Brand
HP EliteDisplay E243d Docking 1920x1080 23.8" 5ms HDMI VGA DisplayPort USB-C LED monitor
Quicklinx: F3Y9WS00 Mfr#: 1TJ76AT#ABU
Diagonal Size: 23.8in
Max Resolution: 1920 x 1080
Response Time: 5ms
Interfaces: HDMI, USB-C, VGA (HD-15)
£349.83 ex VAT
£419.79 inc VAT
Style meets substance in a strikingly modern business display crafted for optimal viewing, productivity, and ergonomics. The HP EliteDisplay E243 Monitor has a 3-sided micro-edge bezel for seamless multi-display tiling and 4-way adjustability so you can comfortably power through your day.
  • Maximum efficiency in a modern, minimalist footprint
    Create a command center from a display and built-in docking station that's ready to drive your workspace as soon as you plug in. Power your notebook and send and receive video over driverless USB-C . Connect your wired network through the RJ-45.
  • Control your window to the world
    Reveal more of your work and support virtually seamless tiling with a 60.45 cm (23.8") diagonal IPS FHD screen and 3-sided micro-edge bezel. Daisy chain a second display from one PC connection with a DisplayPort output.
  • Expand your view
    Experience a virtually seamless dual-display setup with 3-sided micro-edge bezels when you daisy chain a second display from a single USB-C connection on your PC.
HP EliteDisplay E243d Docking - LED monitor - Full HD (1080p) - 23.8"
LED-backlit LCD monitor - 23.8"
Energy Class
Class F
Energy Consumption per Year
42 kWh
Power Consumption (On mode)
22 W
2 microphones, 720p webcam, USB 3.1 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Input Connectors
HDMI, VGA, USB-C
Display Position Adjustments
Screen Coating
Anti-glare
Voltage
Jack black, asteroid
53.88 cm x 20.5 cm x 47.71 cm
6.1 kg
English / United Kingdom
CSA, UL, VCCI, BSMI, NOM, TUV S, WHQL, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, MEPS, KC, EAC, ISC, low halogen, ICE, CEL Grade 3
Bundled Services
HP 5 years Next Business Day Bundled Support Extension for Monitors (United Kingdom)
Display Type
Energy Class
Class F
42 kWh
Diagonal Size
23.8"
Built-in Devices
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Pixel Per Inch
92.56
Brightness
250 cd/m²
Contrast Ratio
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
50 - 60 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Colour Temperature
6500K
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
HDCP, 72% NTSC colour gamut, Frame Rate Control (FRC), Flicker Free technology, Mercury free, arsenic-free glass, 94% sRGB colour gamut
53.88 cm x 20.5 cm x 47.71 cm - with stand
6.1 kg
DisplayPort output (HDCP) , DisplayPort (HDCP) , HDMI (HDCP) , VGA , Network , USB-C 3.1 upstream , 4 x USB 3.1 downstream , Audio line-in , Audio line-out
Mechanical
Tilt Angle
-5/+23
Swivel Angle
45
Rotation Angle
90
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
1 x USB-C cable - 1.8 m , 1 x DisplayPort cable - 1.8 m
Backlight Life
30,000 hours
Security Slot Type
Kensington security slot
Input Voltage
22 W
22 kWh/1000h
Power Consumption (Typical)
30 Watt
Power Consumption Stand by
0.5 Watt
Included Software
HP Display Assistant, CyberLink Youcam
Microsoft Windows 7 / 8.1 / 10
Dimensions & Weight Details
Without stand - width: 53.88 cm - depth: 4.535 cm - height: 32.19 cm - weight: 3.58 kg , Without stand - width: 53.88 cm - depth: 20.5 cm - height: 47.71 cm - weight: 6.1 kg
Shipping Width
62 cm
Shipping Depth
40 cm
Shipping Height
27.3 cm
Shipping Weight
9.59 kg
Bundled Services
5 °C
35 °C
20 - 80% (non-condensing)
Accessories (1)
F3Y9 HP B300 Mounting Bracket In Stock £28.07
Warranties (4)
F3Y9 HP Care Pack Next Business Day Hardware Support Extended Service Agreement 4 Years On-Site In Stock £15.53
F3Y9 HP Care Pack Next Business Day Hardware Support Extended Service Agreement 5 Years On-Site In Stock £30.10
F3Y9 HP Care Pack Next Business Day Hardware Support Extended Service Agreement 1 Year On-Site In Stock £15.53
F3Y9 HP Care Pack Next Business Day Hardware Support Extended Service Agreement 3 Yrs On-Site for Monitor In Stock £6.01
Response Time: 5ms
Interfaces: HDMI
Interfaces: USB-C
Interfaces: VGA (HD-15)
Brand: HP
