HP EliteDisplay E243i 1920x1200 5ms IPS LED Monitor
Quicklinx: DC6CWS00 Mfr#: 1FH49AA#ABU
Diagonal Size: 24in
Max Resolution: 1920 x 1200
Response Time: 5ms
Speakers: None
Interfaces: DisplayPort, HDMI, VGA (HD-15)
19 in stock
£224.46 ex VAT
£269.35 inc VAT
Style meets substance in a strikingly modern business display crafted for optimal viewing, productivity, and ergonomics. The HP EliteDisplay E243i 24-inch Monitor has a 3-sided micro-edge bezel for seamless multi-display tiling and 4-way adjustability so you can comfortably power through the day.
  • Break the boundaries
    Expand your productivity with uninterrupted views of one screen or many with a 3-sided micro-edge bezel that supports virtually seamless arrays. Get crisp visuals from any angle on the 1920 x 1200 WUXGA resolution, 61 cm (24") diagonal IPS screen.
  • Work comfortably
    Find your most comfortable, productive position with adjustable tilt, height, swivel, and up to 150 mm height adjustment settings. Use pivot rotation to customize portrait or landscape views when using multiple displays.
  • Experience simple, convenient connectivity
    Work with your most frequently-used devices with VGA, HDMI, and DisplayPort . Connect your USB accessories right at the display with two USB 3.0 ports.
HP EliteDisplay E243i - LED monitor - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class A
Energy Consumption per Year
38 kWh
Power Consumption (On mode)
26 W
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:10
Native Resolution
WUXGA 1920 x 1200 at 60 Hz
Pixel Pitch
0.27 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 10000000:1 (dynamic)
Response Time
5 ms (On/Off)
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, anti-static
Silver
53.2 cm x 21.39 cm x 36.23 cm
6.36 kg
English / United Kingdom
Environmental Standards
TCO Certified Displays 7, TCO Certified Edge Displays, ENERGY STAR Qualified
Plug and Play, TUV GS, VCCI, BSMI, WHQL, CB, CCC, FCC, ISO 9241-307, WEEE, ICES, S Mark, cTUVus, ERP, CEL, ISC, RCM, MSIP, CoC, low halogen
5-year warranty
Display Type
Energy Class
Class A
38 kWh
26 W
Diagonal Size
24"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:10
Native Resolution
Pixel Pitch
0.27 mm
Brightness
300 cd/m²
Contrast Ratio
Response Time
5 ms (On/Off)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
BrightView, HDCP, arsenic-free glass
Silver
53.2 cm x 21.39 cm x 36.23 cm - with stand
6.36 kg
HDMI (HDCP) , DisplayPort (HDCP) , VGA , USB 3.0 upstream (Type B) , 2 x USB 3.0 downstream (Type A)
Mechanical
Tilt Angle
-5/+23
Swivel Angle
45
Rotation Angle
90
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
Security Slot Type
Kensington security slot
AC 120/230 V
35 Watt
Power Consumption Stand by
0.5 Watt
Dimensions & Weight Details
With stand - width: 53.2 cm - depth: 21.39 cm - height: 36.23 cm - weight: 6.36 kg , Without stand - width: 53.2 cm - depth: 4.64 cm - height: 35.13 cm
TCO Certified
ENERGY STAR Certified
Limited warranty - 5 years - on-site - response time: next business day
5 °C
35 °C
20 - 80%
Diagonal Size: 24in
Response Time: 5ms
Speakers: None
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: HP
Price Range Ex VAT: 150 - 300
