HP EliteDisplay E222 LED 21.5" Monitor 1920x1080 7MS
Quicklinx: C7XBWS00 Mfr#: M1N96AT#ABU
Be productive and comfortable with the HP EliteDisplay E222 54,6 cm (21.5") Monitor, a Full HD IPS display that delivers crisp, clear color for all of your projects and excellent ergonomic adjustability at an attractive price point.
  • A compact, efficient PC-and-monitor workspace
    Attach your HP Desktop Mini, HP Chromebox, or select HP Thin Client directly behind the display. Keep things tidy with an integrated power supply and cable management features.
  • Reduce power consumption and help lower costs
    Get an intelligent, energy-efficient design that is ENERGY STAR certified, EPEAT Gold registered, and meets TCO Certified Edge requirements requirements with 85% Post-Consumer Recycled plastics.
  • Your monitor's new best friend
    Design the screen for how you work with HP Display Assistant software.
  • Make it yours
    Customize a complete solution with HP accessories designed and tested to work with your display.
  • Backed by world-class support specialists
    Get three years of service and support, and extend your protection with optional HP Care Packs.
HP EliteDisplay E222 - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Energy Class
Class A
Energy Consumption per Year
29 kWh
Power Consumption (On mode)
20 W
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.24795 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
7 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
72%
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
Voltage
AC 120/230 V
Black, silver
51.37 cm x 18.9 cm x 33.35 cm
5.27 kg
English / United Kingdom
Pricing Type
Promo
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
Plug and Play, CSA, UL, VCCI, BSMI, NOM, TUV S, WHQL, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, MEPS, KC, CECP, EAC, CEL Grade 1, ISC, SEPA
Display Type
Energy Class
Class A
29 kWh
Diagonal Size
21.5"
Built-in Devices
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.24795 mm
Pixel Per Inch
102
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
72%
Response Time
7 ms (grey-to-grey)
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Video Bandwidth
170 MHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
WLED
Controls & Adjustments
Brightness, contrast, input select, colour temperature
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
HDCP, Mercury free, arsenic-free glass
Black, silver
51.37 cm x 18.9 cm x 33.35 cm - with stand
5.27 kg
USB 2.0 upstream , 2 x USB 2.0 downstream , HDMI (HDCP) , DisplayPort (HDCP) , VGA
Mechanical
Tilt Angle
-5/+25
Swivel Angle
90
Rotation Angle
90
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), detachable stand
1 x VGA cable - 1.8 m , 1 x DisplayPort cable - 1.8 m , 1 x USB cable - 1.8 m
Backlight Life
30,000 hours
Pricing Type
Promo
Input Voltage
AC 120/230 V
20 W
Power Consumption (Typical)
23 Watt
Power Consumption Stand by
0.5 Watt
Included Software
Microsoft Windows 7, Windows 8.1, Windows 10
Dimensions & Weight Details
Without stand - width: 51.37 cm - depth: 4.98 cm - height: 31.69 cm - weight: 3.26 kg , With stand - width: 51.37 cm - depth: 18.9 cm - height: 33.35 cm - weight: 5.27 kg
Sustainability Information
ENERGY STAR Certified
5 °C
35 °C
20 - 80% (non-condensing)
