Powered for the enterprise, the high-performance HP EliteDesk 800 SFF features superb expandability and strong security required by today's high-productivity workforce in a stylish space-saving chassis designed for the modern workplace.
Let nothing stand in your way
Power through your day with Windows 10 Pro and the powerful security, collaboration and connectivity features from HP. -
HP Sure Sense
Malware is evolving rapidly and traditional antivirus can't always recognize new attacks. Protect your PC against never-before-seen attacks with HP Sure Sense, which uses deep learning AI to provide exceptional protection against advanced malware. -
Protect critical security processes
Keep your critical applications and processes running even if malware tries to shut them down with the self-healing protection of HP Sure Run. -
Browse confidently
Help protect your PC from websites and read only Microsoft Office and PDF attachments with embedded malware, ransomware, or viruses with hardware-enforced security from HP Sure Click.
- HP EliteDesk 800 G5 - SFF - Core i7 9700 3 GHz - vPro - 16 GB - SSD 512 GB - UK
- Personal computer - small form factor
- Platform Technology
- Intel vPro Platform
- Localisation
- Processor
- Intel Core i7 (9th Gen) 9700 / 3 GHz (, up to 4.7 GHz, (8-core)
- Processor Socket
- LGA1151 Socket
- Processor Main Features
- Intel Turbo Boost Technology 2, Intel Smart Cache
- Cache Memory
- 12 MB
- Cache Per Processor
- 12 MB
- RAM
- 16 GB (installed) / 128 GB (max) - DDR4 SDRAM
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- SSD 512 GB - PCI Express 3.0 - M.2 2280 - NVM Express (NVMe)
- SSD Cache
- 3D Xpoint (Optane) - 16 GB
- Optical Storage
- DVD-Writer
- Card Reader
- 5 in 1
- Graphics Controller
- Intel UHD Graphics 630 Dynamic Video Memory Technology
- Audio Output
- Stereo
- Networking
- 1GbE
- Keyboard
- UK
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Windows 10 Pro 64-bit Edition
- Software Included
- HP Recovery Manager, HP Support Assistant, HP Hotkey Support, Windows Defender, HP Secure Erase, HP Drive Packs (free download), HP Client Catalog, HP BIOS Config Utility, HP Setup Integrated OOBE, HP JumpStart, HP PC Hardware Diagnostics, HP Noise Cancellation, HP System Software Manager, HP Wireless Wakeup, HP Manageability & Integration Kit Gen3 (free download), HP BIOSphere Gen5, HP Privacy Settings, HP Client Security Suite Gen5, HP Cloud Recovery
- 30.8 cm x 33.8 cm x 10 cm
- 6.13 kg
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 3 years - on-site
- Personal computer
- Product Form Factor
- Small form factor
- Embedded Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 3 GHz
- Max Turbo Speed
- 4.7 GHz
- Number of Cores
- 8-core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- CPU Socket
- LGA1151 Socket
- Chipset Type
- Intel Q370
Cache Memory
- Installed Size
- 12 MB
- 12 MB
RAM
- Installed Size
- 16 GB / 128 GB (max)
- Technology
- DDR4 SDRAM
- Effective Memory Speed
- 2666 MHz
- Rated Memory Speed
- 2666 MHz
- Form Factor
- DIMM 288-pin
- Slots
- 4 (Total) / 3 (empty)
- Unbuffered
- Configuration Features
- 1 x 16 GB
Hard Drive
- SSD - M.2 2280
- Capacity
- 1 x 512 GB
- SSD Cache
- Interface Type
- PCI Express 3.0
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
- Channel Qty
- 3
Optical Storage
- DVD-Writer
Card Reader
- 5 in 1 card reader
- Supported Flash Memory Cards
