HP EliteDesk 800 G1 DM Intel Core i3-4160 4GB 128GB SSD Windows 7 Professional 64-bit
Quicklinx: BC3YWS00 Mfr#: J7D10EA#ABU
Processor Type: Core i3
Operating System: Microsoft Windows 7 Professional 64-bit Edition
Installed Memory: 4GB
Hard Drive Capacity: 128GB
Storage Type: SSD
  • Core i3
  • IEEE 802.11n
  • Microsoft Windows 7 Professional 64-bit Edition
£660.00 ex VAT
£792.00 inc VAT
The desktop has evolved. Packed with integrated enterprise-class performance, security and manageability features, this is HP's smallest business desktop yet. Efficiently crafted, the HP Desktop Mini will fit almost any work space.
  • Big power
    Smaller than some desk phones, this Desktop Mini can fit almost anywhere vertically or horizontally. The clean, easily serviceable design with integrated wireless antenna allows flexible deployment options to help optimize the workspace.Be up to 35% more productive by adding up to three independent displays using the integrated DisplayPort with Multi-Stream video outputs.Set up the HP EliteDesk 800 G1 Desktop Mini in almost any spot or easily attach to several optional peripheral devices using the integrated VESA mount.The HP EliteDesk 800 G1 Desktop Mini is designed to undergo MIL-STD 810G tests. Prior to that HP performed 115,000 hours of our own testing and end-to-end diagnostics to help ensure you get confidence built right in.Easily service the HP EliteDesk 800 G1 Desktop Mini. A single thumb screw provides fast access to clearly identifiable and serviceable components.
  • Full EliteDesk functionality
    Keep productivity high and downtime low with HP BIOSphere firmware-level automation. Your PCs have extra protection thanks to automatic updates and security checks. Enjoy customization that allows your PC to evolve with your business.Take advantage of new drive technology with an optional M.2 PCI3e solid state hard drive module, the internal 2.5" SSD, or dual drive configurations for more local storage.Power through your day with speed and performance. Get the latest in processing technology with your choice of 4th generation Intel Core processors with optional Intel vPro technology.Enjoy easy and simple integration into your IT environment and ongoing maintenance with HP Client Management Solutions such as optional LANDesk.Help reduce the burden on IT with long life cycles, stable images and drivers along with HP's business services and support programs.
  • Heavy security, exceptionally managed
    HP BIOSphere boosts security and keeps mission-critical data and systems under lock and key with customizable authentication and BIOS-level passwords.HP Secure Erase. Removes the contents of a hard drive for repurposing or reassignment.Get extra protection with secured storage and ensured platform integrity thanks to the Trusted Platform Module security chip used by the BIOS and the Operating System.Keep sensitive information in safe hands. HP Trust Circles helps protect your data by ensuring that only assigned contacts can access critical files.
  • Green with envy
    The low energy consumption levels of this ENERGY STAR qualified and EPEAT Gold certified PC supports 24/7 operations. Consuming less than 8W of power at idle your Desktop Mini can be always on and always updated.
HP EliteDesk 800 G1 - mini desktop - Core i3 4160T 3.1 GHz - 4 GB - 128 GB - UK
Personal computer - mini desktop
1 x Intel Core i3 (4th Gen) 4160T / 3.1 GHz (Dual-Core)
Processor Main Features
Hyper-Threading Technology
Cache Memory
3 MB
Cache Per Processor
3 MB
RAM
4 GB (installed) / 16 GB (max) - DDR3 SDRAM - non-ECC - PC3-12800
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
1 x SSD 128 GB - SATA
Optical Storage
No optical drive
Graphics Controller
Intel HD Graphics 4400 Dynamic Video Memory Technology
Audio Output
Stereo - integrated
GigE, 802.11a, 802.11b/g/n
Keyboard
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 8.1 Pro) + Windows 8.1 Pro Licence
17.5 cm x 17.7 cm x 3.4 cm
1.3 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years - on-site
Personal computer
Product Form Factor
Mini desktop
Built-in Devices
Speaker
Embedded Security
Trusted Platform Module (TPM 1.2) Security Chip
Processor / Chipset
CPU
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
Chipset Type
Intel Q87 Express
Cache Memory
Installed Size
3 MB
Cache Per Processor
3 MB
RAM
Installed Size
4 GB / 16 GB (max)
Effective Memory Speed
1600 MHz
Rated Memory Speed
1600 MHz
Memory Specification Compliance
PC3-12800
SO-DIMM 204-pin
Slots
2 (Total) / 1 (empty)
Unbuffered, dual channel memory architecture
Configuration Features
1 x 4 GB
Hard Drive
SSD
1 x 128 GB
Interface Type
SATA
Storage Controller
1 x SATA - integrated
Controller Interface Type
SATA 6Gb/s
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
Video Interfaces
VGA, DisplayPort
HDCP Compatible
Audio Output
Integrated
Sound Output Mode
Stereo
Max Sampling Rate
192 kHz
High Definition Audio, DTS Studio Sound
Input Device
Mouse, keyboard
Keyboard
Localization & Layout
Ethernet Controller
Intel I217-LM
Wireless LAN Supported
Wireless NIC
Intel Wireless-N 7260
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
Remote Management Protocol
ASF 2.0
Wake on LAN (WoL), PXE support, auto-uplink (auto MDI/MDI-X)
IEEE 802.2, IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.3az
Bays
1 (total) / 0 (free) x internal 2.5"
Slots
2 (total) / 1 (free) x SO-DIMM 204-pin , 2 (total) / 1 (free) x M.2 Card , 1 (total) / 0 (free) x CPU
6 x USB 3.0 (2 front, 4 rear) , 1 x headphones (1 in front) , 1 x microphone (1 in front) , 1 x VGA , 2 x DisplayPort , 1 x LAN (Gigabit Ethernet) , 1 x audio line-out , 1 x audio line-in
Administrator password, power-on password, USB port control, DriveLock, HP Disk Sanitizer, Intel Active Management Technology (iAMT), HP File Sanitizer, Intel Identity Protection Technology (Intel IPT), Setup Password
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
ACPI, RoHS, WEEE
TAA Compliant
Power adapter
Nominal Voltage
Power Provided
65 Watt
Efficiency
87%
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8.1 Pro) + Windows 8.1 Pro Licence - English
OS Certified
SUSE Linux Enterprise Desktop 11
Software
Cyberlink PowerDVD, CyberLink Power2Go, Adobe Flash Player, HP Recovery Disc Creator, Skype, Microsoft Security Essentials, HP Support Assistant, Bing Toolbar, HP ePrint, Foxit PhantomPDF Express, Microsoft Internet Explorer 10, Device Access Manager, HP Client Security, HP PageLift, HP File Sanitizer, Box, Drive Encryption, HP Disk Sanitizer External Edition (free download)
ENERGY STAR Certified
17.5 cm
17.7 cm
3.4 cm
1.3 kg
10 °C
35 °C
10 - 90% (non-condensing)
HP EliteDesk 800 G1 DM Intel Core i3-4160 4GB 128GB SSD Windows 7 Professional 64-bit Bundle deal on HP EliteDesk 800 G1 DM Intel Core i3-4160 4GB 128GB SSD Windows 7 Professional 64-bit
£843.16
saving £8.33
£759.17
Storage Type: SSD
Processor Model: I3-4160T
Type: Personal computer
Case Style: Desktop slimline
Display: no
Optical Storage: None
Brand: HP
Price Range Ex VAT: 500 - 750
