HP EliteDisplay E243m 23.8" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor
Quicklinx: DZRDWS00 Mfr#: 1FH48AA#ABU
Connect and collaborate in complete comfort on the HP EliteDisplay E243m 60.45 cm (23.8") Monitor, which is Skype for Business certified for optimal video and audio experiences between displays and has a 3-sided micro-edge bezel for seamless multi-display tiling and 4-way adjustable ergonomics.
  • Customizable collaboration
    Personalize your setup by combining your display with an HP accessory designed for UCC, including wired and wireless headsets, a speaker phone, and keyboards with dedicated collaboration keys.
  • Adaptable for a single-footprint setup
    Mount your compatible HP Desktop Mini PC or select Thin Client or Chromebox directly on the column stand using the optional HP B300 PC Mounting Bracket.
  • Experience simple, convenient connectivity
    Connect to your most frequently-used displays and devices with a range of integrated ports right at the display.
  • Be responsible
    Reduce power consumption and help lower costs with a low halogen, ENERGY STAR certified, EPEAT 2019 registered display that meets TCO Certified Edge with 85% Post-Consumer Recycled plastics.
  • Divide and conquer
    Design the screen for how you work with HP Display Assistant software, which enables screen partitioning and helps deter theft by dimming a display that's disconnected without approval.
HP EliteDisplay E243m - LED monitor - Full HD (1080p) - 23.8"
LED-backlit LCD monitor - 23.8"
Energy Class
Class E
Power Consumption (On mode)
17.5 W
2 microphones, USB 3.0 hub, 720p webcam
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 10000000:1 (dynamic)
Response Time
5 ms (On/Off)
Colour Support
16.7 million colours
Colour Gamut
72% NTSC
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
Black (rear cover), silver (speakers, bezel and stand)
53.88 cm x 21.4 cm x 51.37 cm
6.6 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified
Plug and Play, CSA, UL, VCCI, BSMI, NOM, TUV S, WHQL, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, MEPS, KC, CECP, EAC, ISC, CEL Grade 2, low halogen, ICE, SmartWay
5-year warranty
Display Type
Energy Class
Class E
Diagonal Size
23.8"
Built-in Devices
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Pixel Per Inch
93
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
72% NTSC
Response Time
5 ms (On/Off)
Vertical Refresh Rate
50 - 60 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
Colour Temperature
6500K
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
HDCP, Frame Rate Control (FRC), Low Blue Light Mode, Flicker Free technology, Mercury free, arsenic-free glass, Bang & Olufsen audio, Micro Edge, 72% NTSC colour gamut
53.88 cm x 21.4 cm x 51.37 cm - with stand
6.6 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
HDMI (HDCP) , DisplayPort (HDCP) , VGA , USB 3.0 upstream (Type B) , 2 x USB 3.0 downstream (Type A) , Audio line-in , Headphones
Mechanical
Tilt Angle
-5/+22
Swivel Angle
90
Rotation Angle
180
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), integrated cable management, detachable stand, direct mountable, VESA interface support
1 x VGA cable - 1.8 m , 1 x DisplayPort cable - 1.8 m , 1 x USB 3.0 to USB 3.0 type B cable - 1.8 m
Backlight Life
30,000 hours
Security Slot Type
Kensington security slot
Input Voltage
17.5 W
17.5 kWh/1000h
Power Consumption (Typical)
45 Watt
Power Consumption Stand by
0.5 Watt
On / Off Switch
Included Software
HP Display Assistant, Skype for Business
Dimensions & Weight Details
With stand - width: 53.88 cm - depth: 21.4 cm - height: 51.37 cm - weight: 6.6 kg , Without stand - width: 53.88 cm - depth: 4.63 cm - height: 34.72 cm - weight: 3.9 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - 5 years - on-site - response time: next business day
5 °C
35 °C
20 - 80% (non-condensing)
