Brand
HP EliteDisplay E190i 19" 1280x1024 VGA DVI-D DisplayPort LED Monitor
Quicklinx: 98QCWS00 Mfr#: E4U30AT#ABU
Diagonal Size: 18.9in
Max Resolution: 1280 x 1024
Response Time: [N/A]
Speakers: [N/A]
Interfaces: DVI, VGA (HD-15), DisplayPort
£177.71 ex VAT
£213.25 inc VAT
The legacy friendly, business-critical IPS display. Get a 5:4 aspect ratio display designed for all of your business-specific applications, now with the impeccable presentation and extra-wide viewing angles of IPS technology. Enjoy customizable comfort from a completely adjustable stand and be environmentally responsible with designed-in energy efficiency.
  • Now see everything
    Get great 178-degree viewing angles and stunning color integrity from In-Plane Switching (IPS) technology. Accurately view sharp images and consistent color from almost any angle-with less distortion than conventional TN (Twisted Nematic) panels.
  • Stay the course
    Keep the 5:4 aspect ratio that your business-specific enterprise and public sector applications are designed to work with. Enjoy ample space for all your tasks on the 48 cm (18.89') diagonal screen.
  • Power through your day in comfort
    Find your most comfortable viewing position with customizable tilt, height adjustment, swivel, and pivot settings.
  • Help control your environmental impact
    Reduce power consumption and help lower your costs with an intelligent, energy efficient design that's ENERGY STAR qualified and EPEAT Gold registered.The display also includes mercury-free display backlights, low halogen components, and arsenic-free display glass.
  • Performance and connectivity
    Get crisp, clear content and video from the high 3M:1 dynamic contrast ratio and fast response time.Easily connect media and devices at the monitor with convenient VGA, DVI, and DisplayPort inputs and the integrated USB hub.
  • Productivity and management software
    Personalize your workspace with resizable screen partitions and work in documents, spreadsheets, and e-mail in separate regions of the screen-at the same time-with HP Display Assistant software.View open applications on all of your connected displays with the expanded toolbar.Deter theft with a user-designated PIN that deactivates the monitor if it's disconnected from a PC without approval.
HP EliteDisplay E190i - LED monitor - 18.9"
LED-backlit LCD monitor - 18.9"
Energy Class
Class D
Power Consumption (On mode)
11 W
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
5:4
Native Resolution
1280 x 1024 at 60 Hz
Pixel Pitch
0.2928 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 3000000:1 (dynamic)
Response Time
14 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, anti-static
Voltage
41.7 cm x 4.7 cm x 34.7 cm
3 kg
English / United Kingdom
Environmental Standards
TCO Certified Displays 8, ENERGY STAR Qualified EPEAT Gold
Plug and Play, CSA, UL, TUV, VCCI, GS, CCC, FCC, ISO 9241-307, KCC, CISPR, MEPS, KC, CECP, EuP
5-year warranty
Bundled Services
HP 5 years Next Business Day Bundled Support Extension for Monitors (United Kingdom)
Display Type
Energy Class
Class D
Diagonal Size
18.9"
Viewable Size
18.9"
Built-in Devices
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
5:4
Native Resolution
Pixel Pitch
0.2928 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
53 - 82 kHz
Video Bandwidth
135 MHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
Colour Temperature
6500K
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Portuguese, Spanish, Dutch, Japanese
72% colour gamut
41.7 cm x 4.7 cm x 34.7 cm - without stand
3 kg
USB 2.0 upstream (Type B) , USB 2.0 downstream (Type A) , DVI-D , DisplayPort , VGA
Mechanical
Tilt Angle
-5/+25
Swivel Angle
360
Rotation Angle
90
Height Adjustment
12 cm
VESA Mounting Interface
100 x 100 mm
1 x VGA cable - 1.8 m , 1 x DisplayPort cable - 1.8 m , 1 x USB cable - 1.8 m
Backlight Life
30,000 hours
Power Supply
Internal
Input Voltage
11 W
11 kWh/1000h
Power Consumption HDR (On mode)
0.3 kWh/1000h
Power Consumption (Typical)
25 Watt
Power Consumption Stand by
0.5 Watt
Included Software
Dimensions & Weight Details
Without stand - width: 41.7 cm - depth: 4.7 cm - height: 34.7 cm - weight: 3 kg , With stand - width: 41.7 cm - depth: 19.2 cm - height: 48.6 cm - weight: 4.9 kg
TCO Certified
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Limited warranty - 5 years - on-site - response time: next business day
Bundled Services
15 - 80% (non-condensing)
Warranties (4)
98QC HP Care Pack Next Business Day Hardware Support Extended Service Agreement 4 Years On-Site In Stock £15.53
98QC HP Care Pack Next Business Day Hardware Support Extended Service Agreement 5 Years On-Site In Stock £30.10
98QC HP Care Pack Next Business Day Hardware Support Extended Service Agreement 1 Year On-Site In Stock £15.53
98QC HP Care Pack Next Business Day Hardware Support Extended Service Agreement 3 Yrs On-Site for Monitor In Stock £6.01
Other bundles (1)
98QC HP Integrated Work Center Stand - Monitor/desktop stand - 17"-2 In Stock £135.84
Speakers: [N/A]
Interfaces: DVI
Interfaces: VGA (HD-15)
Interfaces: DisplayPort
Brand: HP
