Product
HP EliteDisplay E202 20" 1600x900 7ms VGA HDMI Monitor
Quicklinx: C402WS00 Mfr#: M1F41AA#ABU
Diagonal Size: 20in
Max Resolution: 1600 x 900
Response Time: 7ms
Speakers: None
Interfaces: DisplayPort, HDMI, VGA (HD-15)
34 in stock
£152.50 ex VAT
£183.00 inc VAT
Get comfortable and be productive with the affordable, easy-to-deploy HP EliteDisplay E202 50,8 cm (20") Monitor, an HD+ IPS display that is Certified for Windows 10 and includes excellent ergonomic adjustability and crisp, clear color presentation.
  • It's all in the details
    Show and share projects around the room with 178-degree, wide-angle IPS technology. Keep your work front and center on the ample 50,8 cm (20") diagonal screen and enjoy 1600 x 900 HD+ color and clarity for all of your content.
  • Find your comfort zone
    Settle into your most comfortable position with adjustable tilt and swivel settings and an impressive 150 mm height adjustment range. Use pivot rotation to customize portrait or landscape views.
  • Ports for every peripheral
    Connect to a range of PCs and devices with HDMI, DisplayPort, and VGA inputs. The integrated USB hub keeps everyday devices close at hand with USB connections at the display.
HP EliteDisplay E202 - LED monitor - 20"
LED-backlit LCD monitor - 20"
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
1600 x 900 at 60 Hz
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
7 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
47.9 cm x 4.95 cm x 29.68 cm
2.8 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified
CSA, UL, VCCI, BSMI, NOM, TUV S, WHQL, CB, CCC, PSB, ISO 9241-307, KCC, WEEE, MEPS, TCO Certified Edge, KC, CECP, CEL, EAC, ISC, SEPA
5 years warranty
Display Type
Diagonal Size
20"
Viewable Size
20.0"
Built-in Devices
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
1600 x 900 at 60 Hz
Pixel Pitch
0.276 mm
Pixel Per Inch
91
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
7 ms (grey-to-grey)
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
30 - 70 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
WLED
Controls & Adjustments
Brightness, contrast
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
HDCP, 72% colour gamut
47.9 cm x 4.95 cm x 29.68 cm - without stand
2.8 kg
USB 2.0 upstream (Type B) , 2 x USB 2.0 downstream (Type A) , HDMI (HDCP) , DisplayPort (HDCP) , VGA (HD-15)
Mechanical
Tilt Angle
-5/+25
Swivel Angle
90
Rotation Angle
90
Height Adjustment
150 mm
Flat Panel Mount Interface
100 x 100 mm
1 x VGA cable - 1.8 m , 1 x DisplayPort cable - 1.8 m , 1 x USB cable - 1.8 m
Backlight Life
40,000 hours
22 Watt
Power Consumption Stand by
0.5 Watt
Dimensions & Weight Details
Without stand - width: 47.9 cm - depth: 4.95 cm - height: 29.68 cm - weight: 3 kg , With stand - width: 47.9 cm - depth: 18.9 cm - height: 49.33 cm - weight: 4.8 kg
ENERGY STAR Certified
Limited warranty - 5 years - on-site - response time: next business day
5 °C
35 °C
20 - 80% (non-condensing)
HP EliteDisplay E202 20 Bundle deal on HP EliteDisplay E202 20" 1600x900 7ms VGA HDMI Monitor
£252.26
Diagonal Size: 20in
Response Time: 7ms
Speakers: None
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: HP
Price Range Ex VAT: 150 - 300
