Designed to perform, impress, and protect-this sleek HP EliteDesk helps you power through to business success while allowing customized deployment with HP's broadest range of form factors.
The solution for diverse business demands
The new way to do business. Impress and perform like never before-and meet a variety of business demands-with highly customizable tools and a stylish new design. -
Pure performance
Unlock the full potential of your PC. The latest AMD PRO A-Series APUs with HSA architecture that maximizes efficiency by intelligently prioritizing system tasks between the CPU and GPU. -
Heavy security, exceptionally managed
Keep it secure, keep it simple. IT efficiency reigns supreme when it's backed by a full portfolio of security solutions, including HP BIOSphere and HP Client Security. -
Expand with ease
Extend the life of your purchase. Using the tool-less chassis this easily upgradable platform features up to 4 expansion slots, 10 ports and multiple connectors to help you meet growing demands. -
Simplify device management
Reduce the complexity of administration. HP Client Management and DASH compliant devices help you easily and affordably manage assets. -
Enjoy the stunning graphics provided by affordable AMD Radeon Graphics.Get fast access to the data and applications your business demands with solid-state hybrid drive options.HP BIOSphere keeps mission-critical data and systems protected with customizable security.Guard your data, device and identity with HP Client Security.With TPM 1.2 your critical data has protection with hardware-based encryption keys.
- HP EliteDesk 705 G1 - SFF - A8 6500B 3.5 GHz - 4 GB - HDD 500 GB - UK - TAA Compliant
- Personal computer - small form factor - administrator password, power-on password, hard drive I/O control, serial port I/O control, USB port control, DriveLock, Setup Password, UEFI BIOS
- Localisation
- Processor
- AMD A8 6500B / 3.5 GHz (, up to 4.1 GHz, (Quad-Core)
- Cache Memory
- 4 MB L2 Cache
- Cache Per Processor
- 4 MB
- RAM
- 4 GB (installed) / 32 GB (max) - DDR3 SDRAM - non-ECC - PC3-12800
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- HDD 500 GB - SATA 6Gb/s - 7200 rpm
- Optical Storage
- DVD SuperMulti
- Graphics Controller
- AMD Radeon HD 8570D
- Audio Output
- Stereo - integrated
- Networking
- GigE
- Keyboard
- UK
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 8.1 Pro) + Windows 8.1 Pro Licence
- Software Included
- Cyberlink PowerDVD, CyberLink Power2Go, HP Recovery Disc Creator, Skype, Microsoft Security Essentials, HP Recovery Manager, HP Support Assistant, HP ePrint, Foxit PhantomPDF Express, HP Spare Key, HP Client Security, Device Access Manager with Just In Time Authentication, HP PageLift, HP File Sanitizer, Box.net 50GB storage, Drive Encryption, HP Manageability, HP Disk Sanitizer External Edition (free download)
- 33.8 cm x 38 cm x 10 cm
- 7.6 kg
- TAA Compliant
- Limited warranty - parts and labour - 3 years - on-site
- Personal computer
- Recommended Use
- Small business, corporate business
- Product Form Factor
- Small form factor
- Built-in Devices
- Solenoid hood lock
- Embedded Security
- Trusted Platform Module (TPM 1.2) Security Chip
- Localisation
Processor / Chipset
- CPU
- AMD A8 6500B
- Clock Speed
- 3.5 GHz
- Max Turbo Speed
- 4.1 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- Chipset Type
- AMD A88X FCH
Cache Memory
- Installed Size
- L2 Cache - 4 MB
- 4 MB
RAM
- Installed Size
- 4 GB / 32 GB (max)
- Technology
- Effective Memory Speed
- 1600 MHz
- Rated Memory Speed
- 1600 MHz
- Memory Specification Compliance
- PC3-12800
- Form Factor
- DIMM 240-pin
- Slots
- 4 (Total) / 3 (empty)
- Unbuffered, dual channel memory architecture
- Configuration Features
- 1 x 4 GB
Hard Drive
- HDD
- Capacity
- 1 x 500 GB
- Interface Type
- SATA 6Gb/s
- Spindle Speed
- 7200 rpm
Storage Controller
- 1 x SATA - integrated
- Controller Interface Type
- SATA 6Gb/s
Optical Storage
- DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Graphics Processor
- Video Interfaces
- VGA, DisplayPort
Audio Output
- Integrated
- Sound Output Mode
- Stereo
- Max Sampling Rate
- 192 kHz
- High Definition Audio, DTS Studio Sound
Input Device
- Mouse, keyboard
Keyboard
- Localization & Layout
- UK
- Integrated
- Ethernet Controller
- Broadcom BCM5762
- Data Link Protocol
- Remote Management Protocol
- ASF 2.0
- Wake on LAN (WoL), PXE support, auto-uplink (auto MDI/MDI-X)
- IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.1as, IEEE 802.3az
- Bays
- 1 (total) / 0 (free) x external 5.25" Slim Line , 1 (total) / 1 (free) x external 3.5" , 1 (total) / 0 (free) x internal 3.5" , 1 (total) / 1 (free) x internal 2.5"
- Slots
- 4 (total) / 3 (free) x DIMM 240-pin , 1 (total) / 0 (free) x CPU , 2 (total) / 2 (free) x PCIe 2.0 x1 - low-profile , 1 (total) / 1 (free) x PCIe 2.0 x16 - low-profile (x4 mode) , 1 (total) / 1 (free) x PCIe 3.0 x16 - low-profile
- 6 x USB 2.0 (2 front, 4 rear) , 4 x USB 3.0 (2 front, 2 rear) , 1 x serial , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x VGA , 2 x DisplayPort , 1 x headphones (1 in front) , 1 x microphone (1 in front) , 1 x audio line-in , 1 x audio line-out , 1 x LAN (Gigabit Ethernet)
- Administrator password, power-on password, hard drive I/O control, serial port I/O control, USB port control, DriveLock, Setup Password, UEFI BIOS
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- ACPI
- TAA Compliant
- Power supply
- Voltage Required
- Power Provided
- 240 Watt
- Power Factor Correction
- Yes (active)
Operating System / Software
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8.1 Pro) + Windows 8.1 Pro Licence - English
- Software
- 33.8 cm
- 38 cm
- 10 cm
- 7.6 kg
- 10 °C
- 35 °C
- 10 - 90% (non-condensing)