- SD Memory Card, SDHC Memory Card, SDXC Memory Card, SDHC UHS-I Memory Card, SDXC UHS-I Memory Card, SDHC UHS-II Memory Card, SDXC UHS-II Memory Card
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Video Interfaces
- DisplayPort
- HDCP Compatible
Audio Output
- Sound Output Mode
- Stereo
- Max Sampling Rate
- 192 kHz
- High Definition Audio
Input Device
- Mouse, keyboard
Keyboard
- Keyboard Name
- HP Business Slim Keyboard
- Interface
- USB
- Localization & Layout
- UK
Mouse
- Technology
- Optical
- Interface
- USB
- Ethernet Controller
- Intel I219-LM
- Data Link Protocol
- IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3az
- Bays
- 1 (total) / 1 (free) x internal 2.5" , 2 (total) / 2 (free) x internal 3.5" , 1 (total) / 1 (free) x external 5.25" Slim Line
- Slots
- 1 (total) / 1 (free) x M.2 Card - 2230 (x1 mode) , 2 (total) / 1 (free) x M.2 Card - 2230/2280 (x4 mode) , 2 (total) / 2 (free) x PCIe 3.0 x1 , 1 (total) / 1 (free) x PCIe 3.0 x16 (x4 mode) , 1 (total) / 1 (free) x PCIe 3.0 x16
- 2 x USB 3.1 Gen 1 , 4 x USB 3.1 Gen 2 (2 front, 2 rear) , 2 x DisplayPort , 1 x headphones/microphone (1 in front) , 1 x headphones (1 in front) , 1 x LAN (Gigabit Ethernet) , 1 x USB-C 3.1 Gen 2 (1 in front) (charging) , 1 x audio line-in , 1 x audio line-out , 4 x USB 2.0 (2 front, 2 rear) (two of them with wake functionality, one of them is fast-charging)
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- ACPI, CCC, RoHS, WEEE, Common Criteria EAL4+, CECP, SEPA, low halogen
- Power supply
- Voltage Required
- Power Factor Correction
- Yes (active)
Operating System / Software
- OS Provided
- Windows 10 Pro 64-bit Edition English
- Software
Sustainability Information
- ENERGY STAR Certified
- 30.8 cm
- 33.8 cm
- 10 cm
- 6.13 kg
- Shipping Width
- 39.9 cm
- Shipping Depth
- 49.9 cm
- Shipping Height
- 23 cm
- Shipping Weight
- 9 kg
- 5 °C
- 35 °C
- 5 - 90%
Warranties (6)
HP 3 Year NBD On-Site Optional Customer Self Repair Desktop/Workstation Only Hardware Service | In Stock | £33.26 |
HP Care Pack Next Business Day HW Support Post Warranty Extended Service Agreement 1 Year On-Site | In Stock | £14.86 |
HP Care Pack Next Business Day Hardware Support Extended Service Agreement 5 Years On-Site | In Stock | £50.54 |
HP Care Pack NBD Hardware Support with Disk Retention Extended Service Agreement 3 Years On-Site | In Stock | £33.69 |
HP Care Pack NBD HW Support w/ Defective Media Retention Extended Service Agreement 4 Years On-Site | In Stock | £41.17 |
HP Care Pack NBD Hardware Support with Disk Retention Extended Service Agreement 5 Years On-Site | In Stock | £70.47 |
Monitors (3)
HP DreamColour 31.1" 4096x2160 10ms 2xHDMI 2xDisplayPort USB-C LED Monitor | In Stock | £2,821.06 |
HP E23 G4 23" 1920x1080 5ms USB VGA HDMI FHD Monitor | In Stock | £148.74 |
HP E 24" G4 WUXGA 1920 x 1200 LED Backlit Monitor | In Stock | £144.44 |
Keyboards and Mice (1)
HP Premium Wireless Mouse | In Stock | £38.00 |
Other bundles (9)
HPE DisplayPort To VGA Adapter | In Stock | £13.72 |
HP USB-C To VGA Adapter | In Stock | £22.68 |
HP USB-C to DisplayPort Adapter | In Stock | £23.53 |
HP USB-C to HDMI 2.0 Adapter | In Stock | £47.06 |
APC BACK-UPS BE650G2-UK 650VA 230V | In Stock | £106.61 |
APC BACK-UPS BE850G2-UK 850VA 230V USB | In Stock | £110.10 |
APC BACK UPS PRO BR650MI 650VA 6 Outlets | In Stock | £140.55 |
APC BACK UPS PRO BR900MI 900VA 6 Outlets | In Stock | £195.26 |
APC BACK-UPS CS 325VA 230V | In Stock | £70.14 |
