Connect and collaborate. Locally and globally. Bring the meeting to you. The HP EliteDisplay E221c 54,6 cm (21.5') Webcam LED Backlit Monitor combines the wide viewing angles of IPS technology with integrated communications technology so it's easy, affordable, and comfortable to quickly connect and collaborate.
Be meeting-ready on a moment's notice
Quickly connect and collaborate, and optimize your virtual communication technologies like Microsoft Lync. The professional-class display plus integrated webcam, speakers, and microphone are ready when you are. -
Power through your day in comfort
Customizable tilt, height adjustment, swivel, and pivot settings-the most adjustability available on an HP business display-help you find your sweet spot.HP EliteDisplays also meet TCO Certified Edge requirements for innovative products at the forefront of environmental and ergonomic stand design. -
Now see everything
Get great 178-degree viewing angles views and stunning color integrity from In-Plane Switching (IPS) technology. Share content, media, and video conferences with everyone in the room. -
Enhance your view
Enjoy crisp, clear content and video from the high contrast ratio and fast response time. Easily connect devices with convenient VGA, DVI, and DisplayPort inputs and the integrated USB hub. -
Control your environmental impact
Reduce power consumption and help lower your costs with an intelligent, energy-efficient design that is ENERGY STAR qualified and EPEAT Gold registered.The displays also include mercury-free display backlights, a low halogen design, and arsenic-free display glass. -
Meet your monitor's new best friend
Personalize your workspace with resizable screen partitions and work in documents, spreadsheets, and e-mail in separate regions of the screen-at the same time-with HP Display Assistant software.View open applications on all of your connected displays with the expanded toolbar. Help deter theft with a user-designated PIN that deactivates the monitor if it's disconnected from a PC without approval. -
Breathe easy
Rest assured that your IT investment is supported by a three-year standard limited warranty. Select optional HP Care Pack Services to extend your protection beyond the standard warranty.
- HP EliteDisplay E221c - LED monitor - Full HD (1080p) - 21.5"
- LED-backlit LCD monitor - 21.5"
- Camera, 2 microphones, USB 2.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 5000000:1 (dynamic)
- Response Time
- 7 ms (grey-to-grey)
- Input Connectors
- DVI-D, VGA, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare
- Black
- 50.09 cm x 23.7 cm x 46 cm
- 5.4 kg
- Localisation
- English / United Kingdom
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified EPEAT Gold
- Plug and Play, VCCI, BSMI, NOM, TUV S, CB, CCC, PSB, FCC, KCC, KC, CECP, CEL
- Display Type
- Diagonal Size
- 21.5"
- Built-in Devices
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Response Time
- Vertical Refresh Rate
- 50 - 76 Hz
- Horizontal Refresh Rate
- 24 - 94 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- Anti-glare
- Black
- 50.09 cm x 23.7 cm x 46 cm - with stand
- 5.4 kg
Audio
- Speakers
- Output Power / Channel
- 1 Watt
- USB 2.0 upstream (Type B) , 2 x USB 2.0 downstream , DVI-D (HDCP) , DisplayPort (HDCP) , VGA , Audio line-out
Mechanical
- Tilt Angle
- -5/+30
- Swivel Angle
- 360
- Rotation Angle
- 90
- Height Adjustment
- 150 mm
- Localisation
- Power Consumption (Typical)
- 27 Watt
- Power Consumption Stand by
- 0.4 Watt
- Dimensions & Weight Details
- With stand - width: 50.09 cm - depth: 23.7 cm - height: 46 cm - weight: 5.4 kg , Without stand - width: 50.09 cm - depth: 5.1 cm - height: 30.9 cm - weight: 3.3 kg
Sustainability Information
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
