Brand
HP EliteDisplay E223d 21.5" 1920x1080 5ms HDMI DisplayPort IPS LED Docking Monitor
Quicklinx: FBQCWS00 Mfr#: 5VT82AT#ABU
Clear your clutter with the easy, efficient connectivity of the HP EliteDisplay E223d 21.5-inch Docking Monitor. Set up your devices and network at the display one time, then connect your notebook through just one USB-C cable and you're ready to work.
  • Adjust your view
    Filter blue light emission and shift colors to a warmer spectrum for more comfortable viewing with HP Low Blue Light mode.
  • Complete the picture
    Customize a total solution with options like the HP S101 Speaker Bar, which attaches easily to the lower bezel to add stereo audio at the display.
  • Divide and conquer
    Manage your display and make it work for you. HP Display Assistant allows you to quickly resize screen partitions so you can work in separate regions of the screen and helps deter theft by dimming a display that's disconnected without approval.
  • We have your back
    Rest assured that your IT investment is supported with our three-year standard limited warranty. To extend your protection, select an optional HP Care service.
HP EliteDisplay E223d Docking Monitor - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
USB 3.1 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.274 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Input Connectors
HDMI, USB-C
Display Position Adjustments
Pivot (rotation), swivel, tilt
Screen Coating
Anti-glare
Voltage
48.83 cm x 20.5 cm x 44.86 cm
5.08 kg
English / United Kingdom
Plug and Play, TUV GS, VCCI, BSMI, NOM, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, ICES, cTUVus, MEPS, KC, CEL, EAC, ISC, BIS, low halogen
3-year warranty
Display Type
Diagonal Size
21.5"
Built-in Devices
USB 3.1 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.274 mm
Brightness
250 cd/m²
Contrast Ratio
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
60 Hz
Horizontal Refresh Rate
80 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
HDCP, On-screen Digital Controls, Mercury free, arsenic free
48.83 cm x 20.5 cm x 44.86 cm - with stand
5.08 kg
HDMI (HDCP) , USB-C , Network , USB 3.1 upstream (Type B) , 4 x USB 3.1 downstream (Type A) , Audio line-in/out
Mechanical
Tilt Angle
-5/+23
Swivel Angle
90
Rotation Angle
90
VESA Mounting Interface
VESA
Security lock slot (cable lock sold separately), detachable stand
1 x USB cable , 1 x USB-C cable
Security Slot Type
Kensington security slot
Input Voltage
Power Consumption (Typical)
15 Watt
Power Consumption Stand by
0.3 Watt
Included Software
Dimensions & Weight Details
Without stand - width: 48.83 cm - depth: 4.483 cm - height: 29.33 cm
Shipping Width
58.9 cm
Shipping Depth
27.3 cm
Shipping Height
36.5 cm
Shipping Weight
8.06 kg
Limited warranty - parts and labour - 3 years
5 °C
35 °C
20 - 80%
Accessories (1)
FBQC HP B300 Mounting Bracket In Stock £32.48
Warranties (4)
FBQC HP Care Pack Next Business Day Hardware Support Extended Service Agreement 4 Years On-Site In Stock £15.53
FBQC HP Care Pack Next Business Day Hardware Support Extended Service Agreement 5 Years On-Site In Stock £30.10
FBQC HP Care Pack Next Business Day Hardware Support Extended Service Agreement 1 Year On-Site In Stock £15.53
FBQC HP Care Pack Next Business Day Hardware Support Extended Service Agreement 3 Yrs On-Site for Monitor In Stock £6.01
