HP EliteDisplay E273m  27" 1920x1080 5ms HDMI VGA DisplayPortLED Monitor
Quicklinx: F53MWS00 Mfr#: 1FH51AT#ABU
Diagonal Size: 27in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: None
Interfaces: USB-C, DisplayPort, VGA (HD-15), HDMI
£292.30 ex VAT
£350.76 inc VAT
Connect and collaborate in complete comfort on the HP EliteDisplay E273m 68.58 cm (27") Monitor, which is Skype for Business certified for optimal video and audio experiences between displays and has a 3-sided micro-edge bezel for seamless multi-display tiling and 4-way adjustable ergonomics.
  • Advanced communication tools at the touch of a button
    Meet online with colleagues across the hall and around the world on a Skype for Business certified display with an HD webcam, expertly-tuned Audio by Bang & Olufsen, microphone, and collaboration keys to control calls without an onscreen menu.
  • Work comfortably
    Find your most comfortable, productive position with adjustable tilt, height, swivel, and up to 150 mm height adjustment settings. Use pivot rotation to customize portrait or landscape views when using multiple displays.
  • Break the boundaries
    Expand your productivity with uninterrupted views of one screen or many with a 3-sided micro-edge bezel that supports virtually seamless arrays. Get crisp visuals from any angle on the 1920 x 1080 Full HD resolution, 68.58 cm (27") diagonal IPS screen.
HP EliteDisplay E273m - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class F
Energy Consumption per Year
37 kWh
Power Consumption (On mode)
25 W
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
5 ms (On/Off)
Input Connectors
HDMI, VGA, DisplayPort, USB-C
Display Position Adjustments
Screen Coating
Anti-glare, anti-static
61 cm x 21.4 cm x 38.4 cm
7.9 kg
English / United Kingdom
Environmental Standards
TCO Certified Displays 8, ENERGY STAR Qualified
Plug and Play, VCCI, BSMI, TUV S, WHQL, CB, CCC, PSB, FCC, ISO 9241-307, WEEE, cTUVus, MEPS, CECP, CEL, EAC, ISC, MSIP, CoC, low halogen, ICE, SmartWay
3-year warranty
Display Type
Energy Class
Class F
37 kWh
Diagonal Size
27"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
250 cd/m²
Contrast Ratio
Response Time
5 ms (On/Off)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
HDCP, Mercury free, arsenic-free glass, Micro Edge
61 cm x 21.4 cm x 38.4 cm - with stand
7.9 kg
HDMI (HDCP) , DisplayPort (HDCP) , VGA , USB-C upstream , 2 x USB 3.0
Mechanical
Tilt Angle
-5/+22
Swivel Angle
45
Rotation Angle
90
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
Security Slot Type
Kensington security slot
25 W
23 kWh/1000h
Power Consumption (Typical)
32 Watt
Power Consumption Stand by
0.5 Watt
On / Off Switch
Dimensions & Weight Details
With stand - width: 61 cm - depth: 21.4 cm - height: 38.4 cm - weight: 7.9 kg , Without stand - width: 61 cm - depth: 4.75 cm - height: 38.9 cm
TCO Certified
ENERGY STAR Certified
Limited warranty - 3 years
5 °C
35 °C
20 - 80%
Accessories (1)
F53M HP B300 Mounting Bracket In Stock £32.48
Warranties (4)
F53M HP Care Pack Next Business Day Hardware Support Extended Service Agreement 4 Years On-Site In Stock £15.53
F53M HP Care Pack Next Business Day Hardware Support Extended Service Agreement 5 Years On-Site In Stock £30.10
F53M HP Care Pack Next Business Day Hardware Support Extended Service Agreement 1 Year On-Site In Stock £15.64
F53M HP Care Pack Next Business Day Hardware Support Extended Service Agreement 3 Yrs On-Site for Monitor In Stock £6.01
Diagonal Size: 27in
Response Time: 5ms
Speakers: None
Interfaces: USB-C
Interfaces: DisplayPort
Interfaces: VGA (HD-15)
Interfaces: HDMI
Brand: HP
