Meetings come to life on your choice of AiO displays that transform your workspace into a rich video conferencing solution with immersive video and audio engagement, capacitive touch controls, and a built-in pop-up privacy camera.
Personal video conferencing on demand
Save time and launch video calls quickly with integrated collaboration keys. Complete the experience with captivating video and audio engagement with Audio by Bang & Olufsen and an optional FHD dual-facing webcam. -
Stay ahead of the curve
Configurable and flexible, our first AiO with an upgradeable PC base and display for flexible re-deployment-meet the AiO designed to reinvent the lifecycle of your PC. -
Our most secure and manageable PCs
Deploy first-class protection with commercial security and manageability features like HP Sure Start Gen3 and HP Manageability Integration Kit. Get automatic threat detection and system recovery, plus remotely manage your PC security with real-time updates.
- HP EliteOne 1000 G1 - all-in-one - Core i7 7700 3.6 GHz - 8 GB - 256 GB - LED 27"
- Personal computer - all-in-one
- Localisation
- Processor
- Intel Core i7 (7th Gen) 7700 / 3.6 GHz (4.2 GHz) (Quad-Core)
- Processor Socket
- LGA1151 Socket
- Processor Main Features
- Hyper-Threading Technology, Intel Turbo Boost Technology 2, Intel Smart Cache
- Cache Memory
- 8 MB
- Cache Per Processor
- 8 MB
- RAM
- 8 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- 1 x SSD 256 GB - PCI Express - M.2 2280 - NVM Express (NVMe)
- Optical Storage
- No optical drive
- Monitor
- 27" - LED - 3840 x 2160 (Ultra HD 4K) - 16:9
- Graphics Controller
- Intel HD Graphics 630
- Camera
- Audio Output
- Stereo
- Networking
- GigE
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Windows 10 Pro 64-bit Edition
- 61.33 cm x 19 cm x 45.73 cm
- 10.2 kg
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 3 years
- Personal computer
- Product Form Factor
- All-in-one
- Built-in Devices
- Fingerprint reader
- Embedded Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Localisation
Processor / Chipset
- CPU
- Max Turbo Speed
- 4.2 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- CPU Socket
- LGA1151 Socket
- Chipset Type
- Intel Q270
Cache Memory
- Installed Size
- 8 MB
- 8 MB
RAM
- Installed Size
- 8 GB / 32 GB (max)
- Technology
- Effective Memory Speed
- 2400 MHz
- Rated Memory Speed
- 2400 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots
- 2 (Total) / 1 (empty)
- Unbuffered, dual channel memory architecture
- Configuration Features
- 1 x 8 GB
Hard Drive
- SSD - M.2 2280
- Capacity
- 1 x 256 GB
- Interface Type
- PCI Express
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
Optical Storage
- No optical drive
Monitor
- Monitor Type
- LED - IPS
- Diagonal Size
- 27"
- Native Resolution
- Widescreen Display
- Image Aspect Ratio
- 16:9
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Pixel Pitch
- 0.1554 mm
- Image Brightness
- 350 cd/m²
- Image Contrast Ratio
- 1000:1
- Monitor Features
- 99% sRGB colour gamut, Ultra HD 4K anti-glare
Graphics Controller
- Graphics Processor
- Video Interfaces
- HDMI, DisplayPort
Audio Output
- Sound Output Mode
- Stereo
- Max Sampling Rate
- 192 kHz
- High Definition Audio
- Speakers Included
- 2 x right / left channel
Camera
- Camera
- Resolution (MP)
- 2 Megapixel (rear), 2 Megapixel (front)
- Resolution
- Full HD
- IR camera, Windows Hello
Audio Input
- Dual array microphone
- Ethernet Controller
- Intel I219-LM
- Data Link Protocol
- Bays
- 1 (total) / 1 (free) x internal 2.5" x 1/8H
- Slots
- 1 (total) / 1 (free) x M.2 Card - 2230 , 1 (total) / 0 (free) x M.2 Card - 2280
- 5 x USB 3.1 Gen 1 (two of them with wake functionality, one of them is charging) , 1 x DisplayPort input , 1 x DisplayPort output , 1 x HDMI output , 1 x LAN (Gigabit Ethernet) , 1 x headphones , 1 x USB 3.1 - Type C
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Power adapter
- Nominal Voltage
- Power Provided
- 180 Watt
- Efficiency
- 87%
- Power Factor Correction
- Yes (active)
Operating System / Software
- OS Provided
- Windows 10 Pro 64-bit Edition English
- ENERGY STAR Certified
- 61.33 cm
- 19 cm
- 45.73 cm
- 10.2 kg
- 10 °C
- 50 °C
- 10 - 95% (non-condensing)
