HP EliteDisplay E223d 21.5" 1920x1080 5ms HDMI DisplayPort IPS LED Docking Monitor
Quicklinx: FBQCWS00 Mfr#: 5VT82AT#ABU
Diagonal Size: 21.5in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: None
Interfaces: HDMI, USB-C
49 in stock
£300.88 ex VAT
£361.05 inc VAT
Clear your clutter with the easy, efficient connectivity of the HP EliteDisplay E223d 21.5-inch Docking Monitor. Set up your devices and network at the display one time, then connect your notebook through just one USB-C cable and you're ready to work.
  • Single-cable simplicity
    Streamline your space with the clean, convenient cabling of one USB-C 1 connection from your notebook to a display that's also a dock to access your devices, network, and video and power your PC.
  • Flexible by design
    Find your sweet spot with adjustable tilt, height, swivel, and pivot rotation. Add a second display daisy-chained through your PC's USB-C connection. 3-sided micro-edge bezels ensure a virtually seamless dual-display view.
  • Take your PC off the desk
    Maximize space in desktop PC environments by mounting your HP EliteDesk Mini Desktop PC directly behind the display and powering it through USB-C . Or, lift the whole solution and mount it on a wall or arm.
HP EliteDisplay E223d Docking Monitor - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
USB 3.1 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.274 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Input Connectors
HDMI, USB-C
Display Position Adjustments
Pivot (rotation), swivel, tilt
Screen Coating
Anti-glare
48.83 cm x 20.5 cm x 44.86 cm
5.08 kg
English / United Kingdom
Plug and Play, TUV GS, VCCI, BSMI, NOM, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, ICES, cTUVus, MEPS, KC, CEL, EAC, ISC, BIS, low halogen
3-year warranty
Display Type
Diagonal Size
21.5"
Viewable Size
21.5"
Built-in Devices
USB 3.1 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.274 mm
Brightness
250 cd/m²
Contrast Ratio
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
60 Hz
Horizontal Refresh Rate
80 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
HDCP, On-screen Digital Controls, Mercury free, arsenic free
48.83 cm x 20.5 cm x 44.86 cm - with stand
5.08 kg
HDMI (HDCP) , USB-C , Network , USB 3.1 upstream (Type B) , 4 x USB 3.1 downstream (Type A) , Audio line-in/out
Mechanical
Tilt Angle
- 5/+23
Swivel Angle
90
Rotation Angle
90
VESA Mounting Interface
VESA
Security lock slot (cable lock sold separately), detachable stand
1 x USB cable , 1 x USB-C cable
Security Slot Type
Kensington security slot
15 Watt
Power Consumption Stand by
0.3 Watt
Included Software
HP Display Assistant
Dimensions & Weight Details
Without stand - width: 48.83 cm - depth: 4.483 cm - height: 29.33 cm
Shipping Width
58.9 cm
Shipping Depth
27.3 cm
Shipping Height
36.5 cm
Shipping Weight
8.06 kg
Limited warranty - parts and labour - 3 years
5 °C
35 °C
20 - 80%
HP EliteDisplay E223d 21.5 Bundle deal on HP EliteDisplay E223d 21.5" 1920x1080 5ms HDMI DisplayPort IPS LED Docking Monitor
£400.05
Response Time: 5ms
Speakers: None
Interfaces: HDMI
Interfaces: USB-C
Brand: HP
Price Range Ex VAT: 300 - 500
