HP EliteDisplay E223 1920x1080 Full HD IPS LED Monitor
Quicklinx: DC5WWS00 Mfr#: 1FH45AA#ABU
Diagonal Size: 21.5in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: None
Interfaces: DisplayPort, HDMI, VGA (HD-15)
More than 50 in stock
£166.58 ex VAT
£199.89 inc VAT
Style meets substance in a strikingly modern business display crafted for optimal viewing, productivity, and ergonomics. The HP EliteDisplay E223 21.5-inch Monitor has a 3-sided micro-edge bezel for seamless multi-display tiling and 4-way adjustability so you can comfortably power through your day.
  • Break the boundaries
    Expand your productivity with uninterrupted views of one screen or many with a 3-sided micro-edge bezel that supports virtually seamless arrays. Get crisp visuals from any angle on the 1920 x 1080 Full HD resolution, 54.6 cm (21.5") diagonal IPS screen.
  • Work comfortably
    Find your most comfortable, productive position with adjustable tilt, height, swivel, and up to 150 mm height adjustment settings. Use pivot rotation to customize portrait or landscape views when using multiple displays.
  • Experience simple, convenient connectivity
    Work with your most frequently-used devices with VGA, HDMI, and DisplayPort . Connect your USB accessories right at the display with two USB 3.0 ports.
HP EliteDisplay E223 - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Energy Class
Class A
Energy Consumption per Year
25 kWh
Power Consumption (On mode)
17 W
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.24795 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
5 ms (On/Off)
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, anti-static
Silver, black (rear cover)
48.83 cm x 20.5 cm x 46.37 cm
5.26 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified
Plug and Play, TUV GS, VCCI, BSMI, WHQL, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, ICES, S Mark, cTUVus, MEPS, KC, ERP, CEL, EAC, ISC, RCM, MSIP, CoC, low halogen
5-year warranty
Display Type
Energy Class
Class A
25 kWh
17 W
Diagonal Size
21.5"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.24795 mm
Brightness
250 cd/m²
Contrast Ratio
Response Time
5 ms (On/Off)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
HDCP
48.83 cm x 20.5 cm x 46.37 cm - with stand
5.26 kg
HDMI (HDCP) , DisplayPort (HDCP) , VGA , USB 3.0 upstream (Type B) , 2 x USB 3.0 downstream (Type A)
Mechanical
Tilt Angle
- 5/+23
Swivel Angle
90
Rotation Angle
90
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
Security Slot Type
Kensington security slot
AC 120/230 V
18 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
ENERGY STAR Certified
Limited warranty - 5 years - on-site - response time: next business day
5 °C
35 °C
20 - 80%
HP EliteDisplay E223 1920x1080 Full HD IPS LED Monitor Bundle deal on HP EliteDisplay E223 1920x1080 Full HD IPS LED Monitor
£265.75
Response Time: 5ms
Speakers: None
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: HP
Price Range Ex VAT: 150 - 300
