HP EliteDisplay S231d 23" 1920x1080 7ms VGA DisplayPort IPS LED Monitor
Quicklinx: BKTYWS00 Mfr#: F3J72AA#ABU
Diagonal Size: 23in
Max Resolution: 1920 x 1080
Response Time: 7ms
Speakers: None
Interfaces: DisplayPort, VGA (HD-15)
  • Windows 8 (32/64 bits)
  • Windows 8.1 (32/64 bits)
£276.67 ex VAT
£332.00 inc VAT
Create an instant workspace with this 58,4 cm (23') IPS LED Backlit Notebook Docking Monitor. With one USB cable connection from your notebook to display, you can access everything you need and get to work. Charge your HP Notebook battery and power your HP Notebook through the display's DC power cable.
  • Full HD IPS is just the beginning
    Get a large-screen 58,4 cm (23') diagonal Full HD IPS panel display that's so much more-it's your gateway to a streamlined, personalized workspace of your pre-selected, pre-arranged, and pre-connected peripherals.
  • Connect and charge
    Boost productivity and lower costs with a display that does double duty as a large format monitor and port replicator that delivers network connectivity, port expansion, and HP Notebook charging-all in one device.
  • Expand your reach, not your wallet
    Eliminate the time and expense of travel and keep the lines of communication open with an integrated 720p HD webcam and dual microphone plus virtual conferencing software so you can meet anywhere, anytime from the comfort of your desk.
HP EliteDisplay S231d - LED monitor - Full HD (1080p) - 23"
LED-backlit LCD monitor - 23"
USB 3.0 hub, 720p webcam
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.265 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
7 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
54.4 cm x 24.24 cm x 46.99 cm
6.12 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
Plug and Play, CSA, VCCI, C-Tick, BSMI, cUL, NOM, TUV S, WHQL, CB, CCC, PSB, FCC, S Mark, TCO Certified Edge, E-Standby, KC, CECP, EAC, CEL Grade 1, ISC
5 years warranty
Display Type
Diagonal Size
23"
Built-in Devices
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.265 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
7 ms (grey-to-grey)
Vertical Refresh Rate
50 - 60 Hz
Horizontal Refresh Rate
24 - 80 kHz
Video Bandwidth
170 MHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
WLED
Colour Temperature
6500K
OSD Languages
Chinese (traditional), Chinese (simplified), Brazilian Portuguese, English, German, French, Italian, Spanish, Japanese
72% colour gamut, On-screen Digital Controls
54.4 cm x 24.24 cm x 46.99 cm - with stand
6.12 kg
DisplayPort , VGA , Headphones , Audio line-in , Network (RJ-45) , 2 x USB 2.0 downstream , 2 x USB 3.0 downstream , USB 3.0 upstream
Mechanical
Tilt Angle
-5/+30
Swivel Angle
360
Height Adjustment
150 mm
Backlight Life
30,000 hours
Power Supply
External
60 Watt
Power Consumption Stand by
2.2 Watt
Microsoft Windows Vista (32/64 bits) SP1, Microsoft Windows Vista (32/64 bits) SP2, Microsoft Windows 7 Professional (32/64 bits), Windows 8 (32/64 bits), Windows 8 Pro (32/64 bits), Windows 8.1 (32/64 bits), Windows 8.1 Pro 64-bit Edition, Windows 8.1 Pro 32-bit Edition
Dimensions & Weight Details
Without stand - width: 54.4 cm - depth: 5.1 cm - height: 32.9 cm - weight: 3.87 kg
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Limited warranty - 5 years - on-site - response time: next business day
5 °C
35 °C
20 - 80% (non-condensing)
HP EliteDisplay S231d 23 Bundle deal on HP EliteDisplay S231d 23" 1920x1080 7ms VGA DisplayPort IPS LED Monitor
£376.43
Diagonal Size: 23in
Response Time: 7ms
Speakers: None
Interfaces: VGA (HD-15)
Brand: HP
Price Range Ex VAT: 150 - 300
