Brand
HP EliteDisplay S14 14" 1920x1080 5ms LED Portable Monitor
Quicklinx: DZTTWS00 Mfr#: 3HX46AT#AC3
Diagonal Size: 14in
Max Resolution: 1920 x 1080
Response Time: 5ms
Interfaces: USB-C
£177.78 ex VAT
£213.33 inc VAT
Unfold dual-display productivity anywhere you work-on your own, in groups or at client sites-with the HP EliteDisplay S14 USB Portable Monitor, HP's first portable 35.56 cm (14") USB-C display. Fold back the wraparound easel cover, stand up, and connect to your device with just one USB-C cable.
  • Share-worthy visuals
    Fold back the beautiful cover to reveal the 35.56 cm (14") diagonal IPS glass panel screen on HP's first portable Full HD display. It has 1920 x 1080 resolution, a 16:9 aspect ratio, and fast 5 ms response time-perfect for single and group viewing.
  • Form meets function
    Carry a display that sets a style standard with an aesthetic that complements HP PCs. The smooth, easy-to-carry wraparound case helps protect the display when you're on the go, and is an adjustable easel on a desk or table when you stop to work.
HP EliteDisplay S14 - LED monitor - Full HD (1080p) - 14"
LED-backlit LCD monitor - 14"
Energy Class
Class B
Power Consumption (On mode)
5.4 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.1611 mm
Brightness
200 cd/m²
Contrast Ratio
700:1 / 5000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
262,144 colours
Colour Gamut
45% NTSC
Input Connectors
USB-C
Screen Coating
Anti-glare
Ebony black
32.78 cm x 0.86 cm x 20.95 cm
1 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, CSA, UL, VCCI, BSMI, NOM, TUV S, WHQL, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, ICES, MEPS, KC, CECP, CEL, EAC, ISC, low halogen
Display Type
Energy Class
Class B
Diagonal Size
14"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.1611 mm
Pixel Per Inch
157
Brightness
200 cd/m²
Contrast Ratio
Colour Support
262,144 colours
Colour Gamut
45% NTSC
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
60 Hz
Horizontal Refresh Rate
80 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
Mercury free, arsenic-free glass
Ebony black
32.78 cm x 0.86 cm x 20.95 cm - without stand
1 kg
USB-C
1 x USB-C cable - 1.8 m
Backlight Life
15,000 hours
5.4 W
5.4 kWh/1000h
Power Consumption (Typical)
5 Watt
Power Consumption Stand by
0.3 Watt
Included Software
HP Display Assistant
Microsoft Windows 7, Windows 8, Windows 10
Shipping Width
39.4 cm
Shipping Depth
6.3 cm
Shipping Height
28.4 cm
Shipping Weight
1.9 kg
ENERGY STAR Certified
ENERGY STAR Version
7.0
5 °C
35 °C
20 - 80% (non-condensing)
Diagonal Size: 14in
Response Time: 5ms
Interfaces: USB-C
Brand: HP
