Brand
HP EliteDesk i7-10700 512GB 16GB W10P
Quicklinx: G6L3WS00 Mfr#: 122J2ET#ABU
Processor Type: Core i7
Operating System: Windows 10 Pro 64-bit Edition
Hard Drive Capacity: 512GB
Storage Type: SSD
Processor Model: I7-10700
  • Core i7
  • IEEE 802.11n
£886.77 ex VAT
£1,064.12 inc VAT
The redesigned HP EliteDesk 800 Small Form Factor delivers high performance and broad expandability in a compact business-class SFF PC. Featuring powerful components, and strong security, this small PC handles big workloads.
  • Let nothing stand in your way
    Power through your day with Windows 10 Pro and the powerful security, collaboration and connectivity features from HP.
  • Fast performance, connectivity, and responsiveness
    Get the exceptional combination of responsive performance, connectivity and speed with a 10th Gen Intel Core processor that lets you launch, create, and connect fast and reliably.
  • HP Sure Sense
    Malware is evolving rapidly and traditional antivirus can't always recognize new attacks. Protect your PC against never-before-seen attacks with HP Sure Sense, which uses deep learning AI to provide exceptional protection against advanced malware.
  • Protect critical security processes
    Keep your critical applications and processes running even if malware tries to shut them down with the self-healing protection of HP Sure Run.
  • Browse confidently
    Help protect your PC from websites and read only Microsoft Office and PDF attachments with embedded malware, ransomware, or viruses with hardware-enforced security from HP Sure Click.
HP EliteDesk 800 G6 - SFF - Core i7 10700 2.9 GHz - vPro - 16 GB - SSD 512 GB - UK
Personal computer - small form factor
Platform Technology
Intel vPro Platform
Intel Core i7 (10th Gen) 10700 / 2.9 GHz (4.8 GHz) (8-core)
Processor Main Features
Hyper-Threading Technology, Intel Turbo Boost Technology 2, Intel Smart Cache
Cache Memory
16 MB L3 Cache
Cache Per Processor
16 MB
RAM
16 GB (installed) / 128 GB (max) - DDR4 SDRAM - non-ECC
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
SSD 512 GB - PCI Express 3.0 - M.2 2280 - NVM Express (NVMe), triple-level cell (TLC)
Optical Storage
DVD-Writer
Graphics Controller
Intel UHD Graphics 630 Dynamic Video Memory Technology
Audio Output
Stereo
GigE, 802.11a, 802.11b/g/n, 802.11ac, Bluetooth 5.0, 802.11ax (Wi-Fi 6)
Keyboard
OS Provided
33.8 cm x 30.8 cm x 10 cm
6.13 kg
Environmental Standards
TCO Certified Desktops 8, ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years - on-site
Platform Technology
Intel vPro Platform
Personal computer
Product Form Factor
Small form factor
Built-in Devices
Speaker
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Clock Speed
2.9 GHz
Max Turbo Speed
4.8 GHz
Number of Cores
8-core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
Chipset Type
Intel Q470
Cache Memory
Installed Size
L3 Cache - 16 MB
Cache Per Processor
16 MB
RAM
Installed Size
16 GB / 128 GB (max)
Effective Memory Speed
2933 MHz
Rated Memory Speed
2933 MHz
DIMM 288-pin
Slots
4 (Total) / 3 (empty)
Unbuffered
Configuration Features
1 x 16 GB
Hard Drive
SSD - M.2 2280
1 x 512 GB
Interface Type
PCI Express 3.0
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Channel Qty
3
Optical Storage
DVD-Writer
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
VGA, DisplayPort
HDCP Compatible
Audio Output
Sound Output Mode
Stereo
Max Sampling Rate
192 kHz
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
HP 320K
USB
Localization & Layout
Mouse
Optical
USB
Ethernet Controller
Intel I219-LM
Wireless LAN Supported
Wireless NIC
