HP EliteDisplay E230t 23" 1920 x 1080 HDMI VGA DP IPS Touchscreen Monitor
Quicklinx: CH3SWS00 Mfr#: W2Z50AA#ABU
Diagonal Size: 23in
Max Resolution: 1920 x 1080
Response Time: 14ms
Speakers: None
Interfaces: DisplayPort, DVI, HDMI, VGA (HD-15)
Hurry, only 1 left in stock!
£253.06 ex VAT
£303.67 inc VAT
Give your productivity a hand with the ultrathin HP Elite E230t Monitor, a 23-inch diagonal Full HD IPS touch display that's Windows 10 certified with up to 10 simultaneous touch points for every way you touch and comfort adjustability for every way you work.
The next evolution of touch
Get a superb hands-on interactive touch experience minus the traditional distractions of glare and messy fingerprints with integrated in-cell touch technology that also enables a sleek, slim display.
Simply beautiful, nearly borderless
Maximize you visual real estate and see even more of your work on a wide-angle display that has a three-sided micro edge screen, which makes it easy to tile in multi-monitor arrangements and keep clean.
Create an efficient, smart setup
Attach your HP Desktop Mini, HP Chromebox or select HP Thin Client directly behind the display for an integrated, affordable workspace that’s perfect for small spaces. Or, use the integrated VESA mount to place the display on a wall or stand.
Optimized ergonomics
Find just the right position to be comfortable all day with adjustable height up to 150 mm, tilt, and swivel, plus pivot rotation for portrait mode viewing. The included VESA pattern supports wall and arm mounting in tight spaces.
Featuring
Connections for your PC and USB devices
Connect to your legacy and current environments with VGA, DisplayPort™, and HDMI, and add your USB devices with the integrated two-port USB 3.0 hub.
Keep your cool
Reduce power consumption and help lower your costs with an energy-smart, EPEAT® Gold registered design.
Divide and conquer
Design the screen for how you work with HP Display Assistant software, which enables screen partitioning and helps deter theft by deactivating a monitor that’s disconnected without approval.
Make it yours
Create a complete solution with HP accessories designed and tested to work with your display.
Available and supported around the world
Help ensure a consistent worldwide deployment with a Global Series monitor that is supported by a three-year standard limited warranty.
  • The next evolution of touch
  • Simply beautiful, nearly borderless
  • Create an efficient, smart setup
    Attach your HP Desktop Mini, HP Chromebox or select HP Thin Client directly behind the display for an integrated, affordable workspace that's perfect for small spaces. Or, use the integrated VESA mount to place the display on a wall or stand.
  • Optimized ergonomics
HP EliteDisplay E230t - LED monitor - Full HD (1080p) - 23"
LED-backlit LCD monitor - 23" - touchscreen
Energy Class
Class A
Energy Consumption per Year
30 kWh
Power Consumption (On mode)
20 W
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2652 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 500000:1 (dynamic)
Response Time
14 ms (On/Off), 5.7 ms (gray-to-gray with overdrive)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
52.08 cm x 5.23 cm x 31.195 cm
3.1 kg
English / United Kingdom
Environmental Standards
TCO Certified Displays 7, ENERGY STAR Qualified
Plug and Play, CSA, UL, VCCI, BSMI, NOM, TUV S, WHQL, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, MEPS, KC, CECP, EAC, ISC, SEPA, low halogen, CE/EMC
5-year warranty
Display Type
Energy Class
Class A
30 kWh
20 W
Diagonal Size
23"
Viewable Size
23"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2652 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
24 - 80 kHz
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
WLED
Colour Temperature
6500K
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
HDCP, anti-glare, 72% colour gamut, Frame Rate Control (FRC), On-screen Digital Controls, Mercury free, arsenic-free glass
52.08 cm x 5.23 cm x 31.195 cm - without stand
3.1 kg
Input
Touchscreen
USB 3.0 upstream , 2 x USB 3.0 downstream , HDMI (HDCP) , DisplayPort (HDCP) , VGA (HD-15)
Mechanical
Tilt Angle
-5/+25
Swivel Angle
180
Rotation Angle
90
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
1 x VGA cable - 1.8 m , 1 x DisplayPort cable - 1.8 m , 1 x USB cable - 1.8 m
Backlight Life
30,000 hours
29 Watt
Power Consumption Stand by
0.5 Watt
On / Off Switch
Included Software
Dimensions & Weight Details
Without stand - width: 52.08 cm - depth: 5.23 cm - height: 31.195 cm - weight: 3.1 kg , With stand - width: 52.08 cm - depth: 18.9 cm - height: 48.66 cm - weight: 4.9 kg
ENERGY STAR Certified
TCO Certified
Limited warranty - 5 years - on-site - response time: next business day
5 °C
35 °C
20 - 80% (non-condensing)
HP EliteDisplay E230t 23 Bundle deal on HP EliteDisplay E230t 23" 1920 x 1080 HDMI VGA DP IPS Touchscreen Monitor
£352.23
Diagonal Size: 23in
Response Time: 14ms
Speakers: None
Interfaces: DVI
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: HP
Price Range Ex VAT: 150 - 300
