HP EliteDisplay S270n 27" 3840x2160 5.4ms HDMI DisplayPort IPS LED Monitor
Quicklinx: FBRMWS00 Mfr#: 2PD37AT#ABU
Diagonal Size: 27in
Max Resolution: 3840 x 2160
Response Time: 5.4ms
Speakers: None
Interfaces: DisplayPort, HDMI, Mobile High-Definition Link (MHL), USB-C
26 in stock
£409.66 ex VAT
£491.59 inc VAT
Strike envy across the office with the elegance of the UHD HP EliteDisplay S270n 4K Micro Edge Monitor. It delivers style and simplicity with a modern 3-sided micro-edge bezel and easy single-cable USB-C connectivity to your device.
  • Don't miss a thing
    Put all your creativity and content front and center on a large 68.58 cm (27") diagonal screen with 4K, 3840 x 2160 resolution that reveals every detail and makes every color pop.
  • Clear your clutter
    Maintain a minimalist workspace by pulling video and data from and sending power to your PC, notebook, tablet or phone with just one USB-C cable connection.
  • Wide open spaces
    Prepare for maximum visual impact and optimal productivity with a 3-sided micro-edge bezel that tiles easily for a virtually seamless multi-display experience. Get comfortable with 100-mm height adjustability.
HP EliteDisplay S270n - LED monitor - 4K - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class C
Energy Consumption per Year
64 kWh
Power Consumption (On mode)
44 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160 at 60 Hz
Pixel Pitch
0.1554 mm
Brightness
350 cd/m²
Contrast Ratio
1300:1 / 10000000:1 (dynamic)
Response Time
5.4 ms (grey-to-grey with overdrive)
Colour Support
1.074 billion colours (10-bit)
Input Connectors
2xHDMI, DisplayPort, USB-C
Display Position Adjustments
Height, tilt
Screen Coating
Anti-glare
Black, chrome plated, black onyx (base)
61.35 cm x 18.99 cm x 49.85 cm
English / United Kingdom
Environmental Standards
TCO Certified Displays 7, ENERGY STAR Qualified
Plug and Play, VCCI, BSMI, WHQL, CB, CCC, FCC, RoHS, ISO 9241-307, WEEE, ICES, cTUVus, ERP, CEL Grade 1, RCM, MSIP, CoC, low halogen, CU
Display Type
Energy Class
Class C
64 kWh
44 W
Diagonal Size
27"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.1554 mm
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Response Time
Vertical Refresh Rate
24 - 60 Hz
Horizontal Refresh Rate
27 - 135 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
99% sRGB colour gamut, USB-C power delivery up to 60 W, 3-sided micro-edge
61.35 cm x 18.99 cm x 49.85 cm - with stand
USB-C (DisplayPort 1.2 mode) , 2 x HDMI (HDCP) , DisplayPort (HDCP)
Mechanical
Height, tilt
Tilt Angle
-5/+23
Height Adjustment
100 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), arsenic free
VESA bracket
1 x HDMI cable - 1.8 m , 1 x DisplayPort cable - 1.8 m , 1 x USB-C cable - 1.8 m
Backlight Life
30,000 hours
Security Slot Type
Kensington security slot
55 Watt
Power Consumption Stand by
0.5 Watt
Included Software
HP Display Assistant
Microsoft Windows 7 / 8 / 10
Dimensions & Weight Details
Without stand - width: 61.35 cm - depth: 4 cm - height: 36.25 cm - weight: 4.85 kg , With stand - width: 61.35 cm - depth: 18.99 cm - height: 49.85 cm
Shipping Width
71.5 cm
Shipping Depth
27 cm
Shipping Height
48 cm
Shipping Weight
10.95 kg
ENERGY STAR Certified
TCO Certified
5 °C
35 °C
20 - 80% (non-condensing)
HP EliteDisplay S270n 27 Bundle deal on HP EliteDisplay S270n 27" 3840x2160 5.4ms HDMI DisplayPort IPS LED Monitor
£508.83
Diagonal Size: 27in
Speakers: None
Interfaces: HDMI
Interfaces: Mobile High-Definition Link (MHL)
Interfaces: USB-C
Brand: HP
Price Range Ex VAT: 300 - 500
