HP EliteDisplay E242 LED 24" Monitor 1920x1200 7MS PLS
Quicklinx: C7XCWS00 Mfr#: M1P02AT#ABU
Be a master at multi-tasking with HP EliteDisplay E242 61 cm (24") Monitor, which delivers Full HD resolution, TCO Edge Certified comfort features, and an extra-large screen for all of your work.
  • Room to navigate
    See more of your work onscreen at the same time with 1920 x 1200 resolution and a 16:10 aspect ratio on a 61 cm (24") diagonal screen. Collaborate easily with 178-degree viewing angle IPS technology that gives almost everyone in the room a great view.
  • Suit yourself
    Meet your comfort requirements and be more productive with adjustable tilt and swivel and an impressive 150 mm height adjustment range that combine to meet TCO Certified Edge requirements. Use pivot rotation to customize portrait or landscape views.
  • Ports for your platforms and peripherals
    Connect to a range of PCs and USB devices with HDMI, DisplayPort, VGA, and USB ports.
HP EliteDisplay E242 - LED monitor - 24"
LED-backlit LCD monitor - 24"
USB 2.0 hub
Panel Type
Plane to Line Switching (PLS)
Aspect Ratio
16:10
Native Resolution
1920 x 1200 at 60 Hz
Pixel Pitch
0.27 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
7 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
72%
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
Voltage
56.22 cm x 18.9 cm x 51.9 cm
6.23 kg
English / United Kingdom
Pricing Type
Promo
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
Plug and Play, CSA, UL, VCCI, BSMI, NOM, TUV S, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, MEPS, KC, CECP, CEL, EAC, ISC, SEPA
Display Type
Diagonal Size
24"
Built-in Devices
USB 2.0 hub
Panel Type
Aspect Ratio
16:10
Native Resolution
Pixel Pitch
0.27 mm
Pixel Per Inch
93.9
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
72%
Response Time
7 ms (grey-to-grey)
Vertical Refresh Rate
50 - 60 Hz
Horizontal Refresh Rate
30 - 80 kHz
Video Bandwidth
170 MHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
WLED
Controls & Adjustments
Brightness, contrast, input select, colour temperature
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
HDCP, Mercury free, arsenic-free glass
56.22 cm x 18.9 cm x 51.9 cm - with stand
6.23 kg
USB 2.0 upstream , 2 x USB 2.0 downstream , HDMI (HDCP) , DisplayPort (HDCP) , VGA
Mechanical
Tilt Angle
-5/+25
Swivel Angle
90
Rotation Angle
90
Height Adjustment
150 mm
1 x VGA cable - 1.8 m , 1 x DisplayPort cable - 1.8 m , 1 x USB cable - 1.8 m
Backlight Life
30,000 hours
Pricing Type
Promo
Input Voltage
Power Consumption (Typical)
30 Watt
Power Consumption Stand by
0.5 Watt
Included Software
HP Display Assistant
Microsoft Windows 7, Windows 8.1, Windows 10
Dimensions & Weight Details
Without stand - width: 56.22 cm - depth: 5 cm - height: 37.74 cm - weight: 4.2 kg , With stand - width: 56.22 cm - depth: 18.9 cm - height: 51.9 cm - weight: 6.23 kg
Sustainability Information
ENERGY STAR Certified
5 °C
35 °C
20 - 80%
