Space-saving and function-packed, the HP EliteDesk 705 Desktop Mini provides performance, security, manageability, and a unique portfolio of accessories to support your enterprise.
Discover the value of the Desktop Mini
Create a feature packed solution to help your growing business meet performance, security, and manageability needs with the powerful HP EliteDesk 705 Desktop Mini.
Raise the performance bar
Unlock the full potential of your PC with the latest AMD PRO A-Series APUs with AMD Radeon™ graphics. HP Pixel Sharp video filtering produces sharp and color-accurate images and videos, for crystal-clear video conferencing.
Bring big power to tight spaces
Incorporate the HP EliteDesk Desktop Mini into your business utilizing innovative mounting, expansion, and security accessory options that help you create the right solution for your work space.
Security built in
IT efficiency reigns supreme when it’s backed by comprehensive security solutions, including HP BIOSphere with Sure Start, and HP Client Security.
Create a feature packed solution to help your growing business meet performance, security, and manageability needs with the powerful HP EliteDesk 705 Desktop Mini. -
Unlock the full potential of your PC with the latest AMD PRO A-Series APUs with AMD Radeon graphics. HP Pixel Sharp video filtering produces sharp and color-accurate images and videos, for crystal-clear video conferencing. -
Incorporate the HP EliteDesk Desktop Mini into your business utilizing innovative mounting, expansion, and security accessory options that help you create the right solution for your work space. -
Security built in
IT efficiency reigns supreme when it's backed by comprehensive security solutions, including HP BIOSphere with Sure Start, and HP Client Security.
- HP EliteDesk 705 G2 - mini desktop - A6 PRO-8500B 1.6 GHz - 4 GB - HDD 500 GB - TAA Compliant
- Personal computer - mini desktop
- Localisation
- Processor
- AMD A6 PRO-8500B / 1.6 GHz (, up to 3 GHz, (Dual-Core)
- Cache Memory
- 1 MB L2 Cache
- Cache Per Processor
- 1 MB
- RAM
- 4 GB (installed) / 16 GB (max) - DDR3 SDRAM - non-ECC - PC3-12800
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- HDD 500 GB - SATA 6Gb/s - 7200 rpm
- Optical Storage
- No optical drive
- Graphics Controller
- AMD Radeon R5
- Audio Output
- Stereo
- Networking
- GigE, 802.11a, 802.11b/g/n, Bluetooth 4.0, Wi-Fi 5
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence
- Software Included
- CyberLink Power2Go, HP Recovery Disc Creator, Skype, Microsoft Security Essentials, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, CyberLink PowerDVD BD Edition, Foxit PhantomPDF Express, HP Systems Software Manager (free download), HP Secure Erase, HP Security Manager, Drive Encryption, HP BIOSphere, HP BIOS Configuration Utility (free download), HP Drive Packs (free download), HP Client Catalogue (free download), HP Pixel Sharp, HP CIK for Microsoft SCCM (free download)
- 17.5 cm x 17.7 cm x 3.4 cm
- 1.3 kg
- TAA Compliant
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 3 years - on-site
- Personal computer
- Product Form Factor
- Mini desktop
- Embedded Security
- Trusted Platform Module (TPM 1.2) Security Chip
- Localisation
Processor / Chipset
- CPU
- AMD A6 PRO-8500B
- Clock Speed
- 1.6 GHz
- Max Turbo Speed
- 3 GHz
- Number of Cores
- Dual-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- Chipset Type
- AMD A78 FCH
Cache Memory
- Installed Size
- L2 Cache - 1 MB
- 1 MB
RAM
- Installed Size
- 4 GB / 16 GB (max)
- Technology
- Effective Memory Speed
- 1600 MHz
- Rated Memory Speed
- 1600 MHz
- Memory Specification Compliance
- PC3-12800
- Form Factor
- SO-DIMM 204-pin
- Slots
- 2 (Total) / 1 (empty)
- Unbuffered
- Configuration Features
- 1 x 4 GB
Hard Drive
- HDD
- Capacity
- 1 x 500 GB
- Interface Type
- SATA 6Gb/s
- Spindle Speed
- 7200 rpm
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- AMD Radeon R5
- Video Interfaces
- VGA, DisplayPort
Audio Output
- Sound Output Mode
- Stereo
- Max Sampling Rate
- 192 kHz
- High Definition Audio, DTS Studio Sound
- Ethernet Controller
- Broadcom BCM5762
- Wireless LAN Supported
- Wireless NIC
- Intel Dual Band Wireless-AC 3165
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.0, IEEE 802.11ac
- Remote Management Protocol
- ASF 2.0
- Wake on LAN (WoL), PXE support, auto-uplink (auto MDI/MDI-X)
- IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.1as, IEEE 802.3az, Bluetooth 4.0, IEEE 802.11ac
- Bays
- 1 (total) / 0 (free) x internal 2.5" x 1/8H
- Slots
- 2 (total) / 1 (free) x SO-DIMM 204-pin , 1 (total) / 0 (free) x CPU , 2 (total) / 1 (free) x M.2 Card (x4 mode)
- 2 x USB 2.0 , 4 x USB 3.0 (2 front, 2 rear) , 1 x VGA , 2 x DisplayPort , 1 x headphones (1 in front) , 1 x headphones/microphone (1 in front) , 1 x LAN (Gigabit Ethernet)
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- VESA Mounting Interface
- 100 x 100 mm
- ACPI, RoHS, Common Criteria EAL4+
- TAA Compliant
- Power adapter
- Voltage Required
- Power Provided
- 65 Watt
- Efficiency
- 89%
Operating System / Software
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence - English
- Software
Sustainability Information
- ENERGY STAR Certified
- 17.5 cm
- 17.7 cm
- 3.4 cm
- 1.3 kg
- 10 °C
- 35 °C
- 10 - 90% (non-condensing)
Warranties (1)
HP Care Pack Next Business Day HW Support Post Warranty Extended Service Agreement 1 Year On-Site | In Stock | £14.86 |
Keyboards and Mice (1)
HP Premium Wireless Mouse | In Stock | £38.00 |
Other bundles (2)
HPE DisplayPort To VGA Adapter | In Stock | £13.72 |
HP USB-C to DisplayPort Adapter | In Stock | £23.53 |
