HP EliteDesk 705 G1 SFF AMD A8-6500B 4GB 500GB Windows 7 Professional 64-bit
Quicklinx: BC0PWS00 Mfr#: J4V13EA#ABU
  • Microsoft Windows 7 Professional 64-bit Edition
Designed to perform, impress, and protect-this sleek HP EliteDesk helps you power through to business success while allowing customized deployment with HP's broadest range of form factors.
  • The solution for diverse business demands
    The new way to do business. Impress and perform like never before-and meet a variety of business demands-with highly customizable tools and a stylish new design.
  • Pure performance
    Unlock the full potential of your PC. The latest AMD PRO A-Series APUs with HSA architecture that maximizes efficiency by intelligently prioritizing system tasks between the CPU and GPU.
  • Heavy security, exceptionally managed
    Keep it secure, keep it simple. IT efficiency reigns supreme when it's backed by a full portfolio of security solutions, including HP BIOSphere and HP Client Security.
  • Expand with ease
    Extend the life of your purchase. Using the tool-less chassis this easily upgradable platform features up to 4 expansion slots, 10 ports and multiple connectors to help you meet growing demands.
  • Simplify device management
    Reduce the complexity of administration. HP Client Management and DASH compliant devices help you easily and affordably manage assets.
  • Features
    Enjoy the stunning graphics provided by affordable AMD Radeon Graphics.Get fast access to the data and applications your business demands with solid-state hybrid drive options.HP BIOSphere keeps mission-critical data and systems protected with customizable security.Guard your data, device and identity with HP Client Security.With TPM 1.2 your critical data has protection with hardware-based encryption keys.
HP EliteDesk 705 G1 - SFF - A8 6500B 3.5 GHz - 4 GB - HDD 500 GB - UK - TAA Compliant
Personal computer - small form factor - administrator password, power-on password, hard drive I/O control, serial port I/O control, USB port control, DriveLock, Setup Password, UEFI BIOS
AMD A8 6500B / 3.5 GHz (, up to 4.1 GHz, (Quad-Core)
Cache Memory
4 MB L2 Cache
Cache Per Processor
4 MB
RAM
4 GB (installed) / 32 GB (max) - DDR3 SDRAM - non-ECC - PC3-12800
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
HDD 500 GB - SATA 6Gb/s - 7200 rpm
Optical Storage
DVD SuperMulti
Graphics Controller
AMD Radeon HD 8570D
Audio Output
Stereo - integrated
GigE
Keyboard
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 8.1 Pro) + Windows 8.1 Pro Licence
Software Included
Cyberlink PowerDVD, CyberLink Power2Go, HP Recovery Disc Creator, Skype, Microsoft Security Essentials, HP Recovery Manager, HP Support Assistant, HP ePrint, Foxit PhantomPDF Express, HP Spare Key, HP Client Security, Device Access Manager with Just In Time Authentication, HP PageLift, HP File Sanitizer, Box.net 50GB storage, Drive Encryption, HP Manageability, HP Disk Sanitizer External Edition (free download)
33.8 cm x 38 cm x 10 cm
7.6 kg
TAA Compliant
Limited warranty - parts and labour - 3 years - on-site
Personal computer
Recommended Use
Small business, corporate business
Product Form Factor
Small form factor
Built-in Devices
Solenoid hood lock
Embedded Security
Trusted Platform Module (TPM 1.2) Security Chip
Processor / Chipset
CPU
AMD A8 6500B
Clock Speed
3.5 GHz
Max Turbo Speed
4.1 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
Chipset Type
AMD A88X FCH
Cache Memory
Installed Size
L2 Cache - 4 MB
Cache Per Processor
4 MB
RAM
Installed Size
4 GB / 32 GB (max)
Effective Memory Speed
1600 MHz
Rated Memory Speed
1600 MHz
Memory Specification Compliance
PC3-12800
DIMM 240-pin
Slots
4 (Total) / 3 (empty)
Unbuffered, dual channel memory architecture
Configuration Features
1 x 4 GB
Hard Drive
HDD
1 x 500 GB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA - integrated
Controller Interface Type
SATA 6Gb/s
Optical Storage
DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
AMD Radeon HD 8570D
Video Interfaces
VGA, DisplayPort
Audio Output
Integrated
Sound Output Mode
Stereo
Max Sampling Rate
192 kHz
High Definition Audio, DTS Studio Sound
Input Device
Mouse, keyboard
Keyboard
Localization & Layout
Integrated
Ethernet Controller
Broadcom BCM5762
Remote Management Protocol
ASF 2.0
Wake on LAN (WoL), PXE support, auto-uplink (auto MDI/MDI-X)
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.1as, IEEE 802.3az
Bays
1 (total) / 0 (free) x external 5.25" Slim Line , 1 (total) / 1 (free) x external 3.5" , 1 (total) / 0 (free) x internal 3.5" , 1 (total) / 1 (free) x internal 2.5"
Slots
4 (total) / 3 (free) x DIMM 240-pin , 1 (total) / 0 (free) x CPU , 2 (total) / 2 (free) x PCIe 2.0 x1 - low-profile , 1 (total) / 1 (free) x PCIe 2.0 x16 - low-profile (x4 mode) , 1 (total) / 1 (free) x PCIe 3.0 x16 - low-profile
6 x USB 2.0 (2 front, 4 rear) , 4 x USB 3.0 (2 front, 2 rear) , 1 x serial , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x VGA , 2 x DisplayPort , 1 x headphones (1 in front) , 1 x microphone (1 in front) , 1 x audio line-in , 1 x audio line-out , 1 x LAN (Gigabit Ethernet)
Administrator password, power-on password, hard drive I/O control, serial port I/O control, USB port control, DriveLock, Setup Password, UEFI BIOS
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
ACPI
TAA Compliant
Power supply
Power Provided
240 Watt
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8.1 Pro) + Windows 8.1 Pro Licence - English
Software
33.8 cm
38 cm
10 cm
7.6 kg
10 °C
35 °C
10 - 90% (non-condensing)
