Product
Brand
HP EliteDisplay E221C LED MNT
Quicklinx: 90TJWS00 Mfr#: D9E49AT#ABU
Connect and collaborate. Locally and globally. Bring the meeting to you. The HP EliteDisplay E221c 54,6 cm (21.5') Webcam LED Backlit Monitor combines the wide viewing angles of IPS technology with integrated communications technology so it's easy, affordable, and comfortable to quickly connect and collaborate.
HP EliteDisplay E221c - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Camera, 2 microphones, USB 2.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
7 ms (grey-to-grey)
Input Connectors
DVI-D, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
50.09 cm x 23.7 cm x 46 cm
5.4 kg
English / United Kingdom
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
Plug and Play, VCCI, BSMI, NOM, TUV S, CB, CCC, PSB, FCC, KCC, TCO Certified Edge, KC, CECP, CEL
Display Type
Diagonal Size
21.5"
Viewable Size
21.5"
Built-in Devices
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
Response Time
7 ms (grey-to-grey)
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
24 - 94 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Anti-glare
50.09 cm x 23.7 cm x 46 cm - with stand
5.4 kg
Audio
Speakers
Output Power / Channel
1 Watt
USB 2.0 upstream (Type B) , 2 x USB 2.0 downstream , DVI-D (HDCP) , DisplayPort (HDCP) , VGA , Audio line-out
Mechanical
Tilt Angle
-5/+30
Swivel Angle
360
Rotation Angle
90
Height Adjustment
150 mm
27 Watt
Power Consumption Stand by
0.4 Watt
Dimensions & Weight Details
With stand - width: 50.09 cm - depth: 23.7 cm - height: 46 cm - weight: 5.4 kg , Without stand - width: 50.09 cm - depth: 5.1 cm - height: 30.9 cm - weight: 3.3 kg
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
5 °C
35 °C
20 - 80% (non-condensing)
