HP EliteDisplay S140u  LED Monitor 14" 1600 x 900
Quicklinx: CTCWWS00 Mfr#: G8R65AA#AC3
  • Windows 8.1 (32/64 bits)
Create a dual-display mobile workspace almost anywhere with the HP EliteDisplay S140u 35.56 cm (14") USB Portable Monitor, an ultra-compact, strikingly thin, high-resolution display in a wraparound cover. Fold it back to add a second screen for your Windows tablet or notebook and connect with one USB cable.
Sleek, stylish, and ultra-portable.
The super-compact, ultra-thin design weighs 1.44 Kilograms, and is just 1.27 centimeters thick. The cover doubles as an adjustable stand and helps protect the display so you can slide it into your carrying case with your tablet or notebook.
Double your visual workspace.
Pair the 1600 x 900 high-resolution display with a notebook or tablet to extend to a dual-display setup wherever you work, or make a big impression with mirror mode.
Super simple set-up.
Get ready in a snap with the single USB cable that also acts as a power source. Fold back the cover and connect to any USB port on your notebook or tablet and you’re ready to work.
  • Designed with the environment in mind
    Be a better consumer with a display that has environmentally responsible components that include low halogen, arsenic-free glass, and mercury-free backlights.
HP EliteDisplay S140u - LED monitor - 14"
LED-backlit LCD monitor - 14"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
1600 x 900 at 60 Hz
Pixel Pitch
0.1935 mm
Brightness
200 cd/m²
Contrast Ratio
400:1
Response Time
8 ms (grey-to-grey)
Colour Support
262,144 colours
Colour Gamut
72%
Input Connectors
USB
Screen Coating
Anti-glare
34.58 cm x 1.35 cm x 21.71 cm
1.2 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, CSA, UL, VCCI, BSMI, cUL, VESA EDID, CB, CCC, FCC, C-ETL, RoHS, IEC 60950-1, KCC, ICES, S Mark, TUV Bauart, GOST-R 50377-1992, GOST 25861-83, NOM-019-SCFI-1998, ISC, RCM, ISO9241-307
3-year warranty
Display Type
Diagonal Size
14"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
1600 x 900 at 60 Hz
Pixel Pitch
0.1935 mm
Brightness
200 cd/m²
Contrast Ratio
400:1
Colour Support
262,144 colours
Colour Gamut
72%
Response Time
8 ms (grey-to-grey)
Video Bandwidth
108 MHz
Horizontal Viewing Angle
90
Vertical Viewing Angle
50
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Colour Temperature
6500K
Controls & Adjustments
Brightness
On-screen Digital Controls
34.58 cm x 1.35 cm x 21.71 cm - without stand
1.2 kg
USB 3.0
VESA interface support, programmable
1 x micro-USB 3.0 to USB 3.0 / USB 2.0 cable - 1 m
Backlight Life
15,000 hours
Power Consumption (Typical)
7 Watt
Power Consumption Stand by
0.8 Watt
Microsoft Windows 7 Professional (32/64 bits), Windows 8.1 (32/64 bits), Windows 8.1 Pro (32/64 bits)
Dimensions & Weight Details
Without stand - width: 34.58 cm - depth: 1.35 cm - height: 21.71 cm - weight: 1.2 kg , With stand - width: 34.58 cm - depth: 1.6 cm - height: 22.1 cm - weight: 1.49 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - parts and labour - 3 years
5 °C
35 °C
20 - 70% (non-condensing)
