Make the most of your business PC's Windows 8 environment with a fully reclining, multi-touch IPS display that puts productivity at your fingertips and keeps you comfortable throughout the day. Enjoy vibrant Full HDimages on the extra-large 58,4 cm (23') diagonal screen.
Do more
Tap, slide, and swipe your way to greater productivity. This Windows 8-certified multi-touch monitor is plug-and-play ready to support the latest touch-enabled business applications and designed to recline for a more comfortable touch experience. -
Now see everything
Get a great visual experience, even in high ambient light, with the wide 178-degree viewing angles from IPS technology. Take advantage of Full HD resolution, and anti-glare protective glass. -
Meet on a moment's notice
Enjoy an ideal communication experience with a display optimized for business-class collaboration with integrated speakers, webcam, and dual microphones.
- HP EliteDisplay S230tm - LED monitor - Full HD (1080p) - 23"
- LED-backlit LCD monitor - 23"
- Touch screen, 2 microphones, 720p webcam
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.265 mm
- Brightness
- 220 cd/m²
- Contrast Ratio
- 1000:1 / 10000000:1 (dynamic)
- Response Time
- 7 ms (grey-to-grey with overdrive)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72%
- Input Connectors
- DVI-D, DisplayPort
- Speakers
- Integrated
- Tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- Black, silver
- 59.93 cm x 6.95 cm x 40.92 cm
- 6.5 kg
- Localisation
- English / United Kingdom
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified EPEAT Gold
- Plug and Play, CSA, VCCI, C-Tick, BSMI, cUL, NOM, TUV S, WHQL, CB, CCC, PSB, EK, FCC, S Mark, E-Standby, CECP, EAC, CEL Grade 1, ISC
- Display Type
- Diagonal Size
- 23"
- Built-in Devices
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.265 mm
- Brightness
- 220 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 72%
- Response Time
- Vertical Refresh Rate
- 50 - 76 Hz
- Horizontal Refresh Rate
- 24 - 94 kHz
- Video Bandwidth
- 170 MHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- WLED
- Colour Temperature
- 6500K
- OSD Languages
- Chinese (traditional), Chinese (simplified), Brazilian Portuguese, English, German, French, Italian, Spanish, Dutch, Japanese
- HDCP, 5-point multi-touch, touch screen
- Black, silver
- 59.93 cm x 6.95 cm x 40.92 cm - with stand
- 6.5 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 2 Watt
- USB (Type B) , DVI-D (HDCP) , DisplayPort (HDCP) , Headphones
Mechanical
- Tilt
- Tilt Angle
- +15/+70
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), detachable stand
- Cables Included
- 1 x DVI cable - 1.8 m , 1 x DisplayPort cable - 1.8 m , 1 x USB cable - 1.8 m , 1 x audio cable - 1.8 m
- Backlight Life
- 30,000 hours
- Localisation
- Power Supply
- Internal
- Input Voltage
- Power Consumption (Typical)
- 25 Watt
- Power Consumption Stand by
- 0.5 Watt
- Included Software
- HP Display Assistant, HP YouCam
- Dimensions & Weight Details
- Without stand - width: 59.93 cm - depth: 4.05 cm - height: 40.92 cm - weight: 5.5 kg , With stand - width: 59.93 cm - depth: 6.95 cm - height: 40.92 cm - weight: 6.5 kg
Sustainability Information
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
