Powered for the enterprise, the HP EliteDesk 800 is a secure and manageable PC featuring advanced performance, and configurability in a space saving, stylishly redesigned chassis for the modern workplace.
Let nothing stand in your way
Power through your day with Windows 10 Pro and the powerful HP EliteDesk 800 SFF with built-in security, collaboration, and connectivity. -
Self-healing safeguard
Start with a genuine HP BIOS every time. HP Sure Start Gen3 monitors in-memory BIOS, recovers the platform without user or admin intervention, restores the BIOS to a custom state, and is enterprise ready for centralized management. -
Super secure. Super protected
Keep data out of reach and defend against theft, attacks, and unauthorized users with HP Client Security Suite Gen3. -
Get PC images right the first time
ITDMs can quickly help create, improve, and secure custom Windows images with HP Image Assistant. -
Speed up the basics of IT management
The HP Manageability Integration Kit helps speed up image creation and management of hardware, BIOS, and security through Microsoft SCCM. -
Built-in durability
Rest easy with a PC that goes the distance and is designed to pass HP Total Test Process and MIL-STD 810G testing.
- HP EliteDesk 800 G3 - SFF - Core i7 6700 3.4 GHz - vPro - 8 GB - SSD 256 GB - UK
- Personal computer - small form factor
- Platform Technology
- Intel vPro Platform
- Localisation
- Processor
- Intel Core i7 (6th Gen) 6700 / 3.4 GHz (, up to 4 GHz, (Quad-Core)
- Processor Socket
- LGA1151 Socket
- Processor Main Features
- Hyper-Threading Technology, Intel Turbo Boost Technology 2, Intel Smart Cache
- Cache Memory
- 8 MB
- Cache Per Processor
- 8 MB
- RAM
- 8 GB (installed) / 64 GB (max) - DDR4 SDRAM - non-ECC
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- SSD 256 GB - PCI Express - M.2 2280 - NVM Express (NVMe), triple-level cell (TLC)
- Optical Storage
- DVD-Writer
- Graphics Controller
- Intel HD Graphics 530 Dynamic Video Memory Technology
- Audio Output
- Stereo
- Networking
- 1GbE
- Keyboard
- UK
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Windows 10 Pro 64-bit Edition
- Software Included
- Skype, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Hotkey Support, HP Systems Software Manager, Windows Defender, HP Velocity, HP Secure Erase, HP Client Catalog, HP Driver Packs, HP BIOS Config Utility, HP JumpStart, HP Noise Cancellation, HP Client Security Suite Gen3, HP Notifications, HP Manageability & Integration Kit
- 38.8 cm x 30.8 cm x 10 cm
- 5.31 kg
- Limited warranty - parts and labour - 3 years - on-site
- Personal computer
- Product Form Factor
- Small form factor
- Embedded Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 3.4 GHz
- Max Turbo Speed
- 4 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- CPU Socket
- LGA1151 Socket
- Chipset Type
- Intel Q270
Cache Memory
- Installed Size
- 8 MB
- 8 MB
RAM
- Installed Size
- 8 GB / 64 GB (max)
- Technology
- Effective Memory Speed
- 2133 MHz
- Rated Memory Speed
- 2400 MHz
- Form Factor
- DIMM 288-pin
- Slots
- 4 (Total) / 3 (empty)
- Unbuffered
- Configuration Features
- 1 x 8 GB
Hard Drive
- SSD - M.2 2280
- Capacity
- 1 x 256 GB
- Interface Type
- PCI Express
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
Optical Storage
- DVD-Writer
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Video Interfaces
- DisplayPort
- HDCP Compatible
Audio Output
- Sound Output Mode
- Stereo
- Max Sampling Rate
- 192 kHz
- High Definition Audio
Input Device
- Mouse, keyboard
Keyboard
- Keyboard Name
- HP Business Slim Keyboard
- Interface
- USB
- Localization & Layout
- UK
Mouse
- Technology
- Optical
- Interface
- USB
- Ethernet Controller
- Intel I219-LM
- Data Link Protocol
- IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3az
- Bays
- 2 (total) / 2 (free) x internal 3.5" x 1/3H , 1 (total) / 1 (free) x external 5.25" Slim Line , 1 (total) / 1 (free) x internal 2.5" x 1/8H
- Slots
- 1 (total) / 1 (free) x M.2 Card - 2230 (x1 mode) , 1 (total) / 0 (free) x M.2 Card - 2280 (x4 mode) , 2 (total) / 2 (free) x PCIe 3.0 x1 - low-profile , 1 (total) / 1 (free) x PCIe 3.0 x16 - low-profile (x4 mode) , 1 (total) / 1 (free) x PCIe 3.0 x16 - low-profile
- 6 x USB 3.1 Gen 1 (2 front, 4 rear) , 1 x USB-C 3.1 Gen 1 (1 in front) (charging) , 1 x headphones/microphone (1 in front) , 2 x DisplayPort , 1 x LAN (Gigabit Ethernet) , 1 x headphones (1 in front) , 1 x audio line-out , 1 x audio line-in , 4 x USB 2.0 (2 front, 2 rear) (two of them with wake functionality, one of them is fast-charging) , 1 x HDMI
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- ACPI, CCC, Common Criteria EAL4+, CECP, SEPA, low halogen
- Power supply
- Voltage Required
- Power Provided
- 180 Watt
- 80 PLUS Certification
- 80 PLUS Platinum
- Efficiency
- 93%
- Power Factor Correction
- Yes (active)
Operating System / Software
- OS Provided
- Windows 10 Pro 64-bit Edition English
- Software
- 38.8 cm
- 30.8 cm
- 10 cm
- 5.31 kg
- 10 °C
- 35 °C
- 10 - 90% (non-condensing)
Warranties (7)
HP 3 Year NBD On-Site Optional Customer Self Repair Desktop/Workstation Only Hardware Service | In Stock | £33.26 |
HP Care Pack Next Business Day HW Support Post Warranty Extended Service Agreement 1 Year On-Site | In Stock | £14.86 |
HP Care Pack Next Business Day Hardware Support Extended Service Agreement 5 Years On-Site | In Stock | £50.54 |
HP Care Pack NBD Hardware Support with Disk Retention Extended Service Agreement 3 Years On-Site | In Stock | £33.69 |
HP Care Pack NBD HW Support w/ Defective Media Retention Extended Service Agreement 4 Years On-Site | In Stock | £41.17 |
HP Care Pack NBD Hardware Support with Disk Retention Extended Service Agreement 5 Years On-Site | In Stock | £70.47 |
HP Care Pack Next Business Day HW Support Extended Service Agreement 4 Year On-Site - Desktop Only | In Stock | £25.34 |
Monitors (3)
HP DreamColour 31.1" 4096x2160 10ms 2xHDMI 2xDisplayPort USB-C LED Monitor | In Stock | £2,821.06 |
HP E23 G4 23" 1920x1080 5ms USB VGA HDMI FHD Monitor | In Stock | £157.28 |
HP E 24" G4 WUXGA 1920 x 1200 LED Backlit Monitor | In Stock | £144.44 |
Other bundles (4)
HPE DisplayPort To VGA Adapter | In Stock | £13.72 |
HP USB-C To VGA Adapter | In Stock | £22.68 |
HP USB-C to DisplayPort Adapter | In Stock | £23.53 |
HP USB-C to HDMI 2.0 Adapter | In Stock | £47.06 |