Intel Wi-Fi 6 AX 201
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 5.0, IEEE 802.11ax (Wi-Fi 6)
Remote Management Protocol
SNMP 2
Wake on LAN (WoL), ACPI support, PXE 2.1 support, dual stream (2x2)
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.3x, IEEE 802.11d, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11h, IEEE 802.11e, IEEE 802.11n, IEEE 802.11k, IEEE 802.3az, IEEE 802.11ac, IEEE 802.11r, IEEE 802.11v, Bluetooth 5.0, IEEE 802.11ax
Bays
1 (total) / 1 (free) x internal 2.5" , 2 (total) / 2 (free) x internal 3.5" , 1 (total) / 0 (free) x external 5.25" Slim Line
Slots
1 (total) / 0 (free) x M.2 Card - 2230 , 2 (total) / 1 (free) x M.2 Card - 2242/2280 (x4 mode) , 2 (total) / 2 (free) x PCIe 3.0 x1 , 1 (total) / 1 (free) x PCIe 3.0 x16 (x4 mode) , 1 (total) / 1 (free) x PCIe 3.0 x16 (75W max power)
2 x USB 2.0 , 4 x USB 3.2 Gen 1 (2 front, 2 rear) (one of them is fast-charging) , 4 x USB 3.2 Gen 2 (2 front, 2 rear) , 1 x USB-C 3.2 Gen 2 (1 in front) , 2 x DisplayPort , 1 x headphones/microphone (1 in front) (CTIA headset support) , 1 x audio line-out , 1 x LAN (Gigabit Ethernet) , 1 x VGA
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
ACPI, CCC, RoHS, WEEE, Common Criteria EAL4+, CECP, SEPA, low halogen
Power supply
Power Provided
260 Watt
80 PLUS Certification
80 PLUS Platinum
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Windows 10 Pro 64-bit Edition English
TCO Certified
ENERGY STAR Certified
33.8 cm
30.8 cm
10 cm
6.13 kg
Shipping Width
39.9 cm
Shipping Depth
49.9 cm
Shipping Height
23 cm
Shipping Weight
9 kg
10 °C
35 °C
10 - 90% (non-condensing)
Warranties (8)
G6L3 HP 3 Year NBD On-Site Optional Customer Self Repair Desktop/Workstation Only Hardware Service In Stock £19.26
G6L3 HP Care Pack Next Business Day HW Support Post Warranty Extended Service Agreement 1 Year On-Site In Stock £14.50
G6L3 HP Care Pack Next Business Day Hardware Support Extended Service Agreement 5 Years On-Site In Stock £73.94
G6L3 HP Care Pack NBD Hardware Support with Disk Retention Extended Service Agreement 3 Years On-Site In Stock £26.21
G6L3 HP Care Pack NBD HW Support w/ Defective Media Retention Extended Service Agreement 4 Years On-Site In Stock £52.97
G6L3 HP Care Pack NBD Hardware Support with Disk Retention Extended Service Agreement 5 Years On-Site In Stock £91.49
G6L3 HP Care Pack Premium Care Service Extended Service Agreement 3 Years On-Site In Stock £62.60
G6L3 HP 3 Year Premium Care Desktop In Stock £77.04
Monitors (7)
G6L3 HP EliteDisplay E243m 23.8" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor In Stock £203.04
G6L3 HP EliteDisplay E273m 27" 1920x1080 5ms VGA HDMI DisplayPort USB-C IPS LED Monitor In Stock £233.33
G6L3 HP DreamColour 31.1" 4096x2160 10ms 2xHDMI 2xDisplayPort USB-C LED Monitor In Stock £2,821.06
G6L3 HP Z38c 37.5" 3840x1600 5ms HDMI DisplayPort USB-C Curved IPS LED Monitor In Stock £798.42
G6L3 HP P22h G4 21.5" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor In Stock £180.00
G6L3 HP E23 G4 23" 1920x1080 5ms USB VGA HDMI FHD Monitor In Stock £199.16
G6L3 HP E 24" G4 WUXGA 1920 x 1200 LED Backlit Monitor In Stock £191.77
Keyboards and Mice (1)
G6L3 HP Wireless Premium Keyboard In Stock £48.25
Other bundles (4)
G6L3 HPE DisplayPort To VGA Adapter In Stock £19.80
G6L3 HP Display Port to VGA Adapter In Stock £19.80
G6L3 HP Keyed Cable Lock 10mm In Stock £27.41
G6L3 HP USB-C to DisplayPort Adapter In Stock £23.53
Storage Type: SSD
Type: Personal computer
Case Style: Small form factor
Optical Storage: DVD-Writer
Brand: HP
Price Range Ex VAT: £750 - £1000
