HP EliteDisplay E273q 27" 2560x1440 5ms VGA DVI DisplayPort IPS LED Monitor
Quicklinx: F6W4WS00 Mfr#: 1FH52AA#ABU
Diagonal Size: 27in
Max Resolution: 2560 x 1440
Response Time: 5ms
Speakers: None
Interfaces: DisplayPort, HDMI, VGA (HD-15)
£377.36 ex VAT
£452.83 inc VAT
Style meets substance in the strikingly modern HP EliteDisplay E273q 68.58 cm (27") QHD Monitor, a Quad HD display crafted for optimal viewing, productivity, and ergonomics with a 3-sided micro-edge bezel for seamless multi-display tiling, flexible USB-C connectivity, and 4-way adjustable comfort.
  • A whole world view of all your work
    Bring more of your data to the screen at the same time on a massive 68.58 cm (27") diagonal screen with Quad HD 2560 x 1440 resolution, which supports efficient column and row management in your office software and smoother curves in your images.
  • Drive your productivity to the edge
    Take visual disruptions out of the picture with the display's 3-sided micro-edge bezel, which essentially removes them from your line of sight so you can multi-task to your heart's content across virtually seamless multi-display arrays.
  • Work comfortably
    Find your most comfortable, productive position with adjustable tilt, height, swivel, and up to 150 mm height adjustment settings. Use pivot rotation to customize portrait or landscape views when using multiple displays.
  • Expanded, flexible connectivity
    Keep your workspace clean with video and data connections over a single cable with USB-C . Be ready for multiple generations of products with DisplayPort , HDMI, VGA, and a 2-port USB hub.
HP EliteDisplay E273q - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440 at 60 Hz
Pixel Pitch
0.2331 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
5 ms (On/Off)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Black (rear cover), silver (front bezel, frame and stand)
61.26 cm x 21.4 cm x 52.29 cm
7.4 kg
English / United Kingdom
Environmental Standards
TCO Certified Displays 7, TCO Certified Edge Displays, ENERGY STAR Qualified
Plug and Play, TUV GS, VCCI, BSMI, TUV S, WHQL, CB, CCC, PSB, FCC, ISO 9241-307, WEEE, PSE Mark, cTUVus, MEPS, CECP, CEL, EAC, ISC, RCM, MSIP, CoC, low halogen, ICE, SmartWay
5-year warranty
Display Type
Energy Class
Class B
Diagonal Size
27"
Viewable Size
27"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2331 mm
Pixel Per Inch
108.8
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (On/Off)
Vertical Refresh Rate
50 - 60 Hz
Horizontal Refresh Rate
30 - 90 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
Colour Temperature
6500K
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
HDCP, Frame Rate Control (FRC), Low Blue Light Mode, Flicker Free technology, Mercury free, arsenic-free glass, Micro Edge, 99.6% sRGB colour gamut
61.26 cm x 21.4 cm x 52.29 cm - with stand
7.4 kg
HDMI (HDCP) , DisplayPort (HDCP) , VGA , USB-C upstream (HDCP) , 2 x USB 3.0 downstream (Type A)
Mechanical
Tilt Angle
- 5/+22
Swivel Angle
90
Rotation Angle
180
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), integrated cable management, detachable stand, direct mountable, VESA interface support
1 x HDMI cable - 1.8 m , 1 x DisplayPort cable - 1.8 m , 1 x USB 3.1 Type A to Type C cable - 1.8 m
Backlight Life
30,000 hours
Security Slot Type
Kensington security slot
75 Watt
Power Consumption Stand by
0.5 Watt
On / Off Switch
Included Software
HP Display Assistant
Dimensions & Weight Details
With stand - width: 61.26 cm - depth: 21.4 cm - height: 52.29 cm - weight: 7.4 kg , Without stand - width: 61.26 cm - depth: 4.93 cm - height: 36.4 cm - weight: 4.6 kg
ENERGY STAR Certified
TCO Certified
Limited warranty - 5 years - on-site - response time: next business day
5 °C
35 °C
20 - 80% (non-condensing)
HP EliteDisplay E273q 27 Bundle deal on HP EliteDisplay E273q 27" 2560x1440 5ms VGA DVI DisplayPort IPS LED Monitor
£476.53
Diagonal Size: 27in
Response Time: 5ms
Speakers: None
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: HP
Price Range Ex VAT: 300 - 500
