HP EliteDisplay E222 LED 21.5" Monitor 1920x1080 7MS
Quicklinx: C7XBWS00 Mfr#: M1N96AT#ABU
Diagonal Size: 21.5in
Max Resolution: 1920 x 1080
Response Time: 7ms
Speakers: None
Interfaces: DisplayPort, HDMI, VGA (HD-15)
£133.90 ex VAT
£160.68 inc VAT
Be productive and comfortable with the HP EliteDisplay E222 54,6 cm (21.5") Monitor, a Full HD IPS display that delivers crisp, clear color for all of your projects and excellent ergonomic adjustability at an attractive price point.
  • Clear viewing ahead
    Collaborate freely with 178-degree views from almost anywhere in the room thanks to IPS technology. An ample 54,6 cm (21.5") diagonal screen keeps your work front and center and Full HD 1920 x 1080 resolution makes your colors and content pop.
  • Settle in
    Be comfortable and productive with adjustable tilt and swivel settings and an impressive 150 mm height adjustment range. Use pivot rotation to customize portrait or landscape views.
  • Simple, expansive connections
    Enjoy easy connectivity to a range of PCs and devices with HDMI, DisplayPort, and VGA inputs. The integrated USB hub keeps everyday devices close at hand with USB connections at the display.
HP EliteDisplay E222 - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Energy Class
Class A
Energy Consumption per Year
29 kWh
Power Consumption (On mode)
20 W
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.24795 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
7 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
Black, silver
51.37 cm x 18.9 cm x 33.35 cm
5.27 kg
English / United Kingdom
Pricing Type
Promo
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
Plug and Play, CSA, UL, VCCI, BSMI, NOM, TUV S, WHQL, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, MEPS, KC, CECP, EAC, CEL Grade 1, ISC, SEPA
Display Type
Energy Class
Class A
29 kWh
20 W
Diagonal Size
21.5"
Viewable Size
21.5"
Built-in Devices
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.24795 mm
Pixel Per Inch
102
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
7 ms (grey-to-grey)
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Video Bandwidth
170 MHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
WLED
Controls & Adjustments
Brightness, contrast, input select, colour temperature
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
HDCP, 72% colour gamut, Mercury free, arsenic-free glass
Black, silver
51.37 cm x 18.9 cm x 33.35 cm - with stand
5.27 kg
USB 2.0 upstream , 2 x USB 2.0 downstream , HDMI (HDCP) , DisplayPort (HDCP) , VGA
Mechanical
Tilt Angle
-5/+25
Swivel Angle
90
Rotation Angle
90
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), detachable stand
1 x VGA cable - 1.8 m , 1 x DisplayPort cable - 1.8 m , 1 x USB cable - 1.8 m
Backlight Life
30,000 hours
Pricing Type
Promo
AC 120/230 V
23 Watt
Power Consumption Stand by
0.5 Watt
Included Software
HP Display Assistant
Microsoft Windows 7, Windows 8.1, Windows 10
Dimensions & Weight Details
Without stand - width: 51.37 cm - depth: 4.98 cm - height: 31.69 cm - weight: 3.26 kg , With stand - width: 51.37 cm - depth: 18.9 cm - height: 33.35 cm - weight: 5.27 kg
ENERGY STAR Certified
5 °C
35 °C
20 - 80% (non-condensing)
Response Time: 7ms
Speakers: None
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: HP
Price Range Ex VAT: 100 - 150
