HP EliteDesk 705 G2 - A series A6 PRO-8500B 1.6 GHz - 4 GB - 500 GB
Quicklinx: CH5MWS00 Mfr#: T4J34EA#ABU
Processor Type: A6
Operating System: Microsoft Windows 7 Professional 64-bit Edition
Installed Memory: 4GB
Hard Drive Capacity: 500GB, 500GB
Storage Type: HDD
  • Bluetooth 4.0
  • Microsoft Windows 7 Professional 64-bit Edition
£498.39 ex VAT
£598.06 inc VAT
Space-saving and function-packed, the HP EliteDesk 705 Desktop Mini provides performance, security, manageability, and a unique portfolio of accessories to support your enterprise.
Discover the value of the Desktop Mini
Create a feature packed solution to help your growing business meet performance, security, and manageability needs with the powerful HP EliteDesk 705 Desktop Mini.
Raise the performance bar
Unlock the full potential of your PC with the latest AMD PRO A-Series APUs with AMD Radeon™ graphics. HP Pixel Sharp video filtering produces sharp and color-accurate images and videos, for crystal-clear video conferencing.
Bring big power to tight spaces
Incorporate the HP EliteDesk Desktop Mini into your business utilizing innovative mounting, expansion, and security accessory options that help you create the right solution for your work space.
Security built in
IT efficiency reigns supreme when it’s backed by comprehensive security solutions, including HP BIOSphere with Sure Start, and HP Client Security.
  • Discover the value of the Desktop Mini
  • Raise the performance bar
    Unlock the full potential of your PC with the latest AMD PRO A-Series APUs with AMD Radeon graphics. HP Pixel Sharp video filtering produces sharp and color-accurate images and videos, for crystal-clear video conferencing.
  • Bring big power to tight spaces
  • Security built in
    IT efficiency reigns supreme when it's backed by comprehensive security solutions, including HP BIOSphere with Sure Start, and HP Client Security.
HP EliteDesk 705 G2 - mini desktop - A6 PRO-8500B 1.6 GHz - 4 GB - 500 GB
Personal computer - mini desktop
1 x AMD A6 PRO-8500B / 1.6 GHz (3 GHz) (Dual-Core)
Cache Memory
1 MB L2 Cache
Cache Per Processor
1 MB
RAM
4 GB (installed) / 16 GB (max) DDR3 SDRAM - non-ECC - PC3-12800
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
1 x 500 GB - SATA 6Gb/s - 7200 rpm
Optical Storage
No optical drive
Graphics Controller
AMD Radeon R5
Audio Output
Stereo
GigE, Bluetooth 4.0, 802.11ac
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence
17.5 cm x 17.7 cm x 3.4 cm
1.3 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years - on-site
Personal computer
Product Form Factor
Mini desktop
Embedded Security
Trusted Platform Module (TPM 1.2) Security Chip
Processor / Chipset
CPU
Max Turbo Speed
3 GHz
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
Chipset Type
AMD A78 FCH
Cache Memory
Installed Size
L2 Cache - 1 MB
Cache Per Processor
1 MB
RAM
Installed Size
4 GB / 16 GB (max)
Effective Memory Speed
1600 MHz
Rated Memory Speed
1600 MHz
Memory Specification Compliance
PC3-12800
SO-DIMM 204-pin
Slots
2 (Total) / 1 (empty)
Unbuffered
Configuration Features
1 x 4 GB
Hard Drive
HDD
1 x 500 GB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
AMD Radeon R5
Video Interfaces
VGA, DisplayPort
Audio Output
Sound Output Mode
Stereo
Max Sampling Rate
192 kHz
High Definition Audio, DTS Studio Sound
Ethernet Controller
Broadcom BCM5762
Wireless LAN Supported
Wireless NIC
Intel Dual Band Wireless-AC 3165
Ethernet, Fast Ethernet, Gigabit Ethernet, Bluetooth 4.0, IEEE 802.11ac
Remote Management Protocol
ASF 2.0
Wake on LAN (WoL), PXE support, auto-uplink (auto MDI/MDI-X)
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.1as, IEEE 802.3az, Bluetooth 4.0, IEEE 802.11ac
Bays
1 (total) / 0 (free) x internal 2.5" x 1/8H
Slots
2 (total) / 1 (free) x SO-DIMM 204-pin , 1 (total) / 0 (free) x CPU , 2 (total) / 1 (free) x M.2 Card (x4 mode)
2 x USB 2.0 , 4 x USB 3.0 (2 front, 2 rear) , 1 x VGA , 2 x DisplayPort , 1 x headphones (1 in front) , 1 x headphones/microphone (1 in front) , 1 x LAN (Gigabit Ethernet)
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
VESA Mounting Interface
100 x 100 mm
ACPI, RoHS, Common Criteria EAL4+
TAA Compliant
Power adapter
Nominal Voltage
Power Provided
65 Watt
Efficiency
89%
Operating System / Software
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence - English
Software
CyberLink Power2Go, HP Recovery Disc Creator, Skype, Microsoft Security Essentials, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, CyberLink PowerDVD BD Edition, Foxit PhantomPDF Express, HP Systems Software Manager (free download), HP Secure Erase, HP Security Manager, Drive Encryption, HP BIOSphere, HP BIOS Configuration Utility (free download), HP Drive Packs (free download), HP Client Catalogue (free download), HP Pixel Sharp, HP CIK for Microsoft SCCM (free download)
ENERGY STAR Certified
17.5 cm
17.7 cm
3.4 cm
1.3 kg
10 °C
35 °C
10 - 90% (non-condensing)
HP EliteDesk 705 G2 - A series A6 PRO-8500B 1.6 GHz - 4 GB - 500 GB Bundle deal on HP EliteDesk 705 G2 - A series A6 PRO-8500B 1.6 GHz - 4 GB - 500 GB
£597.56
Processor Type: A6
Storage Type: HDD
Processor Model: A6 PRO-8500B
Type: Personal computer
Case Style: Desktop slimline
Optical Storage: None
Brand: HP
Price Range Ex VAT: 300 - 500
