HP EliteDisplay E243p 23.8" 1920x1080 14ms VGA HDMI DisplayPort IPS LED Monitor
Quicklinx: FBQKWS00 Mfr#: 5FT13AA#ABU
Diagonal Size: 23.8in
Max Resolution: 1920 x 1080
Response Time: 14ms
Speakers: None
Interfaces: DisplayPort, HDMI, VGA (HD-15)
£472.22 ex VAT
£566.66 inc VAT
Help protect your onscreen data in an instant with the HP EliteDisplay E243p Sure View Monitor. It's our first 23.8" diagonal display with an integrated privacy screen that's designed to shield sensitive content from prying eyes.
  • Safeguard your screen with one touch
    Instantly create privacy in open workspaces and deter visual hacking with built-in HP Sure View Gen3 technology. No attachments, no replacements, no worries.
  • Designed for functional flexibility
    Experience practical sophistication in a forward-thinking, sleek design that also keeps you comfortable with 4-way adjustability-tilt, pivot, swivel, and up to 150 mm height adjustment.
  • Explore every detail
    Hide your screen from passersby and still get a crisp, clear, 1920 x 1080 FHD resolution view of your content, images, and video. Enjoy the productivity boost of a nearly-seamless, multi-display setup with the 3-sided micro-edge bezel.
HP EliteDisplay E243p - LED monitor - Full HD (1080p) - 23.8"
LED-backlit LCD monitor - 23.8" - HP SureView
Energy Class
Class A+
Energy Consumption per Year
23 kWh
Power Consumption (On mode)
16 W
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Brightness
260 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
14 ms (grey-to-grey)
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, anti-static
53.88 cm x 4.51 cm x 32.19 cm
3.48 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified
Plug and Play, CSA, UL, VCCI, BSMI, NOM, TUV S, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, ICES, MEPS, KC, CECP, CEL, EAC, ISC, SEPA, low halogen
5-year warranty
Display Type
Energy Class
Class A+
23 kWh
16 W
Diagonal Size
23.8"
Viewable Size
23.8"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Brightness
260 cd/m²
Contrast Ratio
Response Time
Vertical Refresh Rate
60 Hz
Horizontal Refresh Rate
80 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Privacy Technology
HP SureView
HDCP, Full HD BrightView, Mercury free, arsenic-free glass
53.88 cm x 4.51 cm x 32.19 cm - without stand
3.48 kg
HDMI (HDCP) , DisplayPort (HDCP) , VGA , USB 3.0 upstream (Type B) , 2 x USB 3.0 downstream (Type A)
Mechanical
Tilt Angle
-5/+22
Swivel Angle
45
Rotation Angle
90
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
1 x VGA cable , 1 x DisplayPort cable , 1 x HDMI cable
Security Slot Type
Kensington security slot
40 Watt
Power Consumption Stand by
0.5 Watt
Included Software
HP Display Assistant
Dimensions & Weight Details
With stand - width: 53.88 cm - depth: 20.5 cm - height: 46.3 cm - weight: 5.8 kg , Without stand - width: 53.88 cm - depth: 4.51 cm - height: 32.19 cm - weight: 3.48 kg
Shipping Width
64.5 cm
Shipping Depth
28.5 cm
Shipping Height
42 cm
Shipping Weight
9.8 kg
ENERGY STAR Certified
Limited warranty - parts and labour - 5 years - on-site
5 °C
35 °C
20 - 80% (non-condensing)
Response Time: 14ms
Speakers: None
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: HP
Price Range Ex VAT: 300 - 500
