Let nothing stand in your way
Super-charge your HP PC with Windows 10 Pro, an 8th gen Intel Core processor, optional discrete graphics, and Intel Optane memory, a smart, adaptable system accelerator that helps improve responsiveness on hard drive-based systems. -
Choose from three optional display sizes
Pick the right display to suit your needs. Choose from a touch or non-touch 23.8-inch diagonal, 27-inch diagonal non-touch UHD IPS, and a 34-inch diagonal non-touch WQHD curved display for an immersive and engaging visual experience. -
The adaptable all-in-one
With core computing components like 8th Gen Intel Core processors and a Thunderbolt 3 connection located in the base of these serviceable AiOs, you can upgrade or redeploy displays as user and business needs change over time. -
Give your speakers a boost
HP Audio Boost balances loudness and clarity and enhances bass for improved speech quality. -
Cut out the chatter
Suppress background noise including keyboard clicks with HP Noise Cancellation. -
Browse confidently
Help protect your PC from websites, read only Microsoft Office and PDF attachments, malware, ransomware, and viruses with hardware-enforced security from HP Sure Click.
- HP EliteOne 1000 G2 - all-in-one - Core i5 8500 3 GHz - 8 GB - SSD 256 GB - LED 23.8" - UK
- Personal computer - all-in-one
- Localisation
- Processor
- Intel Core i5 (8th Gen) 8500 / 3 GHz (4.1 GHz) (6-core)
- Processor Main Features
- Hyper-Threading Technology, Intel Turbo Boost Technology 2
- Cache Memory
- 9 MB
- Cache Per Processor
- 9 MB
- RAM
- 8 GB (installed) / 32 GB (max) - DDR4 SDRAM
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- SSD 256 GB - PCI Express - M.2 2280 - NVM Express (NVMe)
- Optical Storage
- No optical drive
- Monitor
- 23.8" - LED - 1920 x 1080 (Full HD) - 16:9
- Graphics Controller
- Intel UHD Graphics 630
- Camera
- Audio Output
- Stereo
- Networking
- GigE, 802.11a, 802.11b/g/n, Wi-Fi 5, Bluetooth 5.0
- Keyboard
- UK
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Windows 10 Pro 64-bit Edition
- 53.95 cm x 19 cm x 41.92 cm
- 8.21 kg
- Limited warranty - parts and labour - 3 years
- Personal computer
- Product Form Factor
- All-in-one
- Built-in Devices
- Fingerprint reader
- Embedded Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 3 GHz
- Max Turbo Speed
- 4.1 GHz
- Number of Cores
- 6-core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- Chipset Type
- Intel Q370
Cache Memory
- Installed Size
- 9 MB
- 9 MB
RAM
- Installed Size
- 8 GB / 32 GB (max)
- Technology
- DDR4 SDRAM
- Effective Memory Speed
- 2666 MHz
- Rated Memory Speed
- 2666 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots
- 2 (Total) / 1 (empty)
- Configuration Features
- 1 x 8 GB
Hard Drive
- SSD - M.2 2280
- Capacity
- 1 x 256 GB
- Interface Type
- PCI Express
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
Optical Storage
- No optical drive
Monitor
- Monitor Type
- LED - IPS
- Diagonal Size
- 23.8"
- Native Resolution
- Widescreen Display
- Image Aspect Ratio
- 16:9
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Pixel Pitch
- 0.2745 mm
- Image Brightness
- 250 cd/m²
- Monitor Features
- Full HD anti-glare
Graphics Controller
- Graphics Processor
- Video Interfaces
- HDMI, DisplayPort
- HDCP Compatible
Audio Output
- Sound Output Mode
- Stereo
- Max Sampling Rate
- 192 kHz
- High Definition Audio
- Speakers Included
- 2 x right / left channel
Camera
- Camera
- Resolution (MP)
- 2 Megapixel (rear), 2 Megapixel (front)
- Resolution
- Full HD
- IR camera, Windows Hello
Input Device
- Mouse, keyboard
Keyboard
- Keyboard Name
- HP Premium
- Connectivity
- Wireless
- Localization & Layout
- UK
Mouse
- Connectivity
- Wireless
Audio Input
- Dual array microphone
- Interface (Bus) Type
- PCI Express Mini Card (M.2)
- Ethernet Controller
- Intel I219-LM
- Wireless LAN Supported
- Wireless NIC
- Intel Wireless-AC 9560
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 5.0
- IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, IEEE 802.11n, IEEE 802.3az, IEEE 802.11ac, Bluetooth 5.0
- Bays
- 1 (total) / 1 (free) x internal 2.5"
- Slots
- 1 (total) / 0 (free) x M.2 Card - 2230 , 1 (total) / 0 (free) x M.2 Card - 2280
- 4 x USB 3.1 Gen 2 (4 rear) , 1 x DisplayPort input , 1 x DisplayPort output , 1 x HDMI output , 1 x LAN (Gigabit Ethernet) , 1 x Thunderbolt 3/DisplayPort/USB-C 3.1 Gen 2 , 1 x headphones/microphone , 1 x USB 3.1 Gen 1 (fast-charging)
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Low halogen
- Power adapter
- Voltage Required
- Power Provided
- 180 Watt
- Efficiency
- 87%
- Power Factor Correction
- Yes (active)
Operating System / Software
- OS Provided
- Windows 10 Pro 64-bit Edition English
- Dimensions & Weight Details
- 53.95 cm - 19 cm - 41.92 cm - 8.21 kg - with base , 40 cm - 19 cm - 3.7 cm - base , 53.95 cm - 3.3 cm - 32.49 cm - 5.19 kg - without base
- 53.95 cm
- 19 cm
- 41.92 cm
- 8.21 kg
- Shipping Weight
- 12.42 kg
- 10 °C
- 35 °C
- 10 - 90% (non-condensing)
Warranties (7)
HP 3 Year NBD On-Site Optional Customer Self Repair Desktop/Workstation Only Hardware Service | In Stock | £33.26 |
HP Care Pack Next Business Day HW Support Post Warranty Extended Service Agreement 1 Year On-Site | In Stock | £14.86 |
HP Care Pack Next Business Day Hardware Support Extended Service Agreement 5 Years On-Site | In Stock | £50.54 |
HP Care Pack NBD Hardware Support with Disk Retention Extended Service Agreement 3 Years On-Site | In Stock | £33.69 |
HP Care Pack NBD HW Support w/ Defective Media Retention Extended Service Agreement 4 Years On-Site | In Stock | £41.17 |
HP Care Pack NBD Hardware Support with Disk Retention Extended Service Agreement 5 Years On-Site | In Stock | £70.47 |
HP Care Pack Next Business Day HW Support Extended Service Agreement 4 Year On-Site - Desktop Only | In Stock | £25.34 |
Monitors (2)
HP DreamColour 31.1" 4096x2160 10ms 2xHDMI 2xDisplayPort USB-C LED Monitor | In Stock | £2,821.06 |
HP E 24" G4 WUXGA 1920 x 1200 LED Backlit Monitor | In Stock | £150.00 |
Other bundles (2)
HPE DisplayPort To VGA Adapter | In Stock | £13.72 |
HPE DisplayPort DVI-D Adapter | In Stock | £13.23 |
