Meetings come to life on your choice of AiO displays that transform your workspace into a rich video conferencing solution with immersive video and audio engagement, capacitive touch controls, and a built-in pop-up privacy camera.
Let nothing stand in your way
Super-charge your HP PC with Windows 10 Pro and a 7th Gen Intel Core processor with optional Intel Optane memory. -
Choose from three optional display sizes
Pick the right display to suit your needs. Choose from a touch or non-touch 23.8-inch diagonal, 27-inch diagonal non-touch, and a 34-inch diagonal non-touch curved display for an immersive and engaging visual experience. -
The adaptable all-in-one
With core computing components like 7th Gen Intel Core i3/i5/i7 processors located in the base of our most serviceable AiO, you can upgrade or redeploy displays as user and business needs change over time. -
Give your speakers a boost
HP Audio Boost balances loudness and clarity, and enhances bass for improved speech quality. -
Cut out the chatter
Suppress background noise including keyboard clicks with HP Noise Cancellation. -
Browse confidently
HP Sure Click provides hardware-enforced security for web browsers, protecting your PC from websites infected with malware, ransomware or viruses.
- HP EliteOne 1000 G1 - all-in-one - Core i7 7700 3.6 GHz - 8 GB - SSD 256 GB - LED 27"
- Personal computer - all-in-one
- Localisation
- Processor
- Intel Core i7 (7th Gen) 7700 / 3.6 GHz (, up to 4.2 GHz, (Quad-Core)
- Processor Socket
- LGA1151 Socket
- Processor Main Features
- Hyper-Threading Technology, Intel Turbo Boost Technology 2, Intel Smart Cache
- Cache Memory
- 8 MB
- Cache Per Processor
- 8 MB
- RAM
- 8 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- SSD 256 GB - PCI Express - M.2 2280 - NVM Express (NVMe)
- Optical Storage
- No optical drive
- Monitor
- 27" - LED - 3840 x 2160 (Ultra HD 4K) - 16:9
- Graphics Controller
- Intel HD Graphics 630
- Camera
- Audio Output
- Stereo
- Networking
- 1GbE
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Windows 10 Pro 64-bit Edition
- 61.33 cm x 19 cm x 45.73 cm
- 10.2 kg
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 3 years
- Personal computer
- Product Form Factor
- All-in-one
- Built-in Devices
- Fingerprint reader
- Embedded Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 3.6 GHz
- Max Turbo Speed
- 4.2 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- CPU Socket
- LGA1151 Socket
- Chipset Type
- Intel Q270
Cache Memory
- Installed Size
- 8 MB
- 8 MB
RAM
- Installed Size
- 8 GB / 32 GB (max)
- Technology
- Effective Memory Speed
- 2400 MHz
- Rated Memory Speed
- 2400 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots
- 2 (Total) / 1 (empty)
- Unbuffered, dual channel memory architecture
- Configuration Features
- 1 x 8 GB
Hard Drive
- SSD - M.2 2280
- Capacity
- 1 x 256 GB
- Interface Type
- PCI Express
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
Optical Storage
- No optical drive
Monitor
- Monitor Type
- LED - IPS
- Diagonal Size
- 27"
- Native Resolution
- Widescreen Display
- Image Aspect Ratio
- 16:9
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Colour Gamut
- 99% sRGB
- Pixel Pitch
- 0.1554 mm
- Image Brightness
- 350 cd/m²
- Image Contrast Ratio
- 1000:1
- Monitor Features
- Ultra HD 4K anti-glare, 99% sRGB colour gamut
Graphics Controller
- Graphics Processor
- Video Interfaces
- HDMI, DisplayPort
Audio Output
- Sound Output Mode
- Stereo
- Max Sampling Rate
- 192 kHz
- High Definition Audio
- Speakers Included
- 2 x right / left channel
Camera
- Camera
- Resolution (MP)
- 2 Megapixel (rear), 2 Megapixel (front)
- Resolution
- Full HD
- IR camera, Windows Hello
Audio Input
- Dual array microphone
- Ethernet Controller
- Intel I219-LM
- Data Link Protocol
- Bays
- 1 (total) / 1 (free) x internal 2.5" x 1/8H
- Slots
- 1 (total) / 1 (free) x M.2 Card - 2230 , 1 (total) / 0 (free) x M.2 Card - 2280
- 5 x USB 3.1 Gen 1 (two of them with wake functionality, one of them is charging) , 1 x DisplayPort input , 1 x DisplayPort output , 1 x HDMI output , 1 x LAN (Gigabit Ethernet) , 1 x headphones , 1 x USB 3.1 - Type C
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Power adapter
- Voltage Required
- Power Provided
- 180 Watt
- Efficiency
- 87%
- Power Factor Correction
- Yes (active)
Operating System / Software
- OS Provided
- Windows 10 Pro 64-bit Edition English
Sustainability Information
- ENERGY STAR Certified
- 61.33 cm
- 19 cm
- 45.73 cm
- 10.2 kg
- 10 °C
- 50 °C
- 10 - 95% (non-condensing)
HP Care Pack Next Business Day HW Support Post Warranty Extended Service Agreement 1 Year On-Site | In Stock | £14.86 |
HPE DisplayPort To VGA Adapter | In Stock | £13.72 |
HP DreamColour 31.1" 4096x2160 10ms 2xHDMI 2xDisplayPort USB-C LED Monitor | In Stock | £2,821.06 |
