HP EliteDisplay E273d 27" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor
Quicklinx: FBQMWS00 Mfr#: 5WN63AT#ABU
Diagonal Size: 27in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: None
Interfaces: VGA (HD-15), DisplayPort, USB-C, HDMI
£451.00 ex VAT
£541.20 inc VAT
Streamlined connectivity, big-screen display, cleaner ocean.
Simplify your desk and get room to work with the HP EliteDisplay E273d 27-inch Docking Monitor. Set up your devices and network one time and connect a notebook through USB-C™ or USB-A. Help prevent ocean waste with a display created with the equivalent of more than three plastic water bottles.
  • Create a space for your entire notebook fleet to touch down immediately through USB-C™ or USB-A, access devices and a wired network, and even power your PC through USB-C™.
  • Be a better global citizen with our first display manufactured with ocean-bound plastics to help reduce waterway pollution. We go one step further with 100% fiber recyclable packaging
  • Quickly videoconference with the integrated, high-resolution, pop-up webcam that retracts into the bezel when not in use. Conveniently join web calls by connecting your headset at the display.
  • Expand your view
    Add a second display daisy-chained through your PC's USB-C connection. 3-sided micro-edge bezels ensure a virtually seamless view on one or dual displays.
  • Take your PC off the desk
    Clear your clutter by mounting your HP EliteDesk Mini Desktop PC directly behind the display and powering it through USB-C . Or, lift the whole solution and mount it on a wall or arm.
  • Find your comfort zone
    Work comfortably with adjustable tilt, height, and swivel settings. Use pivot rotation to conveniently customize portrait or landscape views on multiple displays.
  • Adjust your view
    Filter blue light emission and shift colors to a warmer spectrum for more comfortable viewing with HP Low Blue Light mode.
  • Divide and conquer
    Manage your display and make it work for you. HP Display Assistant allows you to quickly resize screen partitions so you can work in separate regions of the screen and helps deter theft by dimming a display that's disconnected without approval.
HP EliteDisplay E273d Docking Monitor - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
720p webcam, dual array microphone, USB 3.1 Gen 1/USB-C hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Input Connectors
HDMI, VGA, DisplayPort, USB-C
Screen Coating
Anti-glare
61.09 cm x 4.63 cm x 36.3 cm
English / United Kingdom
Plug and Play, TUV GS, VCCI, BSMI, NOM, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, MEPS, CEL, EAC, ISC, low halogen, Mercury-free
5-year warranty
Display Type
Diagonal Size
27"
Viewable Size
27"
Built-in Devices
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
250 cd/m²
Contrast Ratio
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
60 Hz
Horizontal Refresh Rate
80 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Bezel Type
Flat front
HDCP, On-screen Digital Controls, arsenic-free glass, DisplayLink Technology
61.09 cm x 4.63 cm x 36.3 cm - without stand
HDMI (HDCP) , USB-C upstream/DisplayPort with Power Delivery , VGA , USB , 4 x USB 3.1 downstream with Battery Charging , Audio line-in/out , Audio line-in , Network (RJ-45) , DisplayPort output
Security lock slot (cable lock sold separately), detachable stand, VESA interface support
1 x USB cable , 1 x USB-C cable
Security Slot Type
Kensington security slot
40 Watt
Power Consumption (Typical)
40 Watt
Power Consumption Stand by
0.5 Watt
Included Software
HP Display Assistant, CyberLink Youcam
Dimensions & Weight Details
With stand - width: 61.09 cm - depth: 21.4 cm - height: 50.85 cm - weight: 7.52 kg
Shipping Width
73.2 cm
Shipping Depth
28.2 cm
Shipping Height
44.6 cm
Limited warranty - parts and labour - 5 years - on-site
5 °C
35 °C
20 - 80% (non-condensing)
FBQM HP Care Pack Next Business Day Hardware Support Extended Service Agreement 4 Years On-Site In Stock £15.53
FBQM HP Care Pack Next Business Day Hardware Support Extended Service Agreement 5 Years On-Site In Stock £30.10
FBQM HP Care Pack Next Business Day Hardware Support Extended Service Agreement 1 Year On-Site In Stock £15.64
FBQM HP Care Pack Next Business Day Hardware Support Extended Service Agreement 3 Yrs On-Site for Monitor In Stock £6.01
Diagonal Size: 27in
Response Time: 5ms
Speakers: None
Interfaces: DisplayPort
Interfaces: USB-C
Interfaces: HDMI
Brand: HP
