
Help protect from today’s security threats and maximize management and productivity features for business with Window 10 Pro.
Ready to run, and upgrade
Make expansion and upgrades a snap with a tool-less rear access panel.
World-class management
Simplify IT manageability with Intel® vPro™8 and Windows 101 plus HP Common Core BIOS, which enables easy management of your entire fleet of HP devices.
Tested to go the distance
Rest easy with a PC that passed 120,000 hours of testing and is designed to undergo MIL-STD 810G9 testing.
Consistently stagger deployments
Get the same HP configuration across the globe, available in more than 180 countries where HP conducts business.
Make your workspace more workable
Make more room with optional, versatile stands or a space-saving VESA wall mount10 for a range of use cases.
Fast easy login
Save time and help eliminate the need for cumbersome complicated passwords by using the integrated fingerprint reader.
Windows 10 Pro 64
Help protect from today's security threats and maximize management and productivity features for business with Window 10 Pro. -
Make expansion and upgrades a snap with a tool-less rear access panel. -
Simplify IT manageability with Intel vPro and Windows 10 plus HP Common Core BIOS, which enables easy management of your entire fleet of HP devices. -
Rest easy with a PC that passed 120,000 hours of testing and is designed to undergo MIL-STD 810G testing. -
Get the same HP configuration across the globe, available in more than 180 countries where HP conducts business. -
Make more room with optional, versatile stands or a space-saving VESA wall mount for a range of use cases.
- HP EliteOne 800 G2 - all-in-one - Core i5 6500 3.2 GHz - vPro - 8 GB - Hybrid Drive 1 TB - LED 23"
- Personal computer - all-in-one - administrator password, power-on password, hard drive I/O control, USB port control, adjustable height, Intel Identity Protection Technology (Intel IPT), HP BIOS Protection, Setup Password, UEFI BIOS, HP DriveLock, Master Record Security, Power On Authentication, 1 USB 3.0 fast charging port, 1 USB-C fast charging port
- Platform Technology
- Intel vPro Platform
- Localisation
- Processor
- Intel Core i5 (6th Gen) 6500 / 3.2 GHz (3.6 GHz) (Quad-Core)
- Processor Main Features
- Intel Turbo Boost Technology 2
- Cache Memory
- 6 MB
- Cache Per Processor
- 6 MB
- RAM
- 8 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC - PC4-17000
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- Hybrid Drive 1 TB (8 GB cache) - SATA 6Gb/s - 7200 rpm
- Optical Storage
- DVD SuperMulti
- Monitor
- 23" - LED - 1920 x 1080 (Full HD) - 16:9 - touchscreen
- Graphics Controller
- Intel HD Graphics 530 Dynamic Video Memory Technology
- Audio Output
- Stereo
- Networking
- GigE, 802.11a, 802.11b/g/n, Bluetooth 4.0
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Windows 10 Pro 64-bit Edition
- 56.72 cm x 28 cm x 43.5 cm
- 10.76 kg
- Environmental Standards
- ENERGY STAR Qualified
- Personal computer
- Product Form Factor
- All-in-one
- Embedded Security
- Trusted Platform Module (TPM 1.2) Security Chip
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 3.2 GHz
- Max Turbo Speed
- 3.6 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- Chipset Type
- Intel Q170
Cache Memory
- Installed Size
- 6 MB
- 6 MB
RAM
- Installed Size
- 8 GB / 32 GB (max)
- Technology
- Effective Memory Speed
- 2133 MHz
- Rated Memory Speed
- 2133 MHz
- Memory Specification Compliance
- PC4-17000
- Form Factor
- SO-DIMM 260-pin
- Slots
- 2 (Total) / 1 (empty)
- Unbuffered, dual channel memory architecture
- Configuration Features
- 1 x 8 GB
Hard Drive
- Hybrid Drive
- Capacity
- 1 x 1 TB (8 GB cache)
- Interface Type
- SATA 6Gb/s
- Spindle Speed
- 7200 rpm
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
Optical Storage
- DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Monitor
- Monitor Type
- LED - IPS
- Touchscreen
- Yes (10-point multi-touch)
- Diagonal Size
- 23"
- Native Resolution
- Widescreen Display
- Image Aspect Ratio
- 16:9
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Colour Gamut
- 72%
- Pixel Pitch
- 0.265 mm
- Image Brightness
- 225 cd/m²
- Image Contrast Ratio
- 1000:1
- Monitor Features
- Projected Capacitive Touch (PCT) technology
Graphics Controller
- Graphics Processor
- Video Interfaces
- DisplayPort
- HDCP Compatible
- Max Monitors Supported
- 3
Audio Output
- Sound Output Mode
- Stereo
- Max Sampling Rate
- 192 kHz
- High Definition Audio
- Speakers Included
- 2 x right / left channel
Input Device
- Mouse
Mouse
- Interface
- USB
- Ethernet Controller
- Intel I219-LM
- Wireless LAN Supported
- Wireless NIC
- Broadcom BCM943228Z
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.0
- IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.3az, Bluetooth 4.0
- Bays
- 1 (total) / 0 (free) x external 5.25" Slim Line , 2 (total) / 1 (free) x internal 2.5"
- Slots
- 1 (total) / 0 (free) x CPU , 1 (total) / 0 (free) x M.2 Card (x1 mode) , 2 (total) / 1 (free) x SO-DIMM 260-pin , 1 (total) / 1 (free) x M.2 Card (x4 mode)
- 6 x USB 3.0 , 1 x DisplayPort , 1 x audio line-in/headphones/microphone , 1 x audio line-out/headphones , 1 x audio line-out , 1 x LAN (Gigabit Ethernet) , 1 x USB-C 3.0
- Administrator password, power-on password, hard drive I/O control, USB port control, adjustable height, Intel Identity Protection Technology (Intel IPT), HP BIOS Protection, Setup Password, UEFI BIOS, HP DriveLock, Master Record Security, Power On Authentication, 1 USB 3.0 fast charging port, 1 USB-C fast charging port
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- VESA Mounting Interface
- 100 x 100 mm
- ACPI, CCC, CECP, SEPA
- Power supply
- Voltage Required
- Power Factor Correction
- Yes (active)
Operating System / Software
- OS Provided
- Windows 10 Pro 64-bit Edition English
- Software
- CyberLink Power2Go, HP Recovery Disc Creator, Skype, Microsoft Security Essentials, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, CyberLink PowerDVD BD Edition, Foxit PhantomPDF Express, Windows Defender, HP Secure Erase, HP Client Security Manager
- ENERGY STAR Certified
- 56.72 cm
- 28 cm
- 43.5 cm
- 10.76 kg
- 10 °C
- 35 °C
- 10 - 90% (non-condensing)
