The desktop has evolved. Packed with integrated enterprise-class performance, security and manageability features, this is HP's smallest business desktop yet. Efficiently crafted, the HP Desktop Mini will fit almost any work space.
See it. Use it
HP PageLift automatically enhances captured documents and images. -
Share your connection wirelessly
HP Wireless Hotspot lets you easily share your internet connection with up to five devices. -
Incredible audio experience
DTS Studio Sound Audio software helps bring work to life. -
Say hello
You're ready for web chats with Skype pre-installed.
- HP EliteDesk 800 G1 - mini desktop - Core i5 4570T 2.9 GHz - vPro - 4 GB - HDD 500 GB - TAA Compliant
- Personal computer - mini desktop - administrator password, power-on password, USB port control, DriveLock, HP Disk Sanitizer, HP File Sanitizer, Intel Identity Protection Technology (Intel IPT), Setup Password
- Platform Technology
- Intel vPro Platform
- Localisation
- Processor
- Intel Core i5 (4th Gen) 4570T / 2.9 GHz (, up to 3.6 GHz, (Dual-Core)
- Processor Main Features
- Hyper-Threading Technology, Intel Turbo Boost Technology 2
- Cache Memory
- 4 MB
- Cache Per Processor
- 4 MB
- RAM
- 4 GB (installed) / 16 GB (max) - DDR3 SDRAM - non-ECC - PC3-12800
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- HDD 500 GB - SATA 6Gb/s - 7200 rpm
- Optical Storage
- No optical drive
- Graphics Controller
- Intel HD Graphics 4600 Dynamic Video Memory Technology
- Audio Output
- Stereo - integrated
- Networking
- 1GbE, 802.11a, 802.11b/g/n
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 8.1 Pro) + Windows 8.1 Pro Licence
- Software Included
- Cyberlink PowerDVD, CyberLink Power2Go, Adobe Flash Player, HP Recovery Disc Creator, Skype, Windows 7 Professional 64-bit recovery DVD, HP Support Assistant, Bing Toolbar, HP ePrint, PDF Complete Corporate Edition, Microsoft Internet Explorer 10, Device Access Manager, HP Client Security, HP PageLift, HP Secure Erase, HP File Sanitizer, Box, Drive Encryption, HP Disk Sanitizer External Edition (free download)
- 17.5 cm x 17.7 cm x 3.4 cm
- 1.3 kg
- TAA Compliant
- Environmental Standards
- ENERGY STAR Qualified
- Personal computer
- Recommended Use
- Small business, corporate business
- Product Form Factor
- Mini desktop
- Built-in Devices
- Solenoid hood lock
- Embedded Security
- Trusted Platform Module (TPM 1.2) Security Chip
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 2.9 GHz
- Max Turbo Speed
- 3.6 GHz
- Number of Cores
- Dual-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- Chipset Type
- Intel Q87
Cache Memory
- Installed Size
- 4 MB
- 4 MB
RAM
- Installed Size
- 4 GB / 16 GB (max)
- Technology
- Effective Memory Speed
- 1600 MHz
- Rated Memory Speed
- 1600 MHz
- Memory Specification Compliance
- PC3-12800
- Form Factor
- SO-DIMM 204-pin
- Slots
- 2 (Total) / 1 (empty)
- Unbuffered, dual channel memory architecture
- Configuration Features
- 1 x 4 GB
Hard Drive
- HDD
- Capacity
- 1 x 500 GB
- Interface Type
- SATA 6Gb/s
- Spindle Speed
- 7200 rpm
Storage Controller
- 1 x SATA - integrated
- Controller Interface Type
- SATA 6Gb/s
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Graphics Processor
- Video Interfaces
- VGA, DisplayPort
- HDCP Compatible
Audio Output
- Integrated
- Sound Output Mode
- Stereo
- Max Sampling Rate
- 192 kHz
- High Definition Audio, DTS Studio Sound
Input Device
- Mouse, keyboard
Keyboard
- Interface
- USB
Mouse
- Interface
- USB
- Ethernet Controller
- Intel I217-LM
- Wireless LAN Supported
- Wireless NIC
- Intel Wireless-N 7260
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
- Remote Management Protocol
- ASF 2.0
- Wake on LAN (WoL), PXE support, auto-uplink (auto MDI/MDI-X)
- IEEE 802.2, IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.3az
- Bays
- 1 (total) / 0 (free) x internal 2.5"
- Slots
- 2 (total) / 1 (free) x SO-DIMM 204-pin , 2 (total) / 1 (free) x M.2 Card , 1 (total) / 0 (free) x CPU
- 6 x USB 3.0 (2 front, 4 rear) , 1 x headphones (1 in front) , 1 x microphone (1 in front) , 1 x VGA , 2 x DisplayPort , 1 x LAN (Gigabit Ethernet) , 1 x audio line-out , 1 x audio line-in
- Included Accessories
- Vertical stand
- Administrator password, power-on password, USB port control, DriveLock, HP Disk Sanitizer, HP File Sanitizer, Intel Identity Protection Technology (Intel IPT), Setup Password
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- ACPI, RoHS, WEEE
- TAA Compliant
- Power adapter
- Voltage Required
- Power Provided
- 65 Watt
- Efficiency
- 87%
- Power Factor Correction
- Yes (active)
Operating System / Software
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8.1 Pro) + Windows 8.1 Pro Licence
- OS Certified
- SUSE Linux Enterprise Desktop 11
- Software
Sustainability Information
- ENERGY STAR Certified
- 17.5 cm
- 17.7 cm
- 3.4 cm
- 1.3 kg
- 10 °C
- 35 °C
- 10 - 90% (non-condensing)
