HP EliteDesk 705 G2 DM AMD A8-8600 4GB 500GB Windows 10 Professional 64-bit
Quicklinx: BZ3VWS00 Mfr#: T4J35EA#ABU
  • IEEE 802.11n
  • Bluetooth 4.0
  • Microsoft Windows 7 Professional 64-bit Edition
Space-saving and function-packed, the HP EliteDesk 705 Desktop Mini provides performance, security, manageability, and a unique portfolio of accessories to support your enterprise.
  • Discover the value of the Desktop Mini
    Create a feature packed solution to help your growing business meet performance, security, and manageability needs with the powerful HP EliteDesk 705 Desktop Mini.
  • Raise the performance bar
    Unlock the full potential of your PC with the latest AMD PRO A-Series APUs with AMD Radeon graphics. HP Pixel Sharp video filtering produces sharp and color-accurate images and videos, for crystal-clear video conferencing.
  • Bring big power to tight spaces
    Incorporate the HP EliteDesk Desktop Mini into your business utilizing innovative mounting, expansion, and security accessory options that help you create the right solution for your work space.
  • Security built in
    IT efficiency reigns supreme when it's backed by comprehensive security solutions, including HP BIOSphere with Sure Start, and HP Client Security.
HP EliteDesk 705 G2 - mini desktop - A8 PRO-8600B 1.6 GHz - 4 GB - 500 GB
Personal computer - mini desktop
1 x AMD A8 PRO-8600B / 1.6 GHz (3 GHz) (Quad-Core)
Cache Memory
2 MB L2 Cache
Cache Per Processor
2 MB
RAM
4 GB (installed) / 16 GB (max) - DDR3L SDRAM - non-ECC - PC3-12800
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
1 x 500 GB - SATA 6Gb/s - 7200 rpm
Optical Storage
No optical drive
Graphics Controller
AMD Radeon R6
Audio Output
Stereo
GigE, 802.11a, 802.11b/g/n, Bluetooth 4.0, 802.11ac
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 10 Pro) + Windows 10 Pro Licence
17.5 cm x 17.7 cm x 3.4 cm
1.3 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years - on-site - response time: next business day
Personal computer
Product Form Factor
Mini desktop
Embedded Security
Trusted Platform Module (TPM 1.2) Security Chip
Processor / Chipset
CPU
Max Turbo Speed
3 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
Chipset Type
AMD A78 FCH
Cache Memory
Installed Size
L2 Cache - 2 MB
Cache Per Processor
2 MB
RAM
Installed Size
4 GB / 16 GB (max)
Effective Memory Speed
1600 MHz
Rated Memory Speed
1600 MHz
Memory Specification Compliance
PC3-12800
SO-DIMM 204-pin
Slots
2 (Total) / 1 (empty)
Unbuffered, dual channel memory architecture
Configuration Features
1 x 4 GB
Hard Drive
HDD
1 x 500 GB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
AMD Radeon R6
Video Interfaces
VGA, DisplayPort
Audio Output
Sound Output Mode
Stereo
Max Sampling Rate
192 kHz
High Definition Audio, DTS Studio Sound
Ethernet Controller
Broadcom BCM5762
Wireless LAN Supported
Wireless NIC
Intel Dual Band Wireless-AC 3165
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.0, IEEE 802.11ac
Remote Management Protocol
ASF 2.0
Wake on LAN (WoL), PXE support, auto-uplink (auto MDI/MDI-X)
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.1as, IEEE 802.11n, IEEE 802.3az, Bluetooth 4.0, IEEE 802.11ac
Bays
1 (total) / 0 (free) x internal 2.5"
Slots
2 (total) / 1 (free) x SO-DIMM 204-pin , 1 (total) / 0 (free) x CPU , 2 (total) / 1 (free) x M.2 Card
2 x USB 2.0 , 4 x USB 3.0 (2 front, 2 rear) , 1 x VGA , 1 x DisplayPort , 1 x headphones (1 in front) , 1 x headphones/microphone (1 in front) , 1 x LAN (Gigabit Ethernet)
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
VESA Mounting Interface
100 x 100 mm
ACPI, Energy-using Products (EuP) Lot 6, Common Criteria EAL4+
TAA Compliant
Power adapter
Nominal Voltage
Power Provided
65 Watt
Efficiency
89%
Operating System / Software
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro) + Windows 10 Pro Licence - English
Software
CyberLink Power2Go, HP Recovery Disc Creator, Skype, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, HP ePrint, CyberLink PowerDVD BD Edition, Foxit PhantomPDF Express, HP PC Hardware Diagnostics UEFI, HP Systems Software Manager (free download), HP Secure Erase, HP Security Manager, Drive Encryption, HP BIOSphere, HP BIOS Configuration Utility (free download), HP Client Catalogue (free download), HP Pixel Sharp, HP Driver Packs, HP CIK for Microsoft SCCM (free download)
ENERGY STAR Certified
17.5 cm
17.7 cm
3.4 cm
1.3 kg
10 °C
35 °C
10 - 90% (non-condensing)
