A huge screen, customizable comfort, and wide-angle IPS. IPS goes mainstream with the HP EliteDisplay E271i 68,6 cm (27') LED Backlit Monitor, a business-class combination of an extra-large screen, extra-wide viewing angles, and extraordinary comfort.
Now see everything
Get great 178-degree viewing angles and stunning color integrity from In-Plane Switching (IPS) technology that lets you share your screen with everyone in the room. -
Power through your day in comfort
Customizable tilt, height adjustment, swivel, and pivot settings-the most adjustability available on an HP business display-help you find your sweet spot.The display also meets TCO Certified Edge requirements for innovative products at the forefront of environmental and ergonomic stand design. -
Control your environmental impact
Reduce power consumption and help lower your costs with an intelligent, energy-efficient design that is ENERGY STAR qualified and EPEAT Gold registered.The display also includes mercury-free display backlights, low halogen components, and arsenic-free display glass. -
Enhance your view
Get crisp, clear content and video from the high contrast ratio and fast response time. Easily connect devices with convenient VGA, DVI, and DisplayPort inputs and the integrated USB hub. -
Meet your monitor's new best friend
Personalize your workspace with resizable screen partitions and work in documents, spreadsheets, and e-mail in separate regions of the screen-at the same time-with HP Display Assistant software.View open applications on all of your connected displays with the expanded toolbar. Deter theft with a user-designated PIN that deactivates the monitor if it's disconnected from a PC without approval. -
Breathe easy
Rest assured that your IT investment is supported by a standard, 3-year limited warranty. Select optional HP Care Pack Services to extend your protection beyond the standard warranties.
- HP EliteDisplay E271i - LED monitor - Full HD (1080p) - 27" - Smart Buy
- LED-backlit LCD monitor - 27"
- USB 2.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.3114 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 5000000:1 (dynamic)
- Response Time
- 7 ms
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72%
- Input Connectors
- DVI-D, VGA, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- Light grey
- Dimensions (WxDxH) - without stand
- 64.2 cm x 5.22 cm x 38.73 cm
- 4.9 kg
- Localisation
- English / United States
- Manufacturer Selling Program
- HP Smart Buy
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified EPEAT Gold
- Plug and Play, VCCI, BSMI, NOM, TUV S, CB, CCC, PSB, FCC, KCC, KC, CECP, CEL, EPA
- 3-year warranty
- Display Type
- Diagonal Size
- 27"
- Built-in Devices
- USB 2.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.3114 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 72%
- Response Time
- 7 ms
- Vertical Refresh Rate
- 50 - 76 Hz
- Horizontal Refresh Rate
- 24 - 94 kHz
- Video Bandwidth
- 170 MHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- WLED
- Colour Temperature
- 6500K
- Controls & Adjustments
- Brightness, contrast, colour temperature
- HDCP
- Light grey
- 64.2 cm x 5.22 cm x 38.73 cm - without stand
- 4.9 kg
- USB 2.0 upstream (Type B) , 2 x USB 2.0 downstream (Type A) , DVI-D (HDCP) , DisplayPort (HDCP) , VGA (HD-15)
Mechanical
- Tilt Angle
- -5/+30
- Swivel Angle
- 360
- Rotation Angle
- 90
- Height Adjustment
- 150 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable - 1.8 m , 1 x DisplayPort cable - 2 m , 1 x USB cable - 2 m
- Backlight Life
- 30,000 hours
- Localisation
- HP Smart Buy
- Power Supply
- Internal
- Input Voltage
- Power Consumption (Typical)
- 35 Watt
- Power Consumption Stand by
- 0.5 Watt
- Included Software
- HP Display Assistant
- Dimensions & Weight Details
- Without stand - width: 64.2 cm - depth: 5.22 cm - height: 38.73 cm - weight: 4.9 kg , With stand - width: 64.2 cm - depth: 27.85 cm - height: 53.21 cm - weight: 7.7 kg
Sustainability Information
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
- Limited warranty - 3 years
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
