HP EliteDesk 705 G2 DM AMD A4 PRO-7350 4GB 500GB Windows 7 Professional 64-bit
Quicklinx: BC4WWS00 Mfr#: K2W34AW#ABU
Processor Type: A4
Operating System: Microsoft Windows 7 Professional 64-bit Edition
Installed Memory: 4GB
Hard Drive Capacity: 500GB, 500GB
Storage Type: HDD
  • Microsoft Windows 7 Professional 64-bit Edition
£405.78 ex VAT
£486.93 inc VAT
The desktop has evolved. The space saving and functionality-packed HP EliteDesk 705 G1 Desktop Mini includes new AMD PRO A-Series APUs with revolutionary HSA technology that provides a perfect balance of power and performance. That's a smart investment.
  • Big power
    Experience true desktop power with the HP EliteDesk 705 G1 Desktop Mini that can fit almost anywhere vertically or horizontally. The clean, easily serviceable design with integrated wireless antenna allows flexible deployment options to help optimize the workspace.
  • Pure performance
    Unlock the full potential of your PC. The latest AMD PRO A-Series APUs with HSA technology that helps maximize performance by intelligently prioritizing system tasks between the CPU and GPU.
  • Security made simple
    Keep it secure, keep it simple. IT efficiency reigns supreme when it's backed by a full portfolio of security solutions, including HP BIOSphere and HP Client Security.
  • Simplify device management
    Reduce the complexity of administration. HP Client Management and DASH compliant devices help you easily and affordably manage assets.
  • Features
    Keep all your work in plain sight. Be up to 35% more productive by adding up to three independent displays using the integrated VGA and two DisplayPorts.Rest easy with a PC that has endured 115,000 hours of HP's Total Test Process and is designed to undergo MIL-STD 810G tests.Easily service the HP EliteDesk 705 G1 Desktop Mini. A single thumb screw provides fast access to clearly identifiable and serviceable components.AMD APUs with AMD Radeon graphics deliver impressive performance and visually stunning graphics at an affordable price.Take advantage of new drive technology with an optional M.2 PCIe solid state hard drive module, an internal 2.5" SSD, or even dual drive configurations for more local storage.
HP EliteDesk 705 G1 - mini desktop - A4 PRO-7350B 3.4 GHz - 4 GB - 500 GB
Personal computer - mini desktop
1 x AMD A4 PRO-7350B / 3.4 GHz (3.8 GHz) (Dual-Core)
Cache Memory
L2 Cache
RAM
4 GB (installed) / 16 GB (max) - DDR3 SDRAM - non-ECC - PC3-12800
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
1 x 500 GB - SATA 6Gb/s - 7200 rpm
Optical Storage
No optical drive
Graphics Controller
AMD Radeon R5
Audio Output
Stereo - integrated
GigE
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 8.1 Pro) + Windows 8.1 Pro Licence
17.5 cm x 17.7 cm x 3.4 cm
1.3 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years - on-site
Personal computer
Product Form Factor
Mini desktop
Embedded Security
Trusted Platform Module (TPM 1.2) Security Chip
Processor / Chipset
CPU
Max Turbo Speed
3.8 GHz
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
Chipset Type
AMD A88X FCH
Cache Memory
Installed Size
L2 Cache
RAM
Installed Size
4 GB / 16 GB (max)
Effective Memory Speed
1600 MHz
Rated Memory Speed
1600 MHz
Memory Specification Compliance
PC3-12800
SO-DIMM 204-pin
Slots
2 (Total) / 1 (empty)
Unbuffered
Configuration Features
1 x 4 GB
Hard Drive
HDD
1 x 500 GB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA - integrated
Controller Interface Type
SATA 6Gb/s
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
AMD Radeon R5
Video Interfaces
VGA, DisplayPort
Audio Output
Integrated
Sound Output Mode
Stereo
Max Sampling Rate
192 kHz
High Definition Audio, DTS Studio Sound
Input Device
Keyboard
Keyboard
USB
Ethernet Controller
Broadcom BCM5762
Remote Management Protocol
ASF 2.0
Wake on LAN (WoL), PXE support, auto-uplink (auto MDI/MDI-X)
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.1as, IEEE 802.3az
Bays
1 (total) / 0 (free) x internal 2.5"
Slots
2 (total) / 1 (free) x SO-DIMM 204-pin , 1 (total) / 0 (free) x CPU , 2 (total) / 2 (free) x M.2 Card
6 x USB 3.0 (2 front, 4 rear) , 1 x VGA , 2 x DisplayPort , 1 x headphones (1 in front) , 1 x microphone (1 in front) , 1 x LAN (Gigabit Ethernet) , 1 x audio line-out
Administrator password, power-on password, USB port control, DriveLock, Setup Password, UEFI BIOS
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
ACPI
TAA Compliant
Power adapter
Nominal Voltage
Power Provided
120 Watt
Efficiency
87%
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8.1 Pro) + Windows 8.1 Pro Licence
Software
Cyberlink PowerDVD, CyberLink Power2Go, HP Recovery Disc Creator, Skype, Microsoft Security Essentials, HP Recovery Manager, HP Support Assistant, HP ePrint, Foxit PhantomPDF Express, HP Spare Key, HP Client Security, Device Access Manager with Just In Time Authentication, HP PageLift, HP File Sanitizer, Box.net 50GB storage, Drive Encryption, HP Manageability, HP Disk Sanitizer External Edition (free download)
ENERGY STAR Certified
17.5 cm
17.7 cm
3.4 cm
1.3 kg
10 °C
35 °C
10 - 90% (non-condensing)
HP EliteDesk 705 G2 DM AMD A4 PRO-7350 4GB 500GB Windows 7 Professional 64-bit Bundle deal on HP EliteDesk 705 G2 DM AMD A4 PRO-7350 4GB 500GB Windows 7 Professional 64-bit
£585.36
saving £2.42
£504.95
Processor Type: A4
Storage Type: HDD
Processor Model: A4 PRO-7350B
Type: Personal computer
Case Style: Desktop slimline
Display: no
Optical Storage: None
Brand: HP
Price Range Ex VAT: 300 - 500
