HP EliteDisplay S14 14" 1920x1080 5ms LED Portable Monitor
Quicklinx: DZTTWS00 Mfr#: 3HX46AT#AC3
Diagonal Size: 14in
Max Resolution: 1920 x 1080
Response Time: 5ms
Interfaces: USB-C
More than 50 in stock
£177.78 ex VAT
£213.33 inc VAT
Unfold dual-display productivity anywhere you work-on your own, in groups or at client sites-with the HP EliteDisplay S14 USB Portable Monitor, HP's first portable 35.56 cm (14") USB-C display. Fold back the wraparound easel cover, stand up, and connect to your device with just one USB-C cable.
  • Perfectly portable
    Maximize your productivity and lighten your load with a Full HD display that weighs 1 kg and is less than 9 mm thick, so you can tuck it into your carrying case alongside your device without weighing you down.
  • Easy USB-C efficiency
    Set up quickly with just one USB-C cable that transfers video and pulls power from your notebook or tablet - no power cable required.
  • Customize your settings
    Control brightness, contrast, and response time, and activate HP Low Blue Light mode to filter blue light emission and shift colors to a warmer spectrum for more comfortable viewing, all from the intuitive OSD.
HP EliteDisplay S14 - LED monitor - Full HD (1080p) - 14"
LED-backlit LCD monitor - 14"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.1611 mm
Brightness
200 cd/m²
Contrast Ratio
700:1 / 5000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
262,144 colours
Input Connectors
USB-C
Screen Coating
Anti-glare
Ebony black
32.78 cm x 0.86 cm x 20.95 cm
1 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, CSA, UL, VCCI, BSMI, NOM, TUV S, WHQL, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, ICES, MEPS, KC, CECP, CEL, EAC, ISC, low halogen
Display Type
Diagonal Size
14"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.1611 mm
Pixel Per Inch
157
Brightness
200 cd/m²
Contrast Ratio
Colour Support
262,144 colours
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
60 Hz
Horizontal Refresh Rate
80 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
45% NTSC colour gamut, Mercury free, arsenic-free glass
Ebony black
32.78 cm x 0.86 cm x 20.95 cm - without stand
1 kg
USB-C
1 x USB-C cable - 1.8 m
Backlight Life
15,000 hours
5 Watt
Power Consumption Stand by
0.3 Watt
Included Software
HP Display Assistant
Microsoft Windows 7, Windows 8, Windows 10
Shipping Width
39.4 cm
Shipping Depth
6.3 cm
Shipping Height
28.4 cm
Shipping Weight
1.9 kg
ENERGY STAR Certified
ENERGY STAR Version
7.0
5 °C
35 °C
20 - 80% (non-condensing)
Diagonal Size: 14in
Response Time: 5ms
Interfaces: USB-C
Brand: HP
Price Range Ex VAT: 150 - 300
